Old 10-17-2014, 08:43 PM   #351
Anh5oi
Drives: 13 FRS
My oft & OFH arrives today and I plan to install it tomorrow.
What is the best rom for drop in filter with OFH?
Anh5oi is offline   Reply With Quote
Old 10-17-2014, 08:50 PM   #352
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
stg 2 rom specific for your car. 91 oct or 93 oct.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 10-17-2014, 08:55 PM   #353
steve99
Drives: FT86
Originally Posted by cliffm View Post
Where can I get the Original Stock Tunes?
Mine uses D00C.bin
if your using an oft your stock tune will be in the protected slot of oft as boffneenne csays you can flashbit back to car or copy it to your pc viacthe openflash managercsoftware
if your just cafter the stock roms see the tactrix link below i have posted up the latest stock roms at the end of first post.
Old 10-20-2014, 07:01 PM   #354
benlaz88
Drives: 2013 Asphalt FRS
Here are my 3rd log on E85. Seem like everything looking good after the 2nd tank of E85. However i see some high +/- STFT and LTFT. Should i be worry about this or would need to rescale my MAF to correct that...? Sorry for the long logging. Just want to make sure everything is fine.
http://www.datazap.me/u/benlaz88/3rd...0&data=1-7-8-9
benlaz88 is offline   Reply With Quote
Old 10-21-2014, 08:48 PM   #355
Turdinator
Señor Member
Turdinator's Avatar
Is there a dyno anywhere comparing v1.6 to v2.06 tunes? My google fu is weak and I couldn't find one. @Shiv@Openflash
1974 TA22 Celica
2013 86 GT
Old 10-21-2014, 09:18 PM   #356
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I hope you'll be around the forums in the summer when I get my OFT! I might need your help if I ever come to a problem
Kelbyat07 is offline   Reply With Quote
Old 10-21-2014, 09:27 PM   #357
steve99
Drives: FT86
OFT is pretty easy to use just read the OFT TIPS post below and you should be fine.
Old 10-22-2014, 01:19 AM   #358
ScionFrsFan
Cold starts is starting to become a issue with e85 . How much of a "downgrade" is switching from e85 to 93pump?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 10-22-2014, 03:43 AM   #359
steve99
Drives: FT86
have you tried increasing the cranking Injector pulse widths in the tables
or add a gallon on 93 petrol to a full tank of e85 ?
ScionFrsFan (10-22-2014)
Old 10-22-2014, 06:58 AM   #360
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
As I am also having this issue and have already added a gallon of 93; which ones and how much? I see "cranking fuel injector pulse width (A-F) ECT" and "cranking fuel IPW compensation XXX". If it is just the A-F tables, then what cranking state number: 2,4,5?
I have a trip coming up so I may be going back to 93 anyway, but If I do decide to go back to E85 it would be nice to not it die 2 times before it will idle.
And thanks again for all the help you give Steve
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-22-2014, 09:34 AM   #361
steve99
Drives: FT86
I linked some info on E85 cold start mods in the OFT Tune Tweeks Thread and the E85 on stock car thread posts below
but here is direct link
http://www.ft86club.com/forums/showt...21#post1444921
I think I would go with malts adjustments below
http://www.ft86club.com/forums/showp...1&postcount=40
If all else fails have a talk to @Malt or @Luckrider
Target70 (10-22-2014)
Old 10-22-2014, 01:46 PM   #362
ScionFrsFan
I haven't tried adding 93 yet. I never played around with tables(scared I will screw something up lol)They should make a winter e85 tune.
Is 93 tune a lot slower? I went from 1.59 basic tune to v2 e85 and that was a big jump. Curious how much they improved 93 since then.
ScionFrsFan
Old 10-22-2014, 01:55 PM   #363
steve99
Drives: FT86
93 tune will be noticeably "slower" than the E85 tune.
Old 10-22-2014, 03:16 PM   #364
cliffm
Originally Posted by Boofneenee View Post
in order for you to use the OFT you had to copy u your stock tune onto the tablet. its there. just look
Actually its not there b/c my tablet had a problem and had to be sent back before I could re marry it or copy it to my pc. The new tablet is now married to the OFT tune.
cliffm is offline   Reply With Quote
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
