Old 10-23-2014, 07:51 PM   #15
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Originally Posted by TylerLieberman View Post
I have 18x9.5s with 265/35s.
The setup is a bit heavier than the stock setup I'm sure but the car grips and drives much better now between that no the alignment changes.
All I need now is more power lol
Haha time for that 2jz engine swap lolol. But it feels better huh? How do launches feel? And hard turns?
WallsAndFoundations is offline   Reply With Quote
Old 10-23-2014, 09:32 PM   #16
N234
N234's Avatar
Drives:
Originally Posted by WallsAndFoundations View Post
Can you explain please?
Rotational inertia increases proportionally with mass, but increases exponentially by the distance from the center of the wheel.
With identical weight,a smaller wheel is easier to spin than a larger one.
You're lightweight 18s need to be lighter to compensate for the larger diameter, and even lighter to reduce rotational inertia.
Someone might correct me but:
I = m × d²
N234 is offline   Reply With Quote
The Following 2 Users Say Thank You to N234 For This Useful Post:
calmtigers (10-31-2014), cdrazic93 (10-24-2014)
Old 10-23-2014, 09:38 PM   #17
8R6
8R6's Avatar
Drives: FRS
Really? I feel like 10 pounds of rotational weight being taken off the wheels would make a difference. .
yeah it would make a difference if there were no tires involved. wider wheel, wider tire. take weight off wheel, add weight with tire. offset of the wheel matters too along with the width, like someone pointed out.
8R6 is offline   Reply With Quote
Old 10-23-2014, 10:41 PM   #18
WallsAndFoundations
Drives:
I = m × d²
I kinda understand I suppose. but would an extra inch really matter?
Old 10-23-2014, 10:42 PM   #19
WallsAndFoundations
Drives:
Why does offset matter? I'm curious and uneducated so please help me understand.
And that's true, how much do the stock tires weigh anyways?
Old 10-24-2014, 03:13 AM   #20
mfbmike
Drives: 2013 FRS, 2008 R32
Not too grippy? I do kind of like a little bit of tail-happynesz
I can kick the rear end out with 18x9.5 volk te37sl's and 265/35 Michelin PSS'
lol. I wouldn't worry about the car losing it's handling characteristics. With that being said, much more grip over stock.
Acceleration will suffer a bit (trivially, really) with such a wide wheel (and heavier tire) but you already mentioned a much more conservative wheel size above.
With that being said, going from the slightly heavier Enkei NT03's I had in the same size, to the TE37's, the weight difference was definitely noticeable in my opinion.
oh and shameless plug, I'm also selling my set.
http://www.ft86club.com/forums/showthread.php?t=75768
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
WallsAndFoundations (10-24-2014)
Old 10-24-2014, 10:38 AM   #21
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
How much power does your car have? If you like the "tail-happynesz" of the car, you will not be happy with adding that much extra width, weight and grip to the rear.. The rims may be 2 whole pounds lighter /s, but the rubber to properly fit on them will make this set up weigh more than stock.
Old 10-24-2014, 10:41 AM   #22
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Offset is basically what determines how far from the hub your rim will sit. Higher offsets will pull the rim into the car, lower offsets will push it out from beyond the wheel well.
I believe the stock offset is around +48? I forget. and that is on a 17x7 wheel. So that is why the wheels appear sunken inside of the wheel well.
Old 10-24-2014, 12:00 PM   #23
WallsAndFoundations
Drives:
Nooo, that's not what I meant, I know what wheel offset is (thank you anyways though!), what I meant is why does wheel offset matter for how a wheel feels while driving.
Old 10-24-2014, 12:04 PM   #24
WallsAndFoundations
Drives:
Oops, sorry haha, keyboard is messing me up. My car is stock minus a tomei type80r, a lightened crank shaft pulley, and a trd performance air filter. It's not turboed by any means but if I'm throwing down the throttle around a turn I can feel the rear wheels take the car. I don't really wanna get rid of that to be honest. I realize adding more rubber will add to the weight, do you think I just get a tire that isn't stupid grippy so I can still have a bit of tail-happy?
Old 10-24-2014, 12:07 PM   #25
WallsAndFoundations
Drives:
I keep hearing about the Michelin pss! I went to Costco and the dude recommended the AS3s over the pss and upon coming to the forum a lot of people have them and like them, what're your thoughts? it's good to know you still feel the spin! Those wheels you're selling are mint, I just wish they were 18x8.5!
Old 10-24-2014, 12:56 PM   #26
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I would really recommend the AS3 as well.
Old 10-24-2014, 01:44 PM   #27
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Too Grippy? Is that even possible? I have MPSS 245/40/17s. I have a stock engine, and I can still spin em. I have an auto too!
Question: 225/40/18 or 245/35/18 on Volk TE37SL 18x9.0 + 45? brianlo622 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-07-2012 09:40 PM
