Drives: 2013 Subaru BRZ Sport-Tech
BRZ to FR-S Trunk Lid Swapping
Hi all,
Did a search for this, but couldn't find something that could address my question clearly. Was wondering what is involved with a trunk swap between a BRZ and FR-S. I have the BRZ with the OEM spoiler on it and found an FR-S with the same color, interested in trading me. Besides the badging (which I assume can be directly swapped by transferring the badges?), what else do I need to be aware of that requires effort over and above a straight BRZ to BRZ swap? Thanks! |
#2 | |
Drives: Whiteout FRS
#3 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i did that. you unbolt yours, unbolt locking mechanism and swap the harness/trim with the license plate lights. very straight forward.
#4 |
Lacking brains
Drives: frz
I own an frs,
i bought a brz limited trunk off ebay and put a wing on the frs trunk for autotivities. When i swap its 4 bolts for the hinges, 2 for the license plate and unplugging the wiring harness. Latch is never touched because i'm not worried about the using the key for my purposes. |
#5 | |
#6 | |
Lacking brains
Drives: frz
Spare key? Or in my case with a rear seat delete just reach through. I do agree though. For most people swap the mechanism too for the one oddball chance over the life of the car you may use the key hole. I.e. when the kill button at the side of the trunk gets bumped. |
#7 |
thanks for the tips everyone. in the Sport-tech version (here in Canada), I get the push to start button, so I only have remote fobs anyway. not even sure if i have a keyhole in my trunk to start with...and if I did, I have no key, lol. good to know it is a simple swap. thanks everyone. will save me a lot of money no having to fill in the holes and refinish the lid to get a new wing on there.
#8 |
Drives: 2013 BRZ Sport-tech WRB
There is a keyhole, its facing down and located where you grab the trunk. You're keyless fob has a physical key inside it, you push on the button on the side to pop it out. This will let you open the driver's door with the dead battery and you can open the trunk.
You want the latch swapped over. Don't rely on the dashboard button. There is a switch in the trunk to be used when giving the car to valets that prevents entry into the trunk. It makes the keyfob to no longer pop it or allow you to use keyless to open and it also disables the button. The only way to open the trunk if that switch is on is to use the key or figure out some way to manhandle the rear seats into folding from inside the cabin. The unfortunate part is that they installed this switch low in the trunk on the left side. Someday, sometime, stuff you have in the trunk will hit it and lock you out of your trunk. You'll be glad that your key works in it then. |
#9 | |
#10 | |
RedBunny w/ Wing
| Swapping the motor. Either 3uz or 2gr | diss7 | Engine Swaps | 34 | 11-16-2015 04:31 PM |
| spoiler swapping?? help? | Justinyuen16 | FR-S / BRZ vs.... | 2 | 07-10-2014 10:04 AM |
| Swapping OEM FRS Spoiler for 5 Axis | CamryDS | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-30-2013 01:59 AM |
| Swapping springs need HELP! | SleekMachine | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-17-2013 04:05 PM |
| Swapping the stock nav system. | yeabude | Electronics | Audio | NAV | Infotainment | 24 | 01-28-2013 05:12 PM |
