Old 10-09-2014, 09:42 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Looking for info on Laser Jammer and install
I'm in the Atl area and I am interested in getting some sort of laser protection installed. I currently have a Escort Max if that provides any type of integration with a jamming system. Can anyone point me in the right direct or put me in contact with a shop that specializes in this?
Bg8780 is offline   Reply With Quote
Old 10-10-2014, 07:05 AM   #2
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
you got a turbo or something? because my car is so slow half the time I get to the speed limit I have to make a turn or something anyways.
Old 10-10-2014, 08:37 AM   #3
Bg8780
Bg8780's Avatar
haha no, I'm slow. Cops in my area just don't play fair. Clocked me with laser going 60 in a 45. Pulled me over right in front of the sign that says "55 mph". They set up a lot of speedtraps in areas where it looks to be 55 and everyone is going 55-60. I get pulled over "cuz racecar". If he only knew his wife's Camry has more power than me. lol
Old 10-10-2014, 06:25 PM   #4
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Especially now that 285 has the changing speed limits. For most of the time it is 65 now but they drop it 55 by Peachtree industrial and a cop is always sitting there
lastexile1987 is offline   Reply With Quote
Old 10-12-2014, 09:53 AM   #5
Bg8780
Bg8780's Avatar
Bump.
Sent from my XT1060 using Tapatalk
Old 10-14-2014, 08:33 PM   #6
gt8613
I dream of BRZ
Drives: Prospective BRZ owner.
Use a GPS that warns you of changes in speed limits? Just get in the habbit of looking out for cops and for.known spots in your daily commute? Not the options you are looking for but at less it will save you some crooked cop trouble.
gt8613 is offline   Reply With Quote
Old 10-14-2014, 10:16 PM   #7
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
AL Priority 866-922-5872 has the best unit on the market , trust me they jtg against the dreaded Dragoneye Compact which is what Atlanta Area PD uses
Atlanta is very well equipped
Avoid Laser Interceptor until they decide to update their firmware to handle the Dala.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-14-2014, 10:49 PM   #8
Captain Caveman
Drives:
I'm no scientist, but I don't think you can "jam" a laser. Pretty sure you would have to make your car non-reflective, or find something that would disperse the laser (or something to that effect). IIRC, LiDAR usually gets bounced off of front license plates, headlights or some other reflective surface.
But I would check my local laws before I did anything to circumvent Johnny Laws attempts to keep the peace.
Sent from my KFTHWI using Tapatalk
Captain Caveman is offline   Reply With Quote
Old 10-14-2014, 11:35 PM   #9
tonystewart
A voice from the inexperienced, again,
1. I do it all the time
2. Other than Veil, nothing else works
3. Please read up before making statements like those above.
Florida and Georgia do not having laws against jamming LIDAR, and the AL Priority doesn't give the LEO a "jammed code" on their LIDAR speed devices.
Old 10-15-2014, 07:59 AM   #10
Captain Caveman
Drives:
Or you could drive at or below the speed limit. Just saying...
Old 10-15-2014, 09:48 AM   #11
Bg8780
Bg8780's Avatar
Thanks @tonystewart. That's the type of expertise I was looking for. I will look for more info on that unit after work. Do you know of any shops in the Atl that can do a clean install?
@Captain Caveman, I am a safe driver and always pay attention to the posted speed limits. Sometimes there are cops sitting in a known speed trap and are there to produce revenue. It's for money not safety. Maybe next time you can present proper information or experience instead of just throwing your misguided 2 cents into the thread. Just saying...
Old 10-15-2014, 09:48 AM   #12
Bg8780
Bg8780's Avatar
Delete. Messed up edit.
Old 10-15-2014, 09:49 AM   #13
Bg8780
Bg8780's Avatar
Delete, damn Taptatalk
Old 10-15-2014, 12:25 PM   #14
Captain Caveman
Drives:
I'm assuming that is this: http://www.laserveil.com/ which does what I said you would probably need to do. Or am I wrong?
Not trying to start a pissing match, but OP if you know about the speed trap areas why not just avoid them or slow down?
Sent from my MB860 using Tapatalk 2
Need help w/ FRS radio install / harness info varun Electronics | Audio | NAV | Infotainment 6 02-19-2014 09:40 PM
What radar/laser detectors do you use? sa1126 Electronics | Audio | NAV | Infotainment 131 12-16-2013 09:39 PM
Tristate Radar Detector/Laser Jammer install? #87 NY / NJ / CT / PA 5 06-24-2013 07:40 AM
Laser Countermeasures Mpowered Electronics | Audio | NAV | Infotainment 2 02-24-2013 01:44 AM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
