Old 10-20-2014, 09:48 PM   #43
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Based on some of the feedback on this thread, how many would be in favor of a "Showroom Stock" class (OEM crash bolts and stock treadwear and higher), and modifying the current stock class to have less restrictions (Also renaming it)? If we want a "budget" class, stick to SS.
raul is offline   Reply With Quote
Old 10-20-2014, 10:43 PM   #44
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
I also thought about putting a class between stock and street, or just raising the stock class points, but that defeats the purpose of stock class. While it seems like a good idea for people with like 1 point instead of .50 to still be in stock, it just doesn't seem worth it.
bkblitzed is offline   Reply With Quote
Old 10-22-2014, 01:14 AM   #45
juliog
juliog's Avatar
Drives: 86
Can I run 235F 255R on aftermarket 17x9 wheels in Stock Class... in the S2K Challenge series?
juliog is offline   Reply With Quote
Old 10-22-2014, 02:42 AM   #46
CSG Mike
CSG Mike's Avatar
if you really wanted to...
juliog (10-22-2014)
Old 10-22-2014, 10:58 AM   #47
D K
Stig's dark passenger
How come so many people are against alignment bolts?
It seems that easy, inexpensive mods should be welcome and encouraged.
D
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
CSG Mike (10-22-2014)
Old 10-22-2014, 07:38 PM   #48
THEmailman
Drives: Raven 6MT
D
I dont think anyone here is against bolts.....they are already free. The question is whether camber plates should take points since they provide a much greater adjustment
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 10-22-2014, 07:43 PM   #49
bkblitzed
is better than you
bkblitzed's Avatar
How much do camber plates give on stock struts?
Old 10-22-2014, 07:59 PM   #50
THEmailman
Drives: Raven 6MT
They've given me approximately 3 degrees.....plus I have bolts to get me another 1
Old 10-22-2014, 08:01 PM   #51
bkblitzed
is better than you
bkblitzed's Avatar
Oh wow. Might have to buy some to get me near 2.5
The Following User Says Thank You to bkblitzed For This Useful Post:
Old 10-22-2014, 08:08 PM   #52
CSG Mike
CSG Mike's Avatar
They generally give a 3 degree range.
RaceSeng stuff is awesome.
Old 10-22-2014, 08:58 PM   #53
bkblitzed
is better than you
bkblitzed's Avatar
Do you know anyone that sells camber plates that are fully sealed for the bearings?
Old 10-22-2014, 09:00 PM   #54
CSG Mike
CSG Mike's Avatar
Not that I'm aware of...
Old 10-22-2014, 09:01 PM   #55
D K
Im not a rules guy since @CSG Mike is doing a good job at it already - but really, any mod thats less than a few hundred bux should be as close to free as possible.
You want to onvite as many people in as possible and lot of these guys arent gonna build the car to a set of rules. They just want to race what theyve got, so if you make it too complicated and unattractve, theyre just gonna turn away.
Who gives two fucks about a mod that is 1/16th of a second faster on a clear day at sea level?
Focus on getting more people to sign up instead.
The Following 3 Users Say Thank You to D K For This Useful Post:
AyJay (10-29-2014), CSG Mike (10-22-2014), raul (10-23-2014)
Old 11-20-2014, 11:49 PM   #56
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
I originally posted this question in the NorCal Subforum 86cup thread but it may be more appropriate here for the people crafting rules and point values.
I'm curious about the thought process behind the e85 tune points. I think we can all agree that an e85 tune on a NA car is not as effective as on an FI car. Therefore, I'm curious if that was taken into consideration when assigning what appears to be a one-size-fits-all point value.
Ultimately you won't find me lobbying for changes but it is helpful for everyone if this stuff is sorted early on.
AyJay is offline   Reply With Quote
2014-2015 Winter Tire & Wheel Discussion Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 153 07-02-2016 09:45 PM
Discussion: Did the 2015 Subaru WRX get nudered because of numbers? FRSFrank Other Vehicles & General Automotive Discussions 27 05-28-2014 10:33 PM
2014 FT86CUP rules discussion CSG Mike Tracking / Autocross / HPDE / Drifting 34 11-18-2013 04:15 PM
Berk Technology FT86Cup Rules/Classing Discussion CSG Mike Southern California 3 02-22-2013 04:11 PM
