Old 10-18-2014, 07:44 AM   #1
ggiddix
Drives: scion frs
Sound tube issues
Could removing the sound tube cause the rpms to fluctuate. I took it to the dealer and they put the sound tube back on, did the software ecu flash update and put shims in the cam shaft to adjust the timing and it seems to fix the problem.
But what I would like to know is if I could take the sound tube off again?
ggiddix is offline   Reply With Quote
Old 10-18-2014, 08:07 AM   #2
raven1231
It doesn't for everyone else I know including myself running no sound tube. Did you plug the sound tube hole??
Old 10-18-2014, 08:09 AM   #3
ggiddix
Drives: scion frs
Yes I plugged both, I didn't think it could, even though it's part of the intake all it does is make noise
Old 10-18-2014, 08:51 AM   #4
Borrowed Time
Drives: 2015 Ultramarine FRS
Then it's likely that the timing and reflash are the real solution to the problem.
Borrowed Time is offline   Reply With Quote
Old 10-18-2014, 08:57 AM   #5
ggiddix
Drives: scion frs
Thanks
Old 10-18-2014, 11:45 AM   #6
100% correct!
IF they put it back on just grab the plug from the socket in the glovebox and cram it in the hole under the passenger mat. That way you can just pull it when you take it in for service and they can't try to use it as an excuse.
humfrz (10-20-2014), NIN69 (10-18-2014)
sound tube plug? ft86me Engine, Exhaust, Transmission 23 12-21-2014 10:27 PM
WTB: Red tube sound chnager Sharpe978 Want-To-Buy Requests 3 10-05-2014 05:43 AM
FS OEM sound tube Vlady Engine, Exhaust, Bolt-Ons 0 10-16-2013 08:59 PM
why do people not like the sound tube? pr086 Scion FR-S / Toyota 86 GT86 General Forum 104 02-25-2013 09:08 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 08:24 PM
