Old 10-15-2014, 12:26 PM   #15
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
walk away please
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Thorpedo (10-04-2015)
Old 10-15-2014, 12:35 PM   #16
Captain Caveman
Drives:
Originally Posted by tonystewart View Post
walk away please
Why? Just looked up the AL Priority. Kinda pricey, but to each their own.
Sent from my MB860 using Tapatalk 2
Captain Caveman is offline   Reply With Quote
Old 10-15-2014, 02:11 PM   #17
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
tony stewart's about to run someone over.
to soon?
The Following User Says Thank You to echo419 For This Useful Post:
Old 10-15-2014, 02:45 PM   #18
tonystewart
Copy that
Old 10-15-2014, 03:26 PM   #19
tonystewart
to soon?
Nope, not indicted
Old 10-15-2014, 03:27 PM   #20
tonystewart
If you have to ask the price, just drive the speed limit
Old 10-15-2014, 03:54 PM   #21
tonystewart
I'm assuming that is this: http://www.laserveil.com/ which does what I said you would probably need to do. Or am I wrong?
Not trying to start a pissing match, but OP if you know about the speed trap areas why not just avoid them or slow down?
Veil by itself gives you one second against Laser, VeilGuy would disagree but then he makes the stuff. or about 400 ft till punch thru occurs and it will occur.
One second helps if equipped, with a five head, 3 front and one rear, AL Priority.
It is enough to keep the LEO at bay until speed your speed is reduced.
Then "Shutdown the jammer", let LEO get a "legal reading", and clear is killbox. Do not bring attention to you by JTG, it pisses them off.
Rearm the jammer and give it the beans.
My worst experience.
I was lazed head on by a FHP at too short a range to jam on the brakes and shutdown, I blew by him and then my rear heads stated jamming him as FHP went for a rear shot, thank goodness for rear heads. I slowed down enough to shutdown the ALP, then about two minutes later I see FHP pacing me in rear view mirror, 10 miles later (70 mph) he slowly creeps up to me and starts photographing me with his phone. He wags his finger out the window, slows down and takes the next center median cut through. Lucky right? I accelerate to cruise speed (20 over) for no more than a minute and "bang --lazed again", FHP in median and four chase Chargers, unlucky for the black z07 behind me in the hammer lane, the bmw 535 behind him, and the Toyota Camry behind me. I shutdown and watched every car get pulled over except me, the Bimmer driver saluted me in a derogatory manner as I passed him. I did ten over after that
The three folks in the car with me laughed so hard they almost pissed there pants.
I love my V1's w/ V1C and YaV1 and the incredible AL Priority 5 heads
Bg8780 (10-16-2014)
Old 10-16-2014, 01:29 PM   #22
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Haha! That had to amazing to watch but scary at the same time. At least you know for sure your works. Do you use this along side a traditional radar detector for safety against KA, K, etc? I just purchased an Escort Max after using an Escort 8500 X50 for years.
I love that the AL Priority can have a USB stick removed so even if LE catches it you can pass it off as a parking sensor.
Did you install this yourself or is this something that should be installed by a professional?
Sent from my XT1060 using Tapatalk
Bg8780 is offline   Reply With Quote
Old 10-16-2014, 01:45 PM   #23
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
You're my HERO
Freetime is offline   Reply With Quote
Old 10-16-2014, 02:48 PM   #24
tonystewart
Valentine 1 with V1C and YaV1
Self installed, getting the heads level is the key
Bg8780 (10-16-2014)
Old 10-16-2014, 04:42 PM   #25
Bg8780
Bg8780's Avatar
Thanks for all the info Tony. I learned a lot and now know where to start. Would you mind if I shoot you some PMs in the future if I have any questions?
Old 10-16-2014, 04:49 PM   #26
tonystewart
No worries
Bg8780 (10-16-2014)
Old 10-04-2015, 08:55 PM   #27
dj2020
On your ALP laser jammer set up, where do you recommend the jammer heads go on the FRS/BRZ? Two in the front grill and one near the rear license plate?
dj2020 is offline   Reply With Quote
Need help w/ FRS radio install / harness info varun Electronics | Audio | NAV | Infotainment 6 02-19-2014 09:40 PM
What radar/laser detectors do you use? sa1126 Electronics | Audio | NAV | Infotainment 131 12-16-2013 09:39 PM
Tristate Radar Detector/Laser Jammer install? #87 NY / NJ / CT / PA 5 06-24-2013 07:40 AM
Laser Countermeasures Mpowered Electronics | Audio | NAV | Infotainment 2 02-24-2013 01:44 AM
