#29 |
Drives: '13 BRZ Limited, '95 BMW M3
Guys dont forget they are playing with California's rules.
#30 | |
#31 | |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
A blow-through setup (ie: no intercooling) coupled with our high compression fa20 has disaster written all over it. @WORKS You're definitely going to have to prove your kit here with proper dyno videos, sheets, and how you're not detonating. I can see one or two power pulls, but this kit I can't seeing living too long upon hard use. For real though, all this kit needs is an A2W intercooler in place of that goofy fined pipe. I can see this kit being something different but great. Just needs one of these setups:
| The Following User Says Thank You to hmong337 For This Useful Post: | cdrazic93 (10-27-2014) |
#32 |
Yeah I thought of that and the design lends itself to using a barrel AWIC. Would need something to support it, that aluminum finned pipe is light enough to be supported by the end piping, the AWIC certainly isn't. There are plenty of places in that area to bolt a bracket too though. The specs I saw on the pipe show it being 6" in diameter from fin to fin. You can certainly get barrel AWICs which are smaller.
#33 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I was about to buy this kit. Only reason I held off is because my current financial situation.
They do intend to have a intercooled version early next year. Not 100% sure if they were going to have it as a upgrade that you could buy after or not. I can't speak for works. But I don't think this kit was made to be a track killer. But I did see them at Laguna Seca with it for a hpde event. As far as having a kit with no intercooler at all, I am comfortable At low psi without it. My celica does not have a intercooler with the greddy supercharger and has fairly high compression. When I was on 91 octane I did fine at 11 psi on all but the hottest days in summer. Now on e85 it is a non issue for my car. |
| The Following User Says Thank You to clayrush For This Useful Post: | WORKS (11-07-2014) |
#34 |
I know people who have run non-intercooled turbos on the FA20. If you can run E85 all the time I don't consider running low boost a big deal. 91 octane? Forget it if you want to have an engine survive for very long or unless you limit yourself to 4-5 PSI.
#35 |
Drives: FR-S 10 #103 AT
How would this system work with an aftermarket header? Even faster spool?
Just thinking about guys who already have one.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#36 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
@WORKS when are you planning to entertain our questions? I would hate to see many people turned off your product early due to speculation.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
| The Following User Says Thank You to Boofneenee For This Useful Post: | WORKS (11-07-2014) |
#37 |
I Love custom Turbo kits
Drives: Limited BRZ
This looks like @86_ZN6 car. This is the same ex site "vendor" who got banned (Really don't know why), but I remember him having big arguments in the page because of a WORKS (IIRC) drop in filter that claimed 10 whp and couldn't back it up with a dyno. Also tried to pre-sale like 30 members on TOMs tails but in fact they were not Toms (something about a manufacturer not being selected), and having another big discussion with money being held, when was the money going to be returned, etc.. etc... And also some issues with a groupbuy for some VG Sharkfinn antennas taking a long time to get built after taking the money for all of them.
I don't think he "worked" for Works, but think they had a close relationship and his car was being used to prototype a turbo kit. (This was all many months ago). EDIT: I've been clarified via PM that WORKS is no longer associated with the aforementioned individual. That is very good news.
| The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post: | AllDayJonRay (11-01-2014), ATL BRZ (10-29-2014), kidgogeta (10-31-2014), Marchy (11-07-2014), WORKS (11-04-2014) |
#38 | |
Drives: WORKS CARB Legal Turbo BRZ
Did you visit our web-store link? That has good deal of information and if you still have any questions feel free to ask! The web-store listing can be seen here: http://store.worksmotorsports.com/WO..._p/142.211.htm More photos of the down pipe are coming soon as well.
#39 | |
#40 | |
Included in our kit is a heat shield that protects the battery. It's not easy to see in the first photo, but more photos are coming shortly. Official dyno graphs will be released when the kit is released publicly. Cheers!
#41 | |
We have already discussed through PM, but to let everyone else know we are open to non-local people taking advantage of the offer. Just PM us so we can understand your particular situation. Regarding track testing, our development kit installed on our own BRZ had 3 drivers do back-to-back track days at Laguna Seca where we were data logging every run with two laptops and every time we came back to the pits, we used our IR temp gun to record all the turbo parts and surrounding components. We even had temperature indication paint on the all parts of the turbo kit and the surrounding areas. We have internally and externally thermal coated the up and down pipes and properly shielded all of the wiring. We are also keeping the air-fuel ratios on the rich side to keep exhaust gas temperatures down. That being said, if you will be driving your car on the track, at the autocross, etc., we certainly recommend an oil cooler kit like ours (soon to be released) to reduce the peak temperatures prevalent in the FA20. Hope this helps!
#42 | |
No damage will be done to your paint from using our kit.
| WORKS Stage 1 Turbo Kit Pre-Release Offer | WORKS | Northern California | 31 | 11-11-2014 08:24 PM |
| Hello from WORKS Motorsports! **10% discount for FT86club Members!** | WORKS | Announcements, Contests, Giveaways | 1 | 04-16-2014 11:04 PM |
| Full Blown Stage 2 Turbo Kit Official Release!! | FullBlown | Forced Induction | 53 | 11-18-2013 12:58 PM |
| Discount offer on Tirerack | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 04-01-2013 06:45 PM |
| Subaru $50.00 test drive offer/ $500.00 discount card | terrypm | BRZ First-Gen (2012+) — General Topics | 7 | 08-24-2012 12:33 PM |
