Old 10-20-2014, 04:57 PM   #15
wparsons
wparsons's Avatar
Originally Posted by slava View Post
Then what are the right reasons nerd?
Love how all the guys with mm posts think they're god and decide to shit on everything that goes against their opinion.
If you don't think this is cool, then we're clearly not on the same page.
Please tell me the owner of that Weld car is a moron.
We're CLEARLY not on the same page then.
You're looking at spending (to do it right) $3500+ for sound, a tiny bit of power and to have it look cool. Forgetting the minimal power increase (you'll be hard pressed to find good gains on stock internals from ITB's), you're essentially paying that much to look and sound cool. Spend another $1500 (for turbo or supercharger) and you could have A TON more power, that is actually usable.
I'm not "shitting on it because it goes against my opinion", I'm telling you that running ITB's to look and sound cool is the biggest waste of money out there. You lose driveability, tuning is MUCH harder, etc, etc, etc. Might as well put on a 5 lb flywheel and 3 puck clutch while you're at it to make it even worse to live with.
The right reasons (IMO) for ITB's are better throttle response, and ability to better tune (despite being harder) each cylinder. To really make it worth your while you'll want higher compression, bigger cams, head work, etc. You'll be $15k into the engine/bolt ons/tuning in no time.
As for that car pictured, that's definitely a show car... I bet it rarely (if ever) actually gets driven. If that's what you're after, enjoy wasting the $3k+ to do it. Plus, look at the horrible path the manifolds take after the TB's. They should be dead straight shots, not snaked all over to make it look cool.
flickr
Old 10-20-2014, 04:59 PM   #16
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
In my opinion, the only reason why you would go ITBs is for show car or if you consider custom fab work a hobby.
That engine bay is from a dedicated show car. The intake manifold, fuel rails, and ITB's all look custom. I would wager that a similar setup would cost close to $10,000 if you were to pay someone to make it for you, and that's not even the custom head and cam work you would need to get any real power out of it. After the dust settled, I would guess you would be left with a $15,000 bill and a car that makes power in the low 200's at the wheels.
Like i said tho, if you consider custom fab work a hobby, then have at er' and I hope it turns out like you want. If you just want something unique and you don't have an unlimited budget, this might not be the way to go about it.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
wparsons (10-20-2014)
Old 10-20-2014, 05:00 PM   #17
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
20v 4ag's came stock with ITB's, as did some M3's, as did the RB26. to the best of my knowledge, people manage to drive those on the street.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 10-20-2014, 05:05 PM   #18
gramicci101
Off Topic
And people convert Hondas to ITB. It's not impossible to do; it's just very very impractical for this chassis. It's a ton of work and a ton of money, or no work and three tons of money, for not a lot of gain.
Old 10-20-2014, 05:10 PM   #19
SomeoneWhoIsntMe
right. it's a stupid fucking idea, but not because OMG ITB'S ARE COMPLETELY UNTUNABLE AND IT WILL NEVER DRIVE RIGHT EVER BECAUSE ONLY RACECARS HAVE ITBS
it's just because the DBW, stock EMS, and the boxer layout means you'll have to give your left nut to get ITB's on this motor, where on a honda you can just buy a cheap adapter plate and run toyota ITB's and adjust the TPS and you're done.
Old 10-20-2014, 05:15 PM   #20
gramicci101
Off Topic
Like wparsons said though, it's not untunable, just more difficult to tune. On the other hand it allows you the flexibility of independently adjusting each cylinder, which is good.
I agree that it would be a raging bitch to do properly on this engine. And very expensive. Old Porsches had the ITBs going straight down into each cylinder, but they also had individual carbs on them, too. Whichever way you want to do it, you're not going to get it done with a 2K budget for an ECU.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 10-20-2014, 05:21 PM   #21
SomeoneWhoIsntMe
you could probably run it on the stock ECU with a tune if you went with a setup like the one pictured where the ITB's all share one shaft, if you mounted a stock throttle motor to the end of it, then ran a plenum to a stock MAF. no idea if that'd fit under the hood though, probably not.
you also probably can't fab that unless you're good at CAD and have access to an NC machine shop, and machine time is free. but if that was the case, you wouldn't be asking about it on ft86club
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
Old 10-20-2014, 05:52 PM   #22
wparsons
wparsons's Avatar
All with plenums (with a plenum you can run MAP or MAF sensors MUCH easier), and all with factory tuning for driveability. Tuning a standalone for OEM like driveability without ITB's is a huge task, people REALLY underestimate just how much work it takes to make an engine behave in all daily scenarios. Tuning for WOT is a piece of cake in comparison.
Now add the complexity of ITB's, and good luck.
I would bet you're looking at a bill of over $1000 from the tuner alone to get a reliable, daily driveable tune on ITB's. Add the ECU required, plus all the hardware for the actual ITB's and you're getting into a VERY expensive build.
flickr
Old 10-20-2014, 07:04 PM   #23
Turdinator
Señor Member
Turdinator's Avatar
OP, I think you will struggle with your budget to get a workable ITB setup on the FA20. That said, i would love to be proven wrong. If you can do it you would become a god amoungst the NA crowd here.
Hydra EMS and MOTEC are I believe your best options at the moment. Talk to @Element Tuning if you are serious as they have a good knowledge of both our engine and the Hydra EMS.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
slava (10-20-2014)
Old 10-20-2014, 07:34 PM   #24
slava
slava's Avatar
Drives: brZed
Might not be able to pull this off, but thanks for the helpful answer. Might be more options available down the road to make this an easier task. 3k would be a reasonable amount to spend on this, plus maybe another thousand for cams, but that doesn't seem doable at this time.
slava is offline   Reply With Quote
Old 10-20-2014, 07:48 PM   #25
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Surprised nobody mentioned Megasquirt EMS. Possibly the cheapest out there.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
The Following User Says Thank You to aznatama For This Useful Post:
slava (10-20-2014)
Old 10-20-2014, 07:50 PM   #26
slava
slava's Avatar
Drives: brZed
Will look into that.
Also, this is probably more realistic and more along the lines of what I would actually do, but still prob not cheap.
Old 10-20-2014, 08:05 PM   #27
Turdinator
Señor Member
Turdinator's Avatar
It has been some time since I have looked at megasquirt. Would it be able to run the VVTi and both the direct and port injection?
1974 TA22 Celica
2013 86 GT
Old 10-20-2014, 08:07 PM   #28
aznatama
aznatama's Avatar
No idea, I think it can... There's so many versions out now. It's been a while since I last logged at it too
'14 BRZ LTD MT DGM
Jack/stand system Mr.Corvus Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 03-31-2013 12:02 AM
Does the 'S' Stand for Snow? Clembo New England 9 03-14-2013 06:26 AM
Where do I stand legally? Kenno AUSTRALIA 49 06-22-2012 11:33 PM
What does FORD stand for? Lexicon101 Off-Topic Lounge [WARNING: NO POLITICS] 16 03-19-2010 09:48 PM
