Old 10-10-2014, 03:21 PM   #1
Breeeep
Drives: 2013 Grey BRZ / 1995 Trooper
BRZ+ Long legs + heel-toe downshift = fail ?
Trying to figure out leg/foot placement to learn proper downshift. Problem is that my upper thigh touches the bottom of the steering wheel. The wheel is all the way up...seat all the way back. I can't seem to get my leg rotated/shifted properly.
Any advice from other long legged drivers ? Or am I basically screwed ?
Breeeep is offline   Reply With Quote
Old 10-10-2014, 03:29 PM   #2
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Play around with how you're positioning your foot on the brake pedal. Myself, I place the ball of my foot (as opposed to my "toe") on the brake to hit the accelerator comfortably square on my heel.
I'm assuming you've also adjusted the height of the seat to the lowest as well since your quad is hitting wheel?
1Cor10:23 is offline   Reply With Quote
Old 10-10-2014, 03:49 PM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I don't use my actual heel. Just the right side of my foot while my toe is on the brake pedal.
No room to rotate my whole size 13 foot like that.
murdoc is offline   Reply With Quote
Old 10-10-2014, 04:00 PM   #4
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Yepp, what @murdoc said... I dont really rotate, its more like a pivot
Cockatoo is offline   Reply With Quote
Old 10-10-2014, 04:15 PM   #5
TrqlessWonder
Drives: 2014 FR-S
+1 For non-emergency stuff, I've got the ball and big toe on the brake and I just roll my ankle over to give a quick jab with the right side of my foot. Not as effective for the emergency stuff for me though, especially in my steel toes.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 10-10-2014, 05:39 PM   #6
Breeeep
?? I guess I was not aware that the BRZ seat could lower any further?... seems like my butt is already on the road ! Need to read the owners book again.
Based on the comments, seems like I need to fidget around the seat until I get a good geometry that works for me. Wearing running shoes seems to be bad, since the ball of my foot feels awful when applying pressure. Thanks for the assistance
Old 10-14-2014, 10:17 AM   #7
DaDr00
DaDr00's Avatar
Yep. 6'5" with size 13 shoe: I've learned to roll my right foot to blip the throttle on pretty much any vehicle I'm driving, there really isn't much room for anything else.
- '13 Whiteout FR-S
- '95 Toyota T100
NASA Mid South - Chief of T&S
DaDr00 is offline   Reply With Quote
Old 10-15-2014, 07:33 AM   #8
pleong
Drives: 2013 Whiteout FR-S
Try these
http://www.srpracing.com/pd_brz_racing_pedals.cfm
You won't have to lift your leg as much since the gas pedal is extended closer to the brake pedal..
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 10-15-2014, 10:33 AM   #9
D K
Stig's dark passenger
Heel and toe is a very old misnomer back from the days when gas pedal was on the left and brake on the right.
Anybody attempting to do an 'actual' heel and toe is, well, not doing it correctly.
Find a place on the brake pedal that you are comfortable with as part of your foot hangs over.
Rotate slightly.
Blip.
Slam into gear
Repeat
D K is offline   Reply With Quote
Old 10-15-2014, 12:41 PM   #10
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Right - it ought to be called ball-and-ball.
dradernh is offline   Reply With Quote
Old 10-15-2014, 03:25 PM   #11
D K
That would probably lead you to a set of movie titles that you may or may not be inclined to watch.
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 12:01 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
Stretch Your Legs 10 anyone going this Sunday? FR-Shadow Great Lakes 35 02-18-2013 09:07 AM
Stretch your legs chicago Hawaiian Great Lakes 2 10-21-2012 11:31 AM
