#2059 |
Thanks
P0351 code, how serious is this? Should I be worried? Can I do the second day of track event? Does this lead to DI seal issues or is it unrelated?
#2060 | ||
Off Topic
#2061 |
Drives: '22 BRZ
That's exactly the problem, IMO the brake ends up too low vs the throttle and I keep releasing pressure off the brake by accident when I'm done blipping the throttle. If I'm not 100% on the brakes I'm fine, even up to 90% and I can keep it smooth. Guess I just need a lot more practice
#2062 |
Drives: 2012 Toyota 86
you may need to put some new fluid in to get rid of the mushy pedal. i recommend project mu as it makes flushing so easy with the green color and turning clear when its bad.
#2063 |
Drives: '22 BRZ
Not a bad idea. Might go with SS brake lines as well since it made a noticeable difference on my GTI. I know on my GTI a lot of the pedal feel was dependent on the pads. The street pads made the pedal feel like mush but as soon as I dropped my track pads in the pedal was easily firmer. Hmm.
I don't want to blame the car and I'd love to improve my technique
#2064 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
My dealer just cleared the code but next time on track it happened again so I ignored it. After a bit of rest and a few starts the CEL disappeared. But, when it came on again I told dealer and they replaced the ignition coil under warranty even though I was using car on track.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#2065 |
#2066 | |
There's no "wrong" way. Some guys pivot their foot, others use the sides. |
#2067 | |
Thanks
I'ts an $80 part I'll probably just buy than waste hours at the dealer.
#2068 | |
Drives: 2013 FRS / 2013 427 Vert
You can find them for $80 on line but the part itself has already seen 2 revisions. Part # ending in 650...651.....now 652 Anyone's guess as to what was changed but I just ordered 2 and got 650's. I wrapped the stem and box with heat tape just as a precaution as it seems #1 fails most often and is located closest to the header collector which is unshielded on my car. Mine started acting up at the track in August on Saturday morning, car would misfire at higher revs and the Track Off setting started allowing violent intervention in high G's. I parked it for the rest of the weekend.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#2069 |
#2070 |
Thanks
Ugh cant reach either on driver side...
#2071 |
#2072 |
Thanks
Not sure what im missing i have a 10 mm socket and ratchet. I guess need a smaller one because its too big. Maybe a 1/4 inch ratchet?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
