Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 10-16-2014, 09:02 PM   #57
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by *LongFella View Post
This is awesome. Well done guys!
Quick question: If you have the hyper flash module in place under the steering column, do you need a hyper flash relay in back? My gut says no, but you guys are the experts!
Thanks! You just have one flasher module, which controls all of the turn signals in your vehicle. If you have one already, you won't need another.
i dunno how the wiring works, but is it just repining to get it how i want it for the toms?
You'd just connect two wires in the module. Sort of like repinning. Instructions will describe how to do it.
List updated, production is fully underway and we expect to ship middle of next week!
Paul
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
*LongFella (10-16-2014)
Old 10-16-2014, 09:55 PM   #58
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
Question are all flasher modules made the same? Like the one I bought from you guys, would it be different from another one from a different company?
hahaman86 is offline   Reply With Quote
Old 10-16-2014, 11:05 PM   #59
gepeyo
Opal86
gepeyo's Avatar
Drives: 2013 10 Series #Opal86
if i threw a pre order down, will switchbacks be available again before they ship? I emailed you guys a little while ago about when you would get switchbacks in stock and i was told that they were suppose to be back in stock by the end of last month. I wanted to get get switchbacks and possible this wiring kit for my new pair of toms.
I was wondering, I have not received my tom's taillights yet, but are you able to convert the turn signal on tom's into backup lights as well?
gepeyo is offline   Reply With Quote
The Following User Says Thank You to gepeyo For This Useful Post:
Diode Dynamics (10-17-2014)
Old 10-17-2014, 02:39 AM   #60
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
It's 3AM now, but I'm definitely gonna get on this in the morning!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 10-17-2014, 09:10 AM   #61
Rico415
Rico415's Avatar
Drives: 13FR-S
i'm in... looks like what i'm needing !
#11199198
Rico415 is offline   Reply With Quote
The Following User Says Thank You to Rico415 For This Useful Post:
Old 10-17-2014, 11:51 AM   #62
Diode Dynamics
Flashers are all very similar but some work better than others due to small differences in the digital circuits and variances in the components used, even if the circuit is the same.
However, if one works for you right now, it will work fine with our mod here, etc. I'm just talking about slight differences in blink rates, etc.
We expect to have our new switchbacks in stock by the end of this coming week. We had to delay the production a bit because the white color was not exactly where we wanted it, but the new ones are by far the best switchbacks we've ever offered, and in my opinion the best on the market.
You wouldn't be able to convert the turn signal to backup on Tom's tail lights because it's all LED, and all covered with a red reflector.
John C.
Diode Dynamics
Old 10-17-2014, 12:17 PM   #63
mush
mush's Avatar
ordered
Old 10-17-2014, 01:40 PM   #64
gepeyo
Opal86
gepeyo's Avatar
Cool hopefully I can order both at the same time then. I was wondering for tom's can I have the set up where the main taillight is a turn signal and then change my turn signals into just plain taillights?
Old 10-17-2014, 07:28 PM   #65
Diode Dynamics
This mod will turn your tail light into the turn signal.
Then you can easily make two connections (all in the kit) to make the turn signal work as either the brake light, running light, or to keep it as turn signal.
Thanks!
John C.
Diode Dynamics
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
gepeyo (10-17-2014), NIN69 (10-18-2014)
Old 10-20-2014, 10:44 AM   #66
arvidj
Drives: '93 MR2 Turbo
Yes, I specifically addressed this in the video- while it would make things very slightly easier, it would add around $15 to the cost of the kit, so we chose not to include them. We may offer it in the future, if we can get the price down, but right now we are focused on bringing as much value for your dollar as possible with this product.
One quick splice is just fine for a non-critical component like this, but you can certainly solder the wire instead if you'd like.
Thanks!
Paul
I knew you had addressed it in the video but wanted to provide feedback that at least one person would prefer the $15 - $20 as an option over the guillotine splices ... and soldering is not my idea of a flexible connection where a crimped connection would be preferred ... critical component or not.
We cannot offer it at all right now at all in this initial run.
If we do offer it in the future it would probably be a $20 upgrade. Since that would make the kit $50 instead of $30 we decided not to include it for the initial run.
If you had a part number for the connector ... be if an OEM number, from DigiKey, Mouser, etc. ... and wanted to pass it on I'd add it to my next order and make my own ... i.e. not as a competitive product, just for my own use. It would save me from having to research it myself ;-}
And I just order your kit.
Thanks,
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
The Following User Says Thank You to arvidj For This Useful Post:
Diode Dynamics (10-20-2014)
Old 10-20-2014, 05:28 PM   #67
Khánh
Khánh's Avatar
Drives: sc00ter
this is awesome! can't wait to receive mine!
Khánh is offline   Reply With Quote
Old 10-20-2014, 05:32 PM   #68
Khánh
Khánh's Avatar
Drives: sc00ter
btw, the top (now) reverse is 7440, what size bulbs are the low reserve light?
Old 10-20-2014, 07:28 PM   #69
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Order placed, these look pretty sweet. #11199738
Shneegle is offline   Reply With Quote
Old 10-20-2014, 09:26 PM   #70
Waffleicious
Waffleicious's Avatar
Drives: 2015 BRZ Blue Edition
Just pre ordered!! Got the primo package 8D
Order# 11199755
Waffleicious is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play KI_ZN6 Exterior Parts - Lighting 685 02-18-2016 11:03 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-06-2014 11:24 PM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 09:52 PM
