Old 10-23-2014, 02:58 PM   #2045
steve99
Drives: FT86
Originally Posted by Necric View Post
Getting error 0x65, problem reading from device. And when I try to upgrade I get missing file AUTOCST.LST
Check you on OFM 1.13.0
also on latest template file from page below should be FRS Custoised 4.SLT
http://openflashtablet.com/Automotiv...ads/index.html
make sure your logged in as administrator and maybe turn off antivirius just while oft updates
Old 10-23-2014, 03:17 PM   #2046
Necric
I am on 1.13, thats the file I have, and im an admin and antivirus is off
Necric is offline   Reply With Quote
Old 10-23-2014, 03:27 PM   #2047
Necric
Oddly enough, connecting to my VPN fixed it. Must be a firewall issue here.
Old 10-27-2014, 10:52 AM   #2048
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Someone might have asked this before already, but can I still use the OFT just for data logging even if I'm on ecutek?
Logging with ecutek would require taking laptop into car yes? Whereas logging with OFT is much simpler.
Fizz is offline   Reply With Quote
Old 10-27-2014, 11:40 AM   #2049
phrosty
I think so, but Tactrix might be a cheaper route if you don't need a real-time display.
phrosty is offline   Reply With Quote
Old 10-27-2014, 11:51 AM   #2050
Foobar
SLO NO MO
Foobar's Avatar
This is what I found on the OFT site:
Can I flash multiple cars wither the same device?
No. Each OpenFlash Tablet can only flash the DME of one car at a time. However, it can be “unmarried” from the car by flashing the original ROM file into the DME and erasing the device contents. At which time, the device can be installed on a second car. But even when married to one DME, the device and be used in Diagnostics mode in other vehicles. Diagnostics mode will provide individual adaptation resets, code reading/clearing, data view and soon, data-logging and data graphing.
Old 10-27-2014, 10:10 PM   #2051
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hmm....sounds like it's possible then. I was planning to sell off the OFT once I get my turbo kit (with ecutek map), but I might keep it now and just use it for datalogging purposes.
Old 10-28-2014, 12:51 AM   #2052
steve99
Drives: FT86
Tactrix or oft should work as long as the ecutek guys ut rhe info in the same ram addresses as the standard roms. logging reads a specific ram address.
The ecutek guys mess round with the program a fair bit with map switching and racerom features ect but may still use same ram addresses. If you know someone with ecutek tune plug your oft in see if it will log, it will log any brz/86 will only write to married car
once your on ecutek dont use oft/tactrix to write or you will write over you ecutek licience in the rom of your ecu
Old 10-29-2014, 01:57 AM   #2053
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
How does it look?
Any other parameters I should be logging?
http://datazap.me/u/andrew025/ptunin...g=0&data=1-8-9
Old 10-30-2014, 09:07 PM   #2054
shif7i7down
Erected Member
Drives: frs
hey guys , just wondering if anyone has a fix for this.
I'm still able to upload files onto the ecu with the OFT but i can do live diagnostic, everytime i try it just says "please update template" so i went on the oft site and downloaded their latest template from the download section, updated the tablet and still says the same thing.
any idea?
shif7i7down is offline   Reply With Quote
Old 10-30-2014, 09:20 PM   #2055
steve99
Drives: FT86
any idea?
template should be FRS customised4.slt
OFM should be version 1.13.0
think oft is ver 1.31
if thats all good ring the oft guys
Old 10-30-2014, 09:29 PM   #2056
shif7i7down
Erected Member
Drives: frs
that might be the problem, i updated with FA20 Template 1
Old 11-01-2014, 02:51 PM   #2057
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
@vishnu
Why does the Base idle timing (above RPM threshold) table stop at 2000RPM and then continues onto numbers like 2.####E##.
I was trying to add higher rpms and retarding the timing in them but after the checksum fix, the whole table goes completely out of wack.
The guys over at romraider's forum were able to edit the table without any issue, is it not recommended or something?
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 11-01-2014, 03:23 PM   #2058
steve99
Drives: FT86
Originally Posted by ray7792 View Post
@vishnu
STOP - you may be using wrong definition for your tune file. For V2 OFT tunes you must use defs that come with the tune download file, do not use the V1.5 defs.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
