Old 10-20-2014, 06:49 PM   #1
Oakhenshield
Oakhenshield's Avatar
Drives: ahh its blue?
Question and Confused about installing HID
so i bought this [ame="http://www.amazon.com/gp/product/B00D9D4EV6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1"]Opt7 HID Kit[/ame] and im trying to install it i did first the passenger side and i can conenct the Positive (to the battery), Negative (anywhere on my car), to the ballast, to bulb and to stock harness
but when i go to the driver side i got confused because i can only connect the bulb, ballast and a connector from the relay (the long one)
my question here is where do i connect the stock harness?
am i missing a piece from the kit?
plus i have an extra connector that looks like has a battery or something (6th picture from the link) that im not sure where to connect them
any help would be appreciated
btw, if this isnt the right place to ask feel free to move
Oakhenshield is offline   Reply With Quote
Old 10-20-2014, 06:55 PM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
[ame="https://www.youtube.com/watch?v=iKuST9JuAZs"]2013 Scion FR-S HID Installation (with relay) - YouTube[/ame]
Old 10-20-2014, 07:02 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
to keep blinding to a minimum, please bend down the "squirrel finders" in the projectors
Old 10-20-2014, 07:14 PM   #4
sinny
The Stampede
Drives: 2013 FRS
hi, i got the same opt7 HID kit too and just installed it 2 days ago, you dont need to use the extra stuff that came with (the pre-setup relay, and the 2 capacitor) you only the need stuff inside the box. 2bulbs, 2 ballasts, and the 2 cable connectors that go from the ballasts to your car's headlight connectors. very simple.
note* just match the color of the car's connectors with the ballasts' connector, there are 2 notches on the connector, one side is square which is hard to push into the car's female connector, the other side is like a triangle that can be push in easier, but it is the square one that goes into the snap hole on the car's female connector, you will see it and get what im talking about once you get there, i connected it the wrong way the first time... didnt mess up anything though.
sinny is offline   Reply With Quote
Old 10-20-2014, 07:15 PM   #5
Oakhenshield
Originally Posted by WhiteFRS69 View Post
ok you got me really confused.. the ballast on the driver side was already connected to the stock and to the bulb and the guy said on the vid that the long wire needs to connect to the ballast but the ballast has the bulb and the stock.. unless theres a 3rd connection that im missing
a whaat?
Old 10-20-2014, 07:18 PM   #6
Oakhenshield
well i know all the connections im just confused because when i did the driver side theres like 1 missing connection.
Old 10-20-2014, 07:50 PM   #7
continuecrushing
a whaat?
look up squirrel finder on here...its a little metal tab inside the projector housing, and bending it down when installing HID's can help cut down on glare that on coming traffic will see.
Has no effect on operation of the hid, its just to help prevent blinding people!
Old 10-20-2014, 11:07 PM   #8
sinny
The Stampede
Drives: 2013 FRS
This is the ballast, there are only 2 lines coming out of the ballast. one goes to the bulb with 2 small connector(blue line), the other is jut a female connector where you have to insert the male adapter into it(the green line)
here is the bulb and the car's connector line, as you can see, the green line just goes straight from the ballast to the car's connector line via a male to male adapter that comes with the kit. and the blue line connects the ballast to the bulb.
again, you do not need to use the pre-setup relay nor the 2 capacitors that came with the kit but is packed outside of the opt7 HID box
Old 10-21-2014, 08:49 AM   #9
Oakhenshield
Dude youre my hero nobody told me that i can just connect them directly like power > ballast > bulb on both sides lol im still looking for a nice place to stick the ballast though..
now i just need a pairing light for the Hi beam and some switchback, any suggestion?
Old 10-21-2014, 01:03 PM   #10
sinny
The Stampede
Drives: 2013 FRS
glad i can help
(if you had read my first post clearly, the first 1-2 sentence at least, then i wouldnt need to take all the pictures) haha
for high beam/Daytime running light, im thinking of getting a yellow bulb - 2500k or 3000k
Old 10-21-2014, 06:13 PM   #11
Oakhenshield
glad i can help
sorry about that didnt read it all i was just skimming because im about to go to work..
im thinking to get something like 8000k
more confused Fred Flintstone Engine, Exhaust, Transmission 8 10-16-2014 11:33 PM
Installing Overpipe Question TONY_BRZ Engine, Exhaust, Transmission 13 03-19-2014 12:46 AM
FT-86.....GT-86.....86.....I'm so confused! Hounddub Scion FR-S / Toyota 86 GT86 General Forum 9 11-28-2011 10:52 PM
