Old 08-29-2014, 04:57 PM   #1
Fastbrew
Drives: 2014 Pearl White BRZ
Southbend Stage3/2 Endurance on order
I have been having issues with a Comp Clutch Stage 3 segmented ceramic and I have decided to just rip the thing out and replace it with a different brand.
I searched high and low and did my research on many different brands.
I ended up chosing SB because of their great reputation and their attention to detail.
Prior to placing my order - I took the opportunity to discuss my options.
Here is what they put together for me:
Their Stage 3 endurance clutch with a stage 2 flywheel. Why? It's heavier and this is an FI DD/Street/AX/track car. The fact that the flywheel is not super light should make it more like the OEM DMF even though it's a SMF. It should keep spinning rotational mass a bit to make it a bit more well mannered - especially in situations like being on a hill, in stop/go traffic. I think it's a really nice option and I am glad they suggested it.
It ran $850 for the clutch/flywheel/bolts etc. Should hold up to 450 ft lbs of torque and not produce much chatter.
We will see in about two weeks.
Hopefully I have chosen a "knock it out of the park" combo.
Chime in if you are running a SB clutch too! I would love to hear how yours is working out.
Fastbrew is offline   Reply With Quote
Old 08-29-2014, 05:00 PM   #2
Fastbrew
PS - Just got the shipping notification - They put this combo together for me in less than two hours and got it into UPS on a Friday afternoon before a holiday weekend. Great customer service so far!
Old 08-29-2014, 07:45 PM   #3
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I've not run one on an FRS/BRZ yet (they were not quite ready when I was in the market for one), but I have one of their clutches (what would be considered their Stage 2 Endurance now) on an SR20 swapped 240SX I have. It is a great clutch, easy driving, and has put up to a ton of abuse so far.
FrX is offline   Reply With Quote
Old 08-30-2014, 06:46 PM   #4
Fastbrew
I also placed an order for some Pentosin (MTF2) SAE GL-4 75W-80 which I am going to fill up with on this pass. Adding some stainless clutch line as well.
Old 10-21-2014, 11:40 PM   #5
Fastbrew
Quick bump to tell the rest of the story.
I had the SB installed and I drove it like a granny for about 750 miles. This was very difficult for me. I didn't boost it once. My car is making 285WHP and almost the same in torque now so this was such a bummer. But - I did it. Once I hit 750 miles of mostly city driving, I started to boost and shift a bit harder. I gave it another 100 miles and then started driving like normal - which is pretty aggressive on the gas/gears
Verdict? I love this clutch. It was a perfect choice for me and I am really glad I switched. It behaves perfectly for DD and it holds the torque of my AVO setup. Almost no chatter and what is there is a deep sound. It does not chatter at idle with or without the AC in my case. It comes with a flywheel and I chose the stage 2 because I wanted a heavier flywheel for DD manners.
The car engages smoothly. It is not too heavy on the foot. I would definitely got this route again. Now - to see if it holds up. But - I have heard great things about carbon/kevlar durability so I am not too worried.
So - a win on the SB. Nice company to work with as well. I believe the import clutch guy is named Dave so give him a buzz if you have questions.
Old 07-17-2015, 08:08 PM   #6
rixter145
Sleep Chomper
rixter145's Avatar
Hey man, how does the clutch feel after some time later? I may be looking to get the same
rixter145 is offline   Reply With Quote
Old 07-17-2015, 09:06 PM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm probably picking one up soon myself. I think they've changed the flywheel, as it's now 14.2 lbs. I believe it was 18 lbs prior.
kmbkk is offline   Reply With Quote
Old 07-17-2015, 11:07 PM   #8
Fastbrew
I love it. I am adding flex fuel and running e-85 starting about Aug 3. That will put my car at 350WHP. I will tell you how it works out but the stage3 clutch / stage 2 flywheel is awesome for DD/Fun. Best of both worlds IMO. I don't think I will ever use another clutch brand again. Just remember - follow the break in to the T and baby it for hundreds of miles (No boost, launches, etc). No fun but the result is awesome so far!
Old 07-20-2015, 02:31 AM   #9
rixter145
Sleep Chomper
rixter145's Avatar
Awesome. Yeah I am running at 240 whp with AVO turbo and still a catted OP with stock clutch.
Going to get catless and new clutch *the south bend one* and push it to 300 whp too
Old 07-20-2015, 03:51 AM   #10
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
I have southbend 6 puck and I launch the fuck out of it, I preload the drivetrain by using the handbrake and slipping the clutch and then lowering handbrake and slipping it out. Its chattery as fuck but not a bad clutch to drive on
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 07-20-2015, 08:25 AM   #11
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by #maverick# View Post
...I preload the drivetrain by using the handbrake and slipping the clutch and then lowering handbrake and slipping it out...
I've only been driving a manual for 14 months now but...why would you do this? This just sounds like you're trying to destroy your clutch?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-20-2015, 08:39 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
From what i know something like that should be done only in rare ocasions like starting to drive when car standing uphill or partially on ramp, to not roll backwards, but that's about it, in all other cases it's excessive clutch wear with no purpose. When car is stationary on leveled road, keep leg on brakes. Starting to go - put legs on clutch & gas. I see no practical need for any .. "drivetrain preloading".
Old 07-20-2015, 03:39 PM   #13
#maverick#
#maverick#'s Avatar
Haha Im sorry I didnt mention, this is at the drag strip when launching the car, helps reduce wheelspin as well as the likelyhood of breaking shit.
Old 07-20-2015, 04:02 PM   #14
motoxman
motoxman's Avatar
Drives: 2013 fr-s firestorm red
A Pre-loaded drivetrain for launching is a desirable thing. It reduces static drivetrain shock (from stand still) and keeps you from braking things on a hard launch... think about it this way, your car is setting still while you are revving the engine in anticipation of a hard launch for a drag race. If you just let off the clutch while setting there, all of the "slack" in the drivetrain is taken up in a split second causing a huge thrust load on the gear faces and magnitudes higher shock load on the transmission bearings and case as well as the driveshaft and rear diff. IF instead you are revving the engine with a slight load on the drivetrain (accomplished by letting off of the clutch to the point of partial engagement while holding the emergency brake so the car does not move forward) and let off of the clutch, at time of launch the drivetrain is pre-loaded (all the "slack" is taken up) and the shock loads are MUCH lower. This greatly reduces the chances of breaking parts in the drivetrain and aids in a much better and controlled launch.
Hope this info helps...
Note we do the same thing for Drift and for Grip racing. Smooth throttle transitions and gear changes are paramount to maintaining proper traction (or spin if drifting) control when launching or cornering.
motoxman is offline   Reply With Quote
Essex endurance brake kit. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-07-2016 01:32 PM
Stock Suspension Endurance JDogg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-14-2014 02:33 PM
24 Hour Endurance Race Reliability Wes B. Engine, Exhaust, Transmission 30 09-14-2012 12:50 PM
frs endurance race frs FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-26-2012 09:53 PM
