go_a_way1
Old 11-04-2014, 09:35 PM   #2087
CSG Mike
CSG Mike's Avatar
Originally Posted by pleong View Post
What can I do to get better traction out of the rear coming out of a corner? I put on the whiteline positive traction inserts.. it definitely feels a LOT better.. but I feel like it's about to slip still.. any recommendations? Maybe a sway bar? I still have the stock sway bar on for now..
Are you actually losing traction or just afraid of losing traction?
Old 11-04-2014, 09:43 PM   #2088
dp1
driving smoother faster
Drives: Sold
i have -2.5 degrees camber in the rear with 255/35 RS3 tires.. I do need to upgrade the LSD.. i have kwv3s
As mentioned above, aero (only matters at speed), tire pressure...also smooth transition (hands) and modulated application of brakes/power (feet), especially if boosted, also suspension not too stiff for smoother weight transfer...I like zero toe and on track I preferred 3.4f/2.7r camber to the 3.0f/2.5r that I have now...
dp1 is offline   Reply With Quote
Old 11-04-2014, 09:57 PM   #2089
OkieSnuffBox
Drives: '23 BRZ Limited
This is a very valid point.
Those of use that started out tracking on two wheels are a little more accustomed to the effects of weight transfer and being OK with the vehicle moving around more.
Agreed.
It takes testing/experimentation to see what you're comfortable with/suits your style/etc. Get your base alignment set, mark it, then you can experiment.
Old 11-04-2014, 11:13 PM   #2090
sw20kosh
Drives: 2013 Black FR-S
Tuning can play a factor here. I see you are turbo'd like I am.
For example, I tried a new tuner's map at my local track and was instantly disgusted by it at corner exits. The way he has my power/boost come in is too "laggy" and when it does come in it surges causing the rear to feel unpredictable and loose. I switched back to my original tune and the power delivery was linear withe the throttle and powering out of corners became predictable again.
Other than that, as people have said, more tire and camber, maybe less tire pressure depending on your tire temp distribution. How much boost are you running? I am on WG pressure (6-7 psi) at the track which makes the car less monstrous....
A lot of people grow to love oversteer and might even tell you that the rear feeling loose at the limit is a good thing. Controllable oversteer is different than unpredictable boost surging though. I like the former.
Old 11-05-2014, 09:17 AM   #2091
pleong
Drives: 2013 Whiteout FR-S
Not actually losing traction, but i can feel it about to slip.. maybe i should accelerate a little more then?
I'm running 25psi on the rear tires
Yes, I have FI, I keep it at my lowest setting of 8psi. my tune is very linear and pretty predictable, i love it!
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 11-05-2014, 11:16 AM   #2092
dp1
Drives: Sold
Where you can do this safely, adjust one variable at the time, then push just beyond the limits of adhesion and observe how the car behaves as you correct steering and apply brakes/gas. It will teach you a lot. I've spent some time lately on a local short (.7 mi) AX course at Lime Rock Park - a small track with elevation changes and varied turns, as opposed to a parking lot with cones. I learned more about the car in three days of inducing slip on this course where it's safe to spin out at lower speeds than in 4 years of tracking two cars on full race tracks, where I was afraid to push too hard due to a higher risk of damage.
Old 11-05-2014, 12:46 PM   #2093
stonenewt
Drives: BMW 120d
OT: I can see a disused old air strip which would be a hoot to use as a testing ground from my place. Problem is it's the wrong side of a military fence
stonenewt is offline   Reply With Quote
Old 11-05-2014, 01:28 PM   #2094
Racecomp Engineering
25 psi sounds awfully low...
A larger rear swaybar will not help. I would start by softening rear compression on your V3s a few clicks.
- Andy
Old 11-05-2014, 01:29 PM   #2095
Originally Posted by Reaper View Post
I am definitely thinking stiff bars soft springs for my turbo mostly street car. I need a little front back weight transfer for traction. Eibach sways on full stiff might be in order. Maybe 7k springs? Maybe a little softer? Anyone running something similar on the track?
7k isn't THAT soft. That's more like "medium" to me. What kind of tires are you running?
- Andy
Old 11-05-2014, 03:04 PM   #2096
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
For rs3, try 35 hot. So around 28-30 cold
bkblitzed is offline   Reply With Quote
The Following 2 Users Say Thank You to bkblitzed For This Useful Post:
juliog (11-05-2014), pleong (11-05-2014)
Old 11-05-2014, 03:34 PM   #2097
CSG Mike
CSG Mike's Avatar
IMO, you should keep driving until the rear is actually breaking loose.
What kind of suspension setup and tire setup are you running?
What you think "feels" loose, may not actually be even close to the actual limit of the car.
pleong (11-05-2014)
Old 11-05-2014, 03:42 PM   #2098
pleong
I'm on KWV3 coilovers, whiteline LCAs, HVT Camber plates, Whiteline Camber Bolts, Whiteline toe arms, Whiteline Front Endlinks, Whiteline Positive traction kit, Whiteline front caster bushings, Whiteline Front Strut Tower Brace, 255/35 Hankook RS3, 18x9.5 +38 Enkei RPF1s
I'll take your advice and make changes once i actually do go loose! THANKS!
Old 11-05-2014, 07:29 PM   #2099
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
25psi is getting dangerously low IMHO. I wouldn't go below 30 cold.
Old 11-06-2014, 12:16 AM   #2100
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I start at 27 cold. It gets to 34 hot which is just right.
Sleepless is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
