| Software Tuning Discuss all software tuning topics. |
#57 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
Edit: Did some skimming of the logs prior to scaling and the new logs after scaling and came to a conclusion: Now instead of being pegged at 11.25 from 3500rpm wot and up, now it's only pegged at 11.25 above 5800rpm wot! This is a very noticeable improvement in the logs. I could swear my butt dyno picked up a few hp, but I'm a skeptic.
Also found that the new scaling in the VGI utility wants a lower mass flow per volt above around 3v this time, not 2.5. It is indeed slowly correcting the maf curve log by log. I believe it cannot make a full correction all at once simply because my AFR is off the charts rich for the stock 02.(stock 02 is blind below 11.25:1 with OFT maps, probably for good reason) If I had a wideband 02, the VGI scaling utility could probably see exactly how much it was off and pull off a near perfect correction with one log. Last edited by BuBlake; 10-21-2014 at 06:02 PM. |
#58 | |
Drives: AT 2013 BRZ Limited
Quick question...I'm currently collecting logs for my first new scale. Should I just keep building up data using my current tune or should I reflash everytime VGI utility rescales the MAF then get logs with the new scale to be put into the VGI utility? I'm guessing you are doing the latter as the stock O2 isn't good enough? I started out by using the Perrin 2.75in scale hehe, it leaned out the AFR a bit, but after 4.5k-5k RPM it goes back to 11.25 =/
'13 BRZ (sold)
'17 STI Last edited by ray7792; 10-21-2014 at 07:11 PM. |
#59 | |
| The Following User Says Thank You to BuBlake For This Useful Post: | ray7792 (10-21-2014) |
#60 | |
Drives: FT86
Use the front O2 for your calculations its good enough for NA stuff just no good once it gets outside its narrow range so no good for FI. Last edited by steve99; 10-22-2014 at 08:51 AM. |
#61 |
Drives: Toyota 86 GTS
If we buy an AEM will it just plug in and work without the extra controller, etc?
#62 | |
Drives: FT86
sorry @Wayno stuffed up its calibrated for a Bosch Wideband o2 sensor (LSU4.2) & controller http://www.ft86club.com/forums/showthread.php?t=61724 Last edited by steve99; 10-22-2014 at 02:13 PM. |
#63 |
Just went out for a test drive with the latest scale(this is my 3rd rescale using VGI) and holy crap, it feels just as fast as it did on E85 with 93 now!! Checked the logs and it is never pegged at 11.25... Never! 11.6:1 at 7400rpm! It is ever so slightly on the rich side of the targets(11.6 measured when 12:1 commanded). I'm tempted to just leave it there and swap the scale over to an E85 map and see what happens, but now I want to see if I can get it nailed first. Finally I feel the full potential of OFT!
Thank you! Thank you! Thank you!Ran a 14.7 quarter on e85 last time at drag strip when pegged at 11.25 anywhere above 3k, so will be interesting to see the numbers next time I go... First just need some new tires. :/ |
#64 | |
#65 |
http://www.datazap.me/u/tuner1b/pret...s?log=0&data=1
4th scale and I'm content. I think <2v may be off a bit, but it's right on target when under WOT at any RPM. If I didn't know any better, I would have thought someone slapped an electric supercharger on my car or something because it is much, much snappier. Can't wait to try this scale with an OFT E85 stg 2 tune now. Thank you @steve99 and @Kodename47 for the great support. I was too stubborn to learn this on my own. haha |
| The Following User Says Thank You to BuBlake For This Useful Post: | steve99 (10-24-2014) |
#66 | |
Drives: '13 BRZ Ltd
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
| 2000 mile review, road trip to Road Atlanta & a chat with Randy Pobst. | Mtechnik | BRZ First-Gen (2012+) — General Topics | 0 | 08-03-2012 11:07 AM |
