#5433 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
Wah wah waaaaahh So do you not sell the kit with a Delicious tune? Also your website says the intercoolers are out of stock. Does that mean, you don't have any kits with intercoolers? Or are you just out of the intercooler upgrades?
-Jack Burton |
#5434 | |
Drives: 2014 FT86
I won't touch the issue of Innovate's contract with a 10 foot pole. That subject is off limits, even for me. Better to be frank than fluffy on that one. Intercooler upgrade kits are on the way. I don't know if I will have these before SEMA. Were still adding stock here in the new warehouse. I have new intercooled and non-intercooled complete systems and 69mm pulleys. |
#5435 |
Drives: 2013 FR-S Argento
#5436 |
Drives: 2013 GT86
Coolant Help
Just installed the intercooled blower a week ago and done 400 km so far and I seem to be losing coolant whenever I go complete WOT 6000+ rpm. Last run I made today for about 10 minutes with several WOT pulls, coolant went down another 1 cm. Feels like I've topped up the coolant bottle half a litre more in total so far. Regular driving and low pulls the coolant seems to hold steady. No visible leaks as far as I can tell around the engine bay. Any suggestions much appreciated cheers |
#5437 | |
Drives: 2020 DGM BRZ Limited
#5438 |
Drives: 2013 GT86
I'm hoping it might still be bleeding but my mechanic reckons based on the 3L bottle he picked up for my install we're over 2.25L by now
#5439 |
2.2 liters was the amount listed for the install (2200 ml) so you are in the ball park. If it continues to drop check the entire system for leaks. I believe one guy on here reported a crack in the core that was leaking internally - hope that's not the case for you.
#5440 | |
Drives: 2013 GT86
![]() hopefully not
#5441 | |
Sent from my SGH-I337M using Tapatalk |
#5442 | |
PhoneFlash by EcuTeK
Cheers, William Knose Delicious Tuning |
#5443 | |
Thanks Sent from my SGH-I337M using Tapatalk |
#5444 | |
Drives: GT 86
That's what I thought you meant as well cause I asked the same question in my post on the previous page but William must of missed it and also would like to know if the tune is compatible with headers which I think it would be but not sure.
#5445 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
You're not going to see similar results because gasoline requires more air than E85 to burn. At least some of the power you make with E85 comes from the fact that you can burn more of it for the same volume of air.
Obviously a comparison to nitromethane is ridiculous but it works much the same way. Nitro has less energy density than gasoline but you can literally burn almost 9 times as much nitro with the same amount of air, so you can make absurd power. |
#5446 | |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
