Old 10-27-2014, 07:10 AM   #183
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
Originally Posted by mid_life_crisis View Post
Without a view of the gauges, all I saw was a bouncy, noisy car.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following 3 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post:
cf6mech (10-31-2014), Fast_Freddy (10-31-2014), themadscientist (02-06-2015)
Old 10-27-2014, 10:45 AM   #184
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by SomeoneWhoIsntMe View Post
There is nothing about that video that gives any sensation of an improvement in any capacity. Without knowing that it was a V8 swap, it was just another loud car.
Originally Posted by AtlasMick View Post
The view you do get of the gauges shows them not working.
The angle was such that I didn't really pay attention. Thank you (sincerely) for pointing that out.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-30-2014, 02:57 PM   #185
ftc~brz
Done
Drives: WRB BRZ
should I be surprised the forum lacks members capable of google searching?
The car belongs to Brady @ Pure Automotive Performance in Maryland.
http://instagram.com/p/snaF2PjIuz/?modal=true
Name:  Screen Shot 2014-10-30 at 2.49.57 PM.png
0 fucks given about what trolls think
ftc~brz is offline   Reply With Quote
The Following 5 Users Say Thank You to ftc~brz For This Useful Post:
@Art_Mighty (11-01-2014), cf6mech (10-31-2014), Fast_Freddy (10-31-2014), Lawnik (03-24-2015), Lonewolf (02-07-2015)
Old 02-06-2015, 02:26 AM   #186
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
shows what a great car this is when you have all tose maerican muscle fanboys buying subru. Sure to win the girls when thy notice your sporty car is more sporty only with the hood up. how is that a practical place to mount it? id rather see it behind the driver
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline   Reply With Quote
Old 04-05-2015, 06:56 PM   #187
Suprastar
Drives: no
Originally Posted by Accurate Race Shop View Post
Right now everyone is using new engines for the swap in time once these cars get a little older they will start using a rebuilt one and the price will drop dramatically.
Sent from my Q10
That's one of the better aspects of the LSx V8s, they don't wear to the point of needing rebuilt, and there's no need to waste money on stroking even the 6.2L, though it is easy if you have mega $$. To date I've owned a half dozen of these engines, all well over 100,000 miles, and all still had the crosshatch, from honing, easily visible in all of every cylinder. Sure, most need valveseals, but that's part of installing the set of new Z06 or Comp 26918 springs for whatever cam you like.
Do the seals, the thing's ready for another 100,000 miles.
The iron-block truck versions are plentiful and therefore cheap, only 65 # heavier than aluminum-block, and 4.8L versions are going for $300, 5.3L are around $500, and 6.0L starts at $800.
'07-up have better heads and beefier rods, but most are 58x rather than 24x (crank reluctor) But don't use pre-'01. In fact, every one of mine have been '01s. The early 4.8s are good to 7500 RPM with appropriate valvetrain upgrades. All are safe past 6500 RPM. Try to get #799 or #243 heads if getting a later 5.3, and the later 6.0L heads may have the rectangular-port (intake) heads that flow better but reduce off-idle torque. That's the way to go for cost-effective NA power.
Combining LSx power with 4-cylinder gearing is a fail, plan on a T56, or a T5-WC from an '88-'92 Camaro V8 if NA 4.8L, ( TBI was 0.63:1 fifth, TPI was o.73:1, but 0.59:1 and HD 0.80:1 both exist) and for differential gearing, if your Toy / Sub diff doesn't offer a ratio around 3.5:1, then plan on an aluminum Ford 8.8" from a mid-'00s Shelby Mustang Cobra. You'll never break that. Ratios range from 2.47:1 well into the 5s. And more different types of traction diffs than anyone could want.
Any pure-stock LSx can happily pull a 1500 RPM cruise at 65 MPH in these cars, and the T56 offers a 0.5:1 sixth to help. You can combine that with either a 2.66:1 or 2.97:1 first, try for a combined first gear in the 9.00:1 - 10.00:1 range, for rear tires around 26" overall. If you're closer to 25", then calculate accordingly. Bigger cams will need more RPM at cruise, even after a good dyno-tune.
That's part of why I like the '01-'06, they use the #0411 PCM that was figured out long ago, so tuning is cheap and easy, but it can do anything and everything you really need.
Suprastar is offline   Reply With Quote
The Following 13 Users Say Thank You to Suprastar For This Useful Post:
@Art_Mighty (11-19-2016), Accurate Race Shop (11-06-2015), Bonburner (04-27-2015), cf6mech (04-27-2015), civicdrivr (04-13-2015), Dadhawk (04-06-2015), everythingsablur (09-15-2016), GotBRZ1691 (05-18-2015), Jesse36m3 (04-08-2015), juliog (05-17-2015), misooscar (04-05-2015), mkivalex (04-08-2015), Valentino (05-14-2015)
Old 04-08-2015, 02:49 PM   #188
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Great post!
mkivalex is offline   Reply With Quote
Old 04-27-2015, 12:55 AM   #189
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Sub
SON1C is offline   Reply With Quote
Old 05-13-2015, 07:37 PM   #190
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Another victim...
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 8 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
53Driver (05-14-2015), BirgeyT1 (05-13-2015), cf6mech (05-15-2015), Dadhawk (05-14-2015), Deadpool_25 (05-15-2015), kch (05-14-2015), NOHOME (05-14-2015), xxscaxx (05-21-2015)
Old 05-15-2015, 10:38 AM   #191
Deadpool_25
Drives: BRZ Limited
Originally Posted by Jesse@JDLAutodesign View Post
Another victim...
Saw this yesterday when I stopped by to pick up my header. That car is sexy from the top or bottom. I know what I'm doing if I ever blow up my FA20. Lol. Nice to meet you, Jesse.
Deadpool_25 is offline   Reply With Quote
Old 05-15-2015, 12:41 PM   #192
BRZR1
Drives: v8 BRZ
Looks like an octupus is hiding in your engine bay!
BRZR1 is offline   Reply With Quote
Old 05-15-2015, 01:42 PM   #193
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Wouldn't the header melt all the plastic stuff beside it?
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 05-17-2015, 01:31 PM   #194
inertia
inertia's Avatar
@Jesse@JDLAutodesign any more info on that build?
inertia is offline   Reply With Quote
Old 06-24-2015, 11:27 PM   #195
Fernan Andrade
Fernan Andrade's Avatar
Drives: FRS
@AZFA20 Did you upgrade your heads and cam? I am trying to decide which heads, cam, and intake to go for.
Fernan Andrade is offline   Reply With Quote
Old 06-27-2015, 12:53 AM   #196
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I have TrickFlow heads, FAST 102mm intake manifold, TrickFlow cam, and a lot of other go fast goodies all on the shelf waiting to go in soon.
Really it all depends on your budget and goals as far as recommendations go.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Engine Swap: Which Would You Choose!?? EvoFanatic Engine Swaps 149 08-08-2017 03:34 AM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 09:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
