Old 05-04-2012, 11:28 PM   #1
sieeegel
Drives: rsx was stolen :(
trunk measurement question
Does any one know the measurement of the trunk opening between the two rear brake lights? I know the trunk dimensions, im just trying to determine the width between the brake light opening of the trunk lid to see if i can slide a tv in the trunk. Thanks
sieeegel is offline   Reply With Quote
Old 05-04-2012, 11:41 PM   #2
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
http://www.ft86club.com/forums/showt...t=measurements
bam!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 05-04-2012, 11:44 PM   #3
carbonBLUE
Reverse Burnouts
width of the trunk is about 50 inches where his hand comes down is about at the 14 inch mark
EDIT
i would say the opening is about 22-24 inches wide at its smallest point just guessing
you can always lower the rear seats and slide the tv in from the front doors with the drivers seat folded forward against the steering wheel and slide the tv in the back and into the trunk
the tv has to be skinnier than 39 inches to go into the trunk the reverse way
(wont forget you)
2011 Infiniti G37x
Old 05-04-2012, 11:52 PM   #4
sieeegel
unfortunately the tv dimensions are 51 x 34 x 6 and probably too big to fit thru the front door. Im just trying to see if it can fit thru the trunk opening. I know its small enough to physically fit in the car. just getting it in may be a problem.
Old 05-05-2012, 12:13 AM   #5
Elgancho
Drives: SWP BRZ Limited MT
Dafuq u trying to buy a car to fit a tv in for? Rent a truck for 30 minutes.
Elgancho is offline   Reply With Quote
Old 05-05-2012, 12:13 AM   #6
carbonBLUE
Reverse Burnouts
yeah that does seem tricky, if the car had a targa top, the tv would slide right in!
(wont forget you)
2011 Infiniti G37x
Old 05-05-2012, 12:31 AM   #7
sieeegel
long story short, but im trying to bring the tv with me to florida from illinois.
Old 05-05-2012, 12:42 AM   #8
carbonBLUE
Reverse Burnouts
yup totally doable in 30 min
(wont forget you)
2011 Infiniti G37x
Old 05-05-2012, 10:17 AM   #9
DEC1
Drives: '10 Infiniti G37 (pre-ordered BRZ)
perfect reason/justification for a NEW TV!...
DEC1 is offline   Reply With Quote
Old 05-05-2012, 01:27 PM   #10
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
So, here are the assumption based on the measurement thread:
* the length from front seat back to the edge of trunk is 56 inches.
* the rear seat is 39 inch wide. Although the width of the opening is not measured, i would guess it is a bit (< 2 inches) narrower than 39 inches.
* the height of opening is greater than 6 inches.
So if you slide your TV longitudinally (long side straight in with short side on the width), you should be able to fit your TV in no problem. Of course you have to slide the TV in through trunk opening. You might also want to put some protective stuff on your TV.
And this is just some random Internet guess based on information gathering.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Unlockable trunk? Kage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 10-12-2013 01:57 PM
FR-S / BRZ no trunk liner? R0ME0 Scion FR-S / Toyota 86 GT86 General Forum 76 04-22-2012 10:31 PM
Trunk swap with VIN question ozne99 BRZ First-Gen (2012+) — General Topics 15 04-08-2012 05:56 PM
What's in your trunk/car thread? S2kphile Off-Topic Lounge [WARNING: NO POLITICS] 40 02-23-2012 04:07 PM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 01:29 PM
