View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 10-09-2014, 01:12 PM   #4537
Shady195
Drives: '13 10 Series FRS #1203
So finally after having my car for a few months i decided to give something a try to quiet the crickets..
Picked up some Lucas UCL and after a fresh fill and 20 miles the crickets are just about gone. Fuel system overall seems much quieter.
Going to see if it comes back after the next fillup without adding more UCL and see how often it needs to be done.
Upstate NY with 93 octane gas BTW
Shady195 is offline   Reply With Quote
Old 10-22-2014, 01:56 PM   #4538
Zemshin
Drives: 2015 Scion FR-S
2015s still have Crickets
I've had my 2015 FR-S for about 3 weeks now. Let me start by telling everyone that this crickets are still here on the newest model. Started to hear them after I filled up my 2nd tank, around 300-350 miles.
I tried Lucas UCL with fresh tank of gas from Shell, did not help a bit.
Then I tried TCW3 with the next tank from Chevron, did not help a bit.
I don't have any gas station that are E0 around me.
Then I decided to take it to the dealership, got there and was told that they are aware of this issue and to bring it in for them to take a look. Couple of days later I brought it in and was told it will take about 3 hours to fix, took a shuttle home. 2 hours goes by and I get a phone call from the service adviser telling me that there is nothing they can do, he spoke to his mechanic and the mechanic said its working as intended. I told him that does not sound right and replace it anyway, his reply was sure if you pay for it... Then he said that my model does not have a TSB for that issue.
So the moral of the story is they still have not fixed the crickets.
Zemshin is offline   Reply With Quote
The Following 3 Users Say Thank You to Zemshin For This Useful Post:
Bristecom (12-05-2014), Marrk (10-22-2014), Tcoat (10-22-2014)
Old 10-22-2014, 02:11 PM   #4539
Were all the tanks of gas ethanol free?
In the 4 months I have had mine I only had crickets for one tank worth and that was when I was too low and had to put some 10% in it.
Went right away once I used all that gas up.
You are correct though they will not change pumps on anything made after about Feb 2014.
It doesn't really do any good anyway according to most of the posts here so why bother.
Old 10-22-2014, 02:20 PM   #4540
HunterGreene
Hail Magnet
HunterGreene's Avatar
Could be the colder temperatures in the NEO area, but I haven't heard the crickets in a few weeks.
It has priests in it?
Old 11-17-2014, 10:25 PM   #4541
beatgenie
beatgenie's Avatar
Bought a 2015 FR-S about 6 weeks ago and just hit 900 miles....have not heard any cricket noises at all. Although I rarely drive without music. How noticeable is it when the music is on at a moderate volume? Also how often does the noise appear? So maybe tomorrow I can drive for a while in silence and listen to see if I can hear anything.
beatgenie is offline   Reply With Quote
Old 11-17-2014, 10:58 PM   #4542
slisgrinder
Drives:
It seems that if i push it a bit it will start to chirp. Easy driving and staying under 2500 rpm seems to be the trick
Sent fabulously from a fabulous phablet in the hands of a fabulously dressed phantom with a fabulous phone...which is a fabulous phablet.
slisgrinder is offline   Reply With Quote
Old 11-18-2014, 09:30 AM   #4543
HunterGreene
Hail Magnet
Depending on the temperature down there, you may not hear anything at all. And it isnt too noticeable with the windows up and music on, slightly moreso with the music off, and most noticeable if you have walls on one side or both of your car (like a drive-through).
Old 11-18-2014, 10:15 AM   #4544
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Sit in a drive-thru with your windows down and music off. But really, if you have to go to the effort, it's already not worth it. You aren't noticing it now, you aren't having a problem.
Even if you do hear it, it's still not a problem. Annoying? Yes. Is there a resolution? Yes. It's called E85. But hell, my 3rd and current pump chirps even with E85.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-18-2014, 12:02 PM   #4545
HunterGreene
Hail Magnet
I don't think thats technically a "resolution" then.
Old 11-18-2014, 12:41 PM   #4546
2point0
2point0's Avatar
Well, no, not really. But it does have a good chance to make the stupid noise go away.
Old 11-18-2014, 01:15 PM   #4547
HunterGreene
Hail Magnet
True, but not really worth the expense of converting to an E85 setup *just* to get rid of a noise, at the expense of gas milage (although an appreciable boost in power). Secondly, like E0, E85 is only sold at a few gas stations in the Cleveland area, last I checked.
Did I also mention that the crickets are subdued in the cold?
Old 11-18-2014, 01:30 PM   #4548
2point0
2point0's Avatar
Hot or cold doesn't seem to make a difference for me. Keep in mind, my temp range is around 40s - 100 F (taking into account the whole year). Maybe it's just not cold enough to matter?
I'm not trying to debate whether E85 is a solution for everyone. I was just making a half-bitter comment because there's really no fix and wasting time at the dealer multiple times over the last 2.5 years has changed nothing. I happen to have an OFT and nearby E85 pumps, but even that sucks because of the cold start issues.
When I read these chirping threads now, I just see this pic in my mind...
The Following User Says Thank You to 2point0 For This Useful Post:
Tcoat (12-01-2014)
Old 11-18-2014, 01:38 PM   #4549
HunterGreene
Hail Magnet
The temperature, as I have observed, needs to be in the mid-30s or lower for temperature to have effect. And I didn't notice the sarcasm in your earlier post, my bad.
The Following User Says Thank You to HunterGreene For This Useful Post:
2point0 (11-18-2014)
Old 12-01-2014, 12:42 AM   #4550
swarb
2015 BRZ. Today I got the crickets @1,350 miles, 5th tank of gas. I finally feel like I am part of the club.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
