Old 10-16-2014, 11:52 PM   #1
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Factory HID (BRZ/FRS) Slowly Fading to Yellow Hue?
Is it just me or does the factory HID on BRZs and available equipped FRSes get yellow-er over time? Our Kelvin temperatures are 4300 which is supposed to have some slight yellowish hue. Compared to 2014 BMW, Lexus, Infiniti (Q50) models, our HIDs look yellow in comparison. Maybe it's just me but it seemed much whiter when I had purchased my BRZ last May. Any thoughts?
(I think I might just switch to 5000K bulbs..)
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 10-17-2014, 12:13 AM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
It's happened to me before on my wife's CRV, where the left side HID (factory fitted) became noticeably "yellower" compared to the other side. Was replaced under warranty without any further issues since.
Fizz is offline   Reply With Quote
Old 10-17-2014, 08:12 AM   #3
J_kennington
Drives: 2013 asphalt scion FRS
4300 should be yellowish. 6k is near a pure white with a slight blue. 8k is pure blue. 5k would be close to white with a small off tint
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 10-17-2014, 08:38 AM   #4
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
HIDs typically go toward the other end of the spectrum over time (white/blue). So it seems kind of odd.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
B-R-Z (10-19-2014), boucher (10-17-2014)
Old 10-17-2014, 09:45 AM   #5
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
That's what I was thinking too. I know on my 04 WRX with STi HID's, they were pretty white/blue. That was the original bulbs after about 7 years. I had to replace one and it was noticeably less blue. HID's burn hotter over time, so they shouldn't get more yellow.
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
Old 10-17-2014, 10:10 AM   #6
4honor
Drives: 2014 SWP BRZ Limited
Funny you posted, because I just changed my 2014 BRZ fogs to LEDs (XML2 from Diode Dynamics, which I will write a review on it later), and now it seems my HIDs are actually quite warm... I believe the LEDs are 6000K.
Then while driving today, I noticed (maybe I am just paranoid) that all the Beamer/Caddy/Merc/Mustang/Camaro/etc. had much whiter/bluer tint. I may have to change out the HID bulbs...
4honor is offline   Reply With Quote
Old 10-18-2014, 01:46 AM   #7
Poodles
Drives: 2015 Series.Blue
D4S is supposed to be slightly higher kelvin than D2S. How they age I'm unsure given that D4S is lead free.
It's likely just you getting used to the light.
If you're going to switch, don't cheap out on Chinese bulbs of questionable quality... buy the Osram Xenarc CBI's which unlike the Chinese stuff is brighter than stock but still higher kelvin (and legal, and OEM equipment on select cars, etc)
The Following User Says Thank You to Poodles For This Useful Post:
KelvinBRZ (10-18-2014)
Q300 burnt tip fading Howardwei Cosmetic Modification (Interior/Exterior/Lighting) 9 07-25-2015 11:43 AM
SAFE?:running nokya yellow bulbs in factory foglight housing jbsali Cosmetic Modification (Interior/Exterior/Lighting) 12 07-13-2014 11:42 AM
BRZ Fender Trim Vents Fading - Possible Solution(s) makalaka Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-06-2013 02:00 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
Stereo sound fading in and out *Problem* JiB AUSTRALIA 9 08-06-2012 05:46 PM
