Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 10-10-2014, 01:53 AM   #43
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
subbed... will eventually get around to ordering these.
hmong337 is offline   Reply With Quote
Old 10-12-2014, 08:55 PM   #44
mush
mush's Avatar
i have toms tail. this was asked earlier but was taken to PM. is it easy to make the signal side brake light too? and have both the brake and signal blink when signaling?
Old 10-12-2014, 09:51 PM   #45
Diode Dynamics
Diode Dynamics's Avatar
Out of the box, this module will make anything that lights up as a brake light also light up as a turn signal.
I think the side part on the TOMS tails is the running light. It is not wired up in the tail light to be a dual-stage light (bright and dim modes) so it would be difficult to make it work as the turn signal. You could make the whole running light portion into the turn signal (instead of the brake light) but generally that's not a good idea because the running lights aren't bright enough to be turn signals.
Thanks,
Paul
John C.
Diode Dynamics
Old 10-12-2014, 10:04 PM   #46
mush
mush's Avatar
Thanks,
Paul
toms tail have their own running light strip(outter). then the brake light(middle), and the turn signals(inner). they are all seperate
im wanting to make the brake/signal both light up when u brake and both blink when u signal
if thats possible with a little bit of rewiring your kit
running light strip(outer), brake light is not lit on this pic(middle), signal(inner) mine is red
Old 10-14-2014, 06:58 PM   #47
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
I am really liking this.... but is there way to make the turn signal lights to brake light instead of reverse light?
It probably requires a brand new plug-n-play...
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 10-14-2014, 07:29 PM   #48
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
I've already ordered but I was wondering, I saw that you mentioned an oem connector could be put into the system for true plug and play installation in place of the splice.for those of us alright with the price increase would it be possible to pay the extra to get the oem connections?
hahaman86 is offline   Reply With Quote
Old 10-14-2014, 08:09 PM   #49
Diode Dynamics
Oh yeah sure, you'd just connect the turn signal input (where you'd normally plug in backup wire) to the HIGH output from the module. No problem! Both the brake and turn lights would act as both brake and turn signal.
Sure you'd just need to connect the bare wire (where you'd plug in the backup wire) to the brake light.
The paper installation instructions that come with the kit will include a number of different scenarios so you can make a custom connection if you'd like! Two t-taps will be included, so you can make the connections yourself if you'd like to make the old turn signal light up as the brake, still light up as turn, or do both, if you'd like, instead of connecting it to backup.
John C.
Diode Dynamics
Old 10-14-2014, 08:10 PM   #50
Diode Dynamics
We cannot offer it at all right now at all in this initial run.
If we do offer it in the future it would probably be a $20 upgrade. Since that would make the kit $50 instead of $30 we decided not to include it for the initial run.
John C.
Diode Dynamics
Old 10-14-2014, 08:59 PM   #51
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
This is awesome. Well done guys!
Quick question: If you have the hyper flash module in place under the steering column, do you need a hyper flash relay in back? My gut says no, but you guys are the experts!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-14-2014, 09:42 PM   #52
mush
mush's Avatar
i dunno how the wiring works, but is it just repining to get it how i want it for the toms?
Old 10-16-2014, 01:20 AM   #53
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Ordered!
Old 10-16-2014, 09:03 AM   #54
The Slow One
Track Junkie
Drives: Argento Scion FR-S
Just placed a order! I went back to stock taillights and this is perfect!
The Slow One is offline   Reply With Quote
Old 10-16-2014, 12:09 PM   #55
*LongFella
*LongFella's Avatar
Add me to the list! Paypal sent! Woohoo!
Old 10-16-2014, 01:19 PM   #56
zeal86
zeal86's Avatar
Drives:
very cool product... placed order!
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
Adjustable TURN SIGNAL LEDs for FR-S & BRZ ~Choose color & brightness~ Plug-N-Play KI_ZN6 Exterior Parts - Lighting 685 02-18-2016 11:03 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-06-2014 11:24 PM
Quickets AND Cheapest Turn signal and DRL LEDs? BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 2 06-17-2013 09:52 PM
