Old 10-27-2014, 01:05 PM   #1
Simon
Drives: 2014 Scion Frs Monogram
Monogram headlight issues
Hey guys, I encountered a problem about a week ago. I own a 2014 scion frs monogram series which has HID headlights. I replaced the OEM bulb for diode dynamics 6k HID D4S bulb. It worked perfectly for about a month and then now my passenger side headlight keep shutting off on its own. Whenever i turn on the headlights, it would work, and about 30 seconds later the passenger side would shut off. I keep having to turn it off and on so it can stay on but in the end it just shuts off in a few seconds.
Im not sure whether its the bulb or the ballast itself. I figured it cant be the bulb since it still has a light output.. it just shuts off. any ideas? it would be greatly appreciated.
Simon is offline   Reply With Quote
Old 10-27-2014, 01:11 PM   #2
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Sounds like a ballast. I would contact Diode Dynamics and ask for an RMA.
Jyn is offline   Reply With Quote
Old 10-27-2014, 01:22 PM   #3
Kaotic Lazagna
Drives: GR Corolla
Swap bulbs from side to side. If it continues to shut off on the passenger side, it's the ballast. If it now shuts off on the driver side, it's the bulb.
Old 10-27-2014, 01:56 PM   #4
cliff p.
Drives: '15 BRZ series.Blue
Keep in mind that most systems are 35w systems. If you use a 55w bulb in a 35w system, the bulb will flicker and fail to ignite, shutting off after it reaches operating temps.
If you run a 35w bulb in a 55w system, it will work fine, however some say that the 55w ballast will blow a 35w bulb prematurely (speculation, basic electrical theory does not work this way).
cliff p. is offline   Reply With Quote
Old 10-27-2014, 04:06 PM   #5
Simon
After testing out different scenarios, it came to the conclusion that is it in fact the bulb.
I swapped sides with the bulbs, and it shut off on the driver side now. I then tried switching out the diode dynamic HID bulb with my OEM bulb, and the OEM bulb never shut off. It can't be the ballast since it never shuts off the passenger side whenever I swapped sides, and it never shut off whenever it is OEM bulb. I believe one of the Diode dynamic bulb has faulty issues.
Another weird thing is that if i have the faulty diode dynamic bulb plugged in but outside the bulb socket with the car off but headlights on, it doesn't shut off. But as soon as it is in the socket it shuts off.
Then, once i swapped sides with the diode dynamics, in the socket it worked perfectly. never shut off, but as soon as i turn the car on, it shuts off the driver side.
For now I will be using my OEM bulb until I get a replacement on another HID bulb.
thanks for the suggestion guys.
Old 10-27-2014, 05:26 PM   #6
Kaotic Lazagna
Drives: GR Corolla
Possibly a bad connection somewhere on that one bulb??? Contact DD yet?
Old 10-27-2014, 06:14 PM   #7
504
504's Avatar
Drives: 2014 86 GTS
Originally Posted by Simon View Post
about a week ago
haha had to do it
504 is offline   Reply With Quote
Old 10-27-2014, 11:19 PM   #8
merino_frs
merino_frs's Avatar
Originally Posted by 504 View Post
haha had to do it
I thought the exact same thing
merino_frs is offline   Reply With Quote
Old 10-28-2014, 10:48 AM   #9
Diode Dynamics
Diode Dynamics's Avatar
Give us a call at your earliest convenience and we will help you troubleshoot further and provide more warranty assistance: (314) 205-3033
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
merino_frs (10-28-2014)
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
Anyone looking for a Monogram FR-S merino_frs Northern California 2 07-01-2014 02:43 PM
How much did you pay for your Monogram FR-S Tea86 Scion FR-S / Toyota 86 GT86 General Forum 7 05-29-2014 09:59 PM
HID Headlight Issues KkSc Cosmetic Modification (Interior/Exterior/Lighting) 5 02-10-2014 04:23 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
