Old 11-02-2014, 01:04 PM   #43
vgi
Drives: frs
Originally Posted by dwx View Post
The only Toyota thing on the car is the D4S system with noisy pumps and issues with injector seals leading to blown engines.
I'm a Subaru fanboy but I've owned 9 of them and never had a mechanical issue that wasn't self-inflicted.
the injectors seals melting are due engine overheating which seems to be due to piss poor suburu tuning of the engine (knocking). still, i've never seen another car that takes so long to cool down, 6 hours later after a drive i can still fry eggs on that engine. the D4S has been running fine on all pure toyota cars. we're yet to see how reliable is subaru DIT system will be, especially dealing with carbon built-up.
oh, and for the record, i'm not a fan of any car company, not a brand freak. actually don't give a flying f.. about any company. i pay attention to a specific car that's interesting from any company.
vgi is offline   Reply With Quote
Old 11-02-2014, 01:57 PM   #44
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
The fa20DIT will die a horrible death I can almost guarantee it. My engine is cool to the touch and I'm at 450whp. Pm me I'll show you how to fix that.
Old 11-02-2014, 02:15 PM   #45
stugray
Drives: 2013 GBS BRZ Limited
YOu got that a little messed up. The DI seal failure IS Due to knocking, but that causes overpressure fatigue which leads to blowby which makes the seals look burnt when replaced.
The failure is not due to overheating.
Then you have something seriously wrong with your car.
After an hour highway drive my BRZ is cool to the touch in an hour.
At the track it never got to the point of overheating, however I wasnt driving the car like I stole it (stock tires)
My OTHER 4 cyl 2.0L boxer engine is aircooled (runs much hotter) and I can change the oil in an hour after a hard run.
The Following 2 Users Say Thank You to stugray For This Useful Post:
DAEMANO (11-24-2014), ZZT86 (11-03-2014)
Old 11-02-2014, 02:42 PM   #46
+1
Old 11-02-2014, 08:10 PM   #47
Incursion
Drives: 2013 BRZ Dark Gray
LOL at the suggestion that I might be a troll.
13k miles
last oil change: 7500
I checked the oil shortly after the failure, and it was fine. Subaru said it's covered under warranty, and they're just waiting for parts. It's been two weeks.
Incursion is offline   Reply With Quote
The Following User Says Thank You to Incursion For This Useful Post:
ZZT86 (11-03-2014)
Old 11-02-2014, 08:35 PM   #48
BRZnut
Drives: BRZ DGM Limited
13k miles
Any issues, odd events, or repairs done to the engine before the failure??
Old 11-02-2014, 08:38 PM   #49
Incursion
No
Old 11-02-2014, 08:43 PM   #50
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
13k miles
Good to hear that Subaru is standing behind it.
Ya, this. Just out of curiosity and did they provide any explanation as to why it failed?
Originally Posted by paulca View Post
Has anyone mentioned Hitler yet?
Hot Lava is offline   Reply With Quote
Old 11-02-2014, 09:00 PM   #51
Incursion
No, and no explanation.
Hot Lava (11-02-2014)
Old 11-02-2014, 09:08 PM   #52
vgi
Drives: frs
maybe you're right, i posted based on some older posts (which are speculations) that got stuck in my memory:
http://www.ft86club.com/forums/showp...6&postcount=53
http://www.ft86club.com/forums/showp...7&postcount=82
i have never though seen anything official from toyota or subaru, so do you have another speculation or some solid official info?
the car has been taking a LONG time to cool from day 1, so if there is something wrong with it - it's from factory
Old 11-03-2014, 07:48 AM   #53
ZZT86
ZZT86's Avatar
Drives: BR86
I must also admit, when the 86 was new yeah engine bay temps seemed high compared to my previous bombproof Toyota, however after run-in this changed especially after changing the fuel that I use. Heck I started a 30 minute log of engine parameters on Friday arvo with air temp @ 34C took it fairly easy (my usual drive) warmest coolant temp was 92C & warmest oil temp was 102C ! Cooling system is rock solid, stays put b/w 89-90C usually, pop hood & bay temps are just fine !
PS: My 86 is still kicking goals despite my lack of confidence re it's long term reliability & my preference for Toyota engineering.
ZZT86 is offline   Reply With Quote
Old 11-03-2014, 11:09 AM   #54
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Awesome to hear that your being taken care of. Strange the engine up and died with no provocation, shame your dealership is uncommunicative about this, we will likely never know unless it becomes a common problem.
Old 11-04-2014, 09:57 PM   #55
vobla6.0
Resident Douchebag
Drives: balla'
Originally Posted by pushrod View Post
Why's that?
The oil pressure there is the lowest out of all rod bearings.
Its the first one to take a shit.
vobla6.0 is offline   Reply With Quote
Old 11-05-2014, 03:54 AM   #56
stonenewt
Drives: BMW 120d
Or maybe not. Look at what Element Tuning found
stonenewt is offline   Reply With Quote
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Engine failure - 38,000 miles Mr 286 Issues | Warranty | Recalls / TSB 217 10-05-2014 09:52 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
