Old 10-13-2014, 07:16 PM   #337
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
They are their mate, in the V2xx tune download on the OFT downloads page for editing V2x OFT tunes only. they are not in order.
Here, if I'm wrong then tell me where to look.
RR_ZA1JA01C is missing, not out of order or whatever..and no B01C def.
RR_ZA1JA01A
RR_ZA1JA01E
RR_ZA1JA01F
B-R-Z is offline   Reply With Quote
Old 10-13-2014, 07:37 PM   #338
steve99
Drives: FT86
RR_ZA1JA01A
RR_ZA1JA01E
RR_ZA1JA01F
Use the OFTxxxxxxxx ones I think the OFT guys just have not changed the names on the defs I believe they are all OFTxxxxxx defs as they were all supplied by the OFT guys from their site. They used to call them RRxxxxxxx but changed to OFTxxxxxxx to avoid confusion with the REAL romraider definitions you would get from the github site. (but looks like they forgot to change the names on some of them.
Best to confirm this with the OFT guts though. email them or call.
always use the definitions from the oft website when editing the OFT tunes and always use the definitions for your tune revision ie V2 or V1.5.
Use definitions from the OFT web site that come with the V2 tunes for editing OFT V2 tunes
If you wanted to edit a STOCK tune you pulled from your car DO NOT use the definitions from the OFT site use the ROMRAIDER definitions from the romraider site.
Again always check some known tables to see everything looks good.
Unfortunately the naming of the defs has overlapped causing a bit of confusion.
Old 10-13-2014, 07:40 PM   #339
B-R-Z
B-R-Z's Avatar
Ok so I am to use OFT_ def files in Rom Raider for OFT ROMs. I should only use the RR_ def files for a stock ROM (pulled from ECU)?
Edit: Ok I think this right because the tables look ok and I can finally see LC\FFS.
Old 10-13-2014, 07:44 PM   #340
steve99
Drives: FT86
always use the defs supplied by oft guys from OFT downloads site for editing OFT tunes (their naming is unfortunately the same a RR but defs are not the same)
Always use the defs downloaded from the github site for STOCK ROMs pulled directly from a brz/86
Use the OFT defs matching the OFT tune revision
Use the matching def for calid
Always check some known tables in the tune/rom to make sure it looks ok, if it looks wrong calid/rom does not match = bricked ecu
Old 10-13-2014, 07:53 PM   #341
B-R-Z
B-R-Z's Avatar
Ok yes that was just confusing seeing the RR_ defs in the same ZIP as their ROMs, and similarly named. It suggested to me I should use the RR def with Rom Raider, and the OFT def for the tablet or something. Thanks again for the help.
Old 10-14-2014, 03:33 AM   #342
brn12345
brn12345's Avatar
Have the definitions 2.xx changed to protect the work the OFT guys have done or is it because they are now based on newer roms?
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 10-14-2014, 03:37 AM   #343
s2d4
s2d4's Avatar
Pretty sure its because oft people are running the most up to date ROM even if they have a lower cal ID.
Old 10-14-2014, 04:07 AM   #344
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Based on the newer, B*** roms.
Td-d is offline   Reply With Quote
Old 10-17-2014, 12:46 PM   #345
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
http://www.datazap.me/u/boofneenee/9...=1-4&mark=4686
Hi, did a long log yesterday with most of the drive on the highway . I did manage to get a couple of good pulls and I do not (with my limited tuner knowledge) see any issues. No flkc and knock correction, ignition adv held to 25. However, I did get kncok correction adjustments while cruising the highway. At one point you will see knock correction of 1.4. I remeber @steve99 saying anything over .7 could be an issue. But i also understand their are other variables i.e. kc learned to look at to help determine if its bad kr good knock (if their is such a thing) Would you recommend I post more logs or flash back to 91 tune. Thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 10-17-2014, 06:30 PM   #346
steve99
Drives: FT86
the only difference between 91/93 tunes is timing at higher rpm above about 5000 they pull about 1 degree on the 91 map. that knock on the highway will be in 2000 to 3500 area so to fix it you will need to remove about 0.7 our of the base timing B at the rpm/load points its happening. alternativly try different brand of fuel it may be better
Boofneenee (10-17-2014)
Old 10-17-2014, 07:09 PM   #347
verts
verts's Avatar
Drives: '13 6MT Raven FRS
Quick question as I never got an email back from the OFT guys.
Been using OFT for a while ago, simply got it and used the tunes that were preloaded on it (think it was 2 version before the 2.06 maps).
The maps currently on there are listed as the A01C. Recently wanted to upgrade to the 2.06 OTS maps and when i went to add the A01C Stage 2 EL 91 map its giving me errors saying its not the right type versus my stock tune. Tried a couple different types and found that it will let me put the A00C tunes on there.
Just want to make sure that I should be using that A00C tune, even though what I loaded before was just the A01C that came with the tablet preloaded and its not a bug that I can't load the new 2.06 A01C tunes on there. Thanks.
verts is offline   Reply With Quote
Old 10-17-2014, 07:11 PM   #348
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
very good info. I did not know it was 1 degree of timing about 5k! thank you.
I may have to go with a custom tune here to fix this issue.
I will also try 93 from a different station
thanks
FRS
Old 10-17-2014, 07:24 PM   #349
cliffm
Where can I get the Original Stock Tunes?
Mine uses D00C.bin
cliffm is offline   Reply With Quote
Old 10-17-2014, 07:57 PM   #350
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Mine uses D00C.bin
in order for you to use the OFT you had to copy u your stock tune onto the tablet. its there. just look
FRS
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 10:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 09:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 01:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 04:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 10:02 PM
