#43 |
Engineering Student
Drives: Scion FR-S 2015
#44 |
Engineering Student
Thread updated guys, please read my thread again and answer my question if you want
. Thanks in advance.
#45 |
NASA SpecE30 Racer
You still have research to do. I call that run a 12 PSI run. Sure there is a spike to 14 PSI and the PSI tails towards redline. That was not a one time use. That was a tune I ran often and hard including many dyno runs and even some drag strip runs. The GTX2867 is definitely better than the GT2871R.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#46 | |
NASA SpecE30 Racer
2. I would coat the manifold, downpipe, dumptube (if non recirculated), and the turbo housings. Then I would still throw heat wrap on the downpipe and a turbo blanket on the turbo. Try and keep as much heat doing what it is supposed to do and not warming up your engine bay. 3. LJ @FullBlown will provide you with a basemap to get your car running. It will be safe and will let you boost the car to make sure everything is working properly. I would make sure you log your first drives to ensure your AFRs are correct and there are no major knock events. Then once you are happy everything is running correctly and installed properly, you contact a tuner and get a proper street/dyno tune to make best use of your car and hit your whp/torque goals. 4. Wastegates are used to regulate boost with a spring. FBM provides a properly sized unit. The kit also comes with a BOV that you will also need to have the correct spring installed to keep working properly. 5. This is a personal option. I prefer knowing that hot exhaust gasses are going out the back of my exhaust and not being dumped in the engine compartment or under the front of the car. Some guys prefer the loud sound of those exhaust gasses being wasted by an open wastegate though. 6. Your hp/torque goals will determine what PSI level you will run. There is no guaranteed answer that 7 PSI will or won't meet your goals. It will depend on the ignition timing of your tune and the other modifications on your car. 7. Already answered this. I would get the ACT full face and a lightweight flywheel at least. 8. Just because you install a turbo kit doesn't mean you need to upgrade your brakes. Unless you are going to be doing track days, save your money.
- King Tut
| The Following 2 Users Say Thank You to King Tut For This Useful Post: | Dipstik-sportech (10-28-2014), Mikeez (10-28-2014) |
#47 | |
Engineering Student
Thank you sooooooooooooooo much. Very well detailed. I appreciate your help and time seriously. 1. ![]() 2. Manifold = header? 3. Who's LG lol? How much does he charge? After LG provides me with a basemap, why would I need another tune? 4. The spring is not already installed on the BOV? 5. So recirculating will make the hot gasses go out from the back? 6. Okay ![]() 7. Why though, just because it won't slip? How easy is the clutch? 8. Awesome. |
#48 |
LJ is the owner and tuner at Full Blown.
His kits come with a base tune. Always double check the spring that's installed in the BOV just in case.
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | D_Thissen (11-03-2014) |
#49 | |
Engineering Student
Alright, I want to personally thank you for the time and concern you've put on to help me man. Appreciate it, I don't know how to thank everyone. |
| The Following User Says Thank You to Mikeez For This Useful Post: | Dipstik-sportech (10-29-2014) |
#50 | |
NASA SpecE30 Racer
3. LJ @FullBlown is the man. He is the guy you will want to contact for any questions. 4. There is a spring installed, but one of the issues with the kit is the location of the MAF sensor and BOV and so getting the spring in the BOV tuned properly is key. 5. Recirculated takes the hot exhaust gases from the wastegate and puts them into the downpipe to go back out your exhaust. An open dump will normally use a dump tube and dump them under the front of the car. 7. I didn't want to have to worry about the clutch slipping. I got my ACT 6 puck when there were less options, and I knew it would hold plus I have only had good experiences with ACT. With a lightweight flywheel and a 6 puck you will need good clutch and throttle application skills. If you don't have those, then avoid it.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Mikeez (10-30-2014) |
#51 |
Junior
Drives: a car
Where is @FullBlown when ya need 'em! Lol
#52 | |
Junior
Drives: a car
#53 | |
NASA SpecE30 Racer
- King Tut
#54 |
Or doing Grom turbo kits and big bores.
#55 | |
Engineering Student
4. Why would they cause problem? When do you know that a tune has not been done properly? 5. So recirculated is better if it goes down the exhaust system. Since under the car is not practical? 7. What if I don't have good clutch and throttle application. Sometimes, I am lazy and make the car kick back! So... :3 What should I get |
#56 | |
NASA SpecE30 Racer
5. Better performance, no. Better heat and sound management, yes. 7. With your current goals you are probably better off sticking with a full face clutch and not a puck. Might be best to stick with the OEM flywheel as well if you want a more OEM driving experience.
- King Tut
| Any body have a p&l turbo kit for sale or full blown turbo | Anthony7515 | Want-To-Buy Requests | 2 | 06-06-2014 05:43 PM |
| Full Blown Turbo Kit Q & A | 69Marshall69 | Forced Induction | 3 | 04-18-2014 01:18 PM |
| fs feeler full blown turbo kit minus turbo | kingkai23 | Engine, Exhaust, Bolt-Ons | 10 | 03-11-2014 02:59 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
