Old 10-12-2014, 05:51 PM   #155
mig86
Drives: MY15 86 GTS
I'm 90% sure I have the CAN command to place the system into the same state as the pedal dance.
Need to do more testing, but my laptop battery has died so I waiting for a new one to be delivered.
I'm thinking that it would be best to package this up inside an OBDII connector. If you want that mode just plug in and forget. When you don't want it just remove the plug / dongle.
Plug 'n play!
Sent from my GT-I9100T using Tapatalk
mig86 is offline   Reply With Quote
Old 10-12-2014, 06:14 PM   #156
joshb86
Drives: '13 FR-S
Plug 'n play!
Excellent idea! You already have power and everything else you would need. For the people that just had to have the device + something else running vis obdII at the same time, you could make it a pass through: http://www.ecutool.com/proimg/Smart%..._3599017_A.jpg
joshb86 is offline   Reply With Quote
Old 10-12-2014, 08:28 PM   #157
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
The form factor for that would have to be a right angle package, or you would need to remount the factory obd plug as it points down to your right leg.
It's made for a PCB but if you modified it maybe you could use something like this? http://www.aliexpress.com/item/OBD2-...FbRzMgodxG0A-Q
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-13-2014, 02:57 AM   #158
troek
troek's Avatar
Drives: 2012 Toyota 86
Not sure if its been posted, but companies already sell these.
troek is offline   Reply With Quote
Old 10-13-2014, 03:05 AM   #159
mig86
Drives: MY15 86 GTS
@troek do you mean obd vsc off devices? I have seen devices that replicate holding the button, but not enabling the pedal dance via CAN bus.
Can you share a link?
Old 10-13-2014, 04:01 AM   #160
troek
troek's Avatar
http://revspeed.jp/special/2013/11/p12786brz.php
From what i can tell it puts it in pedal dance mode, although im not 100%
Old 10-13-2014, 04:14 AM   #161
mig86
Drives: MY15 86 GTS
Cool. Thats exactly what I was thinking of putting together.
$80 is a bit steep.
Might still be worth making if the price is lower. Maybe $25-50?
Thanks for sharing the link.
Old 10-13-2014, 04:58 AM   #162
troek
troek's Avatar
Haha if it was 80 dollars id have one. 2万8000円 is 28,000 yen, roughly $280.
Old 10-13-2014, 05:08 AM   #163
mig86
Drives: MY15 86 GTS
Oh. I missed the 2 there...... I can definitely undercut that, no sweat.
Old 10-13-2014, 10:44 AM   #164
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Plug 'n play!
If you don't mind sharing (pm is fine) I may be able to test it and possibly compare against what the Toyota techs use.
robot is offline   Reply With Quote
Old 10-13-2014, 10:56 AM   #165
robot
Somebody ought to write a plugin for the torque app that does this. It shouldn't be that hard. He has an api (I think) and stuff already set up. All you need to do is crib off one of the examples that makes something with a button and send the proper CAN command when pressed.
http://torque-bhp.com/wiki/PluginDocumentation
That buddy club thing is about $260 BTW. Parts for this should be around $150 max.
Old 10-13-2014, 03:22 PM   #166
mig86
Drives: MY15 86 GTS
Actually the parts are around $10 in low qty. I build this type of thing all the time.
Utilising the torque app is a good idea, but won't suit everyone as it's not an convenient an I don't think most people race with their phone on them... do they? I dont know.
Actually the blutooth elm interface for the torque app illustrates the cost of this type of hardware. I bought mine for $9 free shipping.
Code is just std Toyota command.
Old 12-29-2014, 10:17 AM   #167
pleong
Drives: 2013 Whiteout FR-S
I'm getting a little confused.. which one of these switches will completely disable traction control? I saw mig's button but he referred to holding down the trac button for 3 seconds.. and i believe that's not fully disabling it correct? only the "pedal dance" will fully disable it? So which one of these switch methods will do the same as the pedal dance? A link would be greatly appreciated
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 12-29-2014, 10:49 AM   #168
robot
Where can I find the "std Toyota command"?
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 04:43 AM
Permanent Optimum opti-coat 2.0 ?? Ericfrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 09-04-2012 02:11 AM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 08:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
