Old 10-09-2014, 03:10 AM   #1
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
Pressure washer?
Can anyone help me pick out a good pressure washer that lasts? Looking for something in the sub 200 dollar range.
I had to come here because reading reviews on many say that they don't last for more than a season....which makes choosing pretty hard =/
Instagram: 8as6
CyberAkuma is offline   Reply With Quote
Old 10-09-2014, 06:08 AM   #2
Ec1990
Drives: '14 BRZ
I picked up my Simpson electric washer from Costco. It was roughly $150, the real benefit is if it ever breaks it's free to replace.
Connects to a foam cannon with a Bosch fitting relatively well but not perfect.
AR makes a relatively cheap electric washer from Lowe's quality is good overall but parts can be hard to find as they're specific by AR only.
Ec1990 is offline   Reply With Quote
Old 10-09-2014, 01:01 PM   #3
Stay Fresh Car Care
Stay Fresh Car Care's Avatar
Drives: STI
We are about to post a review about the Greenworks 1500 you can purchase from Lowes.
Follow us on Instagram @stay_fresh_car_care
Use the code FT86 at checkout to save 10% off your next order at www.stayfreshcarcare.com
Stay Fresh Car Care is offline   Reply With Quote
Old 10-11-2014, 01:09 AM   #4
cnk
Drives: '13 DGM BRZ Limited
I have a Karcher K5.740 X-series electric. Works great and you can use an adapter to use the foam cannon that is popular among detailers. It's a little over the $200 price range, but I think it's worth it as it's electric motor is water cooled and the unit gets great reviews.
Old 10-13-2014, 02:30 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Have the same one. Don't really need anything fancy if you're just using it for a car.
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Ec1990 (10-13-2014)
Old 10-13-2014, 08:55 PM   #6
Ec1990
Drives: '14 BRZ
Agreed. It works simple as that.
If I needed more I'd just jump to a gas engined version.
Old 10-13-2014, 10:12 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
I have the 1650psi Harbor Freight special. Can be found on sale or used with a coupon otherwise its $100.
Works decent with a foam cannon, been 2 years going strong washing pretty much every other weekend.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-13-2014, 10:28 PM   #8
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Just got a SunJoe SPX3000 and tried it out for the first time Friday.
The thing lasted about 0.22 seconds before the motor went silent for good. Literally turned over for a fraction of a second and dead.
So, so much for getting some powerwashing done this weekend. I called the manufacturer and they're sending a new one via ground shipping yay.... :/
I'll let you know how it is if/when I get a working model. The reviews on Amazon have been pretty good so I am cautiously optimistic that it was just a fluke.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 10-14-2014, 01:21 AM   #9
Poodles
Drives: 2015 Series.Blue
I'm paranoid of AC voltage and water, so I go the gas route...
Old 10-14-2014, 01:39 AM   #10
Ec1990
Drives: '14 BRZ
That's why it's highly recommended to use a GFCI outlet and mine has a separate breaker on the pressure washer itself that should be tested before being used.
Old 10-14-2014, 02:04 AM   #11
...for less than 200 bucks?
Old 10-14-2014, 01:58 PM   #12
Ec1990
Drives: '14 BRZ
Sales from time to time can be found in the $170 range.
Old 10-14-2014, 02:54 PM   #13
Wow! I'll have to start looking. Great tip.
Old 10-14-2014, 03:05 PM   #14
Not a problem for OP, I am sure, but anybody that has freezing temps remember to bring your washers in!
Have gone through way to many over the years because I waited just a little to long and it only takes a couple of degrees below freezing to totally destroy the things.
All those nice narrow passages freeze up FAST!
Son works at an auto parts/hardware store and says they get many back every spring that just suddenly "developed a leak" after sitting in an unheated garage or shed over the winter.
pressure washer
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 05:08 PM
Crush Washer for AT BRZ888 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-27-2014 11:06 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
FS: 1300psi Pressure Washer and Gilmour Foam Gun(Nozzle) ($70) kanundrum Mid-Atlantic 13 07-17-2013 11:10 AM
Pressure Washer $60 at super store Aznek CANADA 6 09-10-2012 12:08 PM
