Old 10-04-2014, 01:35 AM   #1
iBoost
Drives: Subaru Forester XT
Question Dual Oil Coolers in "fog light duct" area?
Has anyone tried using dual oil coolers on the brz / fr-s? i.e. replacing the location of the fog lights with a duct and mounting the oil coolers recessed in each front wheel well at an angle (with sealed duct attached).
This would not impede airflow through the radiator, but would it cause any other problems with pressure drop or does it work fine?
iBoost is offline   Reply With Quote
Old 10-04-2014, 02:08 PM   #2
pitstops
Drives: SC RB FRS
i believe hks has one
pitstops is offline   Reply With Quote
Old 10-04-2014, 06:16 PM   #3
jflogerzi
jflogerzi's Avatar
iboost, you don't need dual oil coolers. If you search around here is what you can do to combat heat in the engine bay:
-Vented Hood
-Remove OEM crash beam. This allow way more fresh air in(Get a drift bar)
-Get a 19-22 row oil cooler and position it off to the side and create a duct work. Look at AVO's kit.
Do these things and you will be good to go for most driving with a turbo setup.
Old 10-05-2014, 01:29 PM   #4
mrk1
Drives: Sterling BRZ Ltd
Older photo from mock up but this is where I mounted my cooler, only 1. Intercooler piping is on the other side and I don't see a need for 2.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-05-2014, 04:30 PM   #5
iBoost
mrk1,
your oil cooler location is exactly what I had in mind. How many rows is it and which brand / model? Lastly, how well does it perform for you?
Thanks .
Old 10-05-2014, 04:32 PM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I had a top mount single oil cooler but oil temps where too low. I'm turbod as well.
Old 10-05-2014, 06:35 PM   #7
dabocx
dabocx's Avatar
Drives: Scion FRS
Full blown and MAP have a 19 row system that goes there, should be enough even for FI guys. A 25 row should also fit there if you want to piece something together
dabocx is offline   Reply With Quote
Old 10-05-2014, 08:35 PM   #8
sw20kosh
Drives: 2013 Black FR-S
Depends what you use the car for. Do you want to track/hpde?
Old 10-05-2014, 10:17 PM   #9
mrk1
Originally Posted by iBoost View Post
mrk1,
Thanks .
It started as a mishimoto, the core is theres and the sandwich plate. Everything else I made myself. Been working great so far.
The Build Thread
Old 10-08-2014, 04:11 PM   #10
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
One but with proper airflow seems quite enough for me
Efferalgan is offline   Reply With Quote
Old 10-08-2014, 06:00 PM   #11
vroom4
I have a @Maximal Performance kit that was used to build a prototype that would be a good start for you. Terry could source you whatever length hose you needed youd just have to build your bracket. Let me or Terry know if you are interested.
http://store.maximalperformance.com/...i-1981916.aspx
vroom4 is offline   Reply With Quote
Old 10-09-2014, 09:07 AM   #12
Maximal
Maximal's Avatar
Drives: Dodge Stealth
Yep, as long as you can figure out a mounting spot I can make the lines whatever length you need or get you a larger core. We carry Setrab which is going to be the best you can find.
Maximal is offline   Reply With Quote
Old 10-09-2014, 03:56 PM   #13
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
This is what I have as well with the HKS oil cooler kit.
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 10-12-2014, 04:05 PM   #14
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Here is my solution:
Pitman is offline   Reply With Quote
brz, dual oil cooler, fr-s, frs, oil cooler
FS: Subaru BRZ/Scion FR-S 2.5" Dual Exit Axleback Exhaust w/ 5" mufflers LPC_FRS Engine, Exhaust, Bolt-Ons 7 08-25-2014 12:33 PM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
DRL + "Eyebrow strip" dual operation? Weeber BRZ First-Gen (2012+) — General Topics 3 11-26-2013 01:35 PM
350z style "ram air duct" BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 17 03-09-2013 11:01 PM
Best Short Film Commercial for FR-S so far - "Area 86" by Toyota Philippines) poudre FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 74 09-28-2012 12:19 AM
