Old 10-09-2014, 06:48 PM   #43
jher
Drives: 2013 Scion FRS
Originally Posted by Xerious View Post
Are you running into the issues mentioned here or is this preventative.
It's preventative. I know a member who has a SS braided clutch line and he said there is a big difference on the clutch. He's coming to the Dublin meet tomorrow so I'll get more info from him. Only thing is, he is still on stock clutch.
Never mind it does not help with the issue. Just pedal feel better.
jher is offline   Reply With Quote
Old 10-10-2014, 07:26 AM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by RallySTI View Post
Thank you for the feedback of our products.
Exedy sells a Twin Disk application for this car. I owned it and drove it for less than 1000 miles. Never had any issues with gear engagement, etc. And the clamping load on that one is 2900 lbs.
There are several clutch choices for this car (CM FX400, ACT with extreme pressure plate), and none of them have a pattern of issue like this one.
I am inclined to think the clutch hydraulics are not the issue at hand.
I still hope Exedy will make this situation right as it is an OEM supplier and has always been known to be a stand up company that is 1000% behind their products. I am already $400 out of pocket for this, and there are $400 more coming when I inevitably remove this clutch. It is getting harder to get into gears every time I drive the car.
Old 10-10-2014, 07:26 AM   #45
Sportsguy83
Drives: Limited BRZ
Originally Posted by jher View Post
Has anyone change out their stock clutch line to aftermarket SS braided one? Just wondering if that would help a little.
Thinking about changing mine out.
I have SS braided clutch line, no difference regarding the issue.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
jher (10-10-2014)
Old 10-14-2014, 07:36 AM   #46
Sportsguy83
Drives: Limited BRZ
@RallySTI any updates on the questions in my post regarding the correct Stg. 2 clutch kit?
Old 10-14-2014, 10:38 AM   #47
blown
Drives: ft86
i have one on order, that is backordered. hopefully they changed something on the new ones?
blown is offline   Reply With Quote
Old 10-17-2014, 12:18 AM   #48
blown
Drives: ft86
Old 10-20-2014, 10:32 AM   #49
blown
Drives: ft86
update?
Old 10-20-2014, 11:37 AM   #50
qtwre
Drives: White FR-S
Sorry for my delayed presence here. My mechanic has been too backed up to take out my clutch so I haven't driven my car in three weeks. I also haven't been on the forum during that time out of mild depression. :P
I've dropped my car off this morning to have the OEM clutch reinstalled. I had spoken to Evan weeks ago and completed an RMA form, so once I have the clutch back out I'll ship it to Exedy.
I'm a little worried that he's saying the spine size appears fine, if others are seeing that it's smaller. I'd hate to incur the expense of shipping it cross-border just to be told it's fine. It's a hard fact to ignore that we have a list of people all with the same clutch and same problem.
I'm not sure why my name is down with "different brand clutch" but I have a regular Exedy Stg 2 for the record.
I haven't been keeping track of miles. Probably around 1500km but I've been babying it the whole time as it quickly started degrading after initial install, hoping it would get better. I couldn't even back into a parking spot at the shop this morning. I had to turn the car off first to get it into reverse.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
Sportsguy83 (10-20-2014)
Old 10-20-2014, 11:55 AM   #51
blown
Drives: ft86
what kind of grease are you guys using?
Old 10-20-2014, 01:29 PM   #52
Sportsguy83
Drives: Limited BRZ
the grease that comes with the clutch "Exedy" brand.
Old 10-20-2014, 01:29 PM   #53
Sportsguy83
Drives: Limited BRZ
[QUOTE=qtwre;1990790
[/QUOTE]
Updated.
Old 10-20-2014, 01:42 PM   #54
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
The minor diameter measured 22.64-22.71mm. The blueprint states the minor diameter as 26.2mm +0.13mm/-0.00mm.
lolwut
Travisty75 is offline   Reply With Quote
The Following User Says Thank You to Travisty75 For This Useful Post:
Old 10-20-2014, 01:43 PM   #55
blown
Drives: ft86
have you tried a different grease? I've had good luck with red grease lithium
Old 10-20-2014, 01:45 PM   #56
Sportsguy83
Drives: Limited BRZ
Other people have tried a different grease with no luck.
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
Exedy Stage 2 Clutch alpine Engine, Exhaust, Transmission 21 09-09-2014 12:24 AM
Share your interesting experience when you bought your BRZ/FRS g0ast BRZ First-Gen (2012+) — General Topics 18 02-25-2014 12:39 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
