Old 10-10-2014, 12:12 PM   #1
FR-S89
For those who do their own maintenance
What if something goes wrong with the engine, transmission, etc.?
I do my own maintenance, oil, filters, breaks, etc. But just realized, if something were to get wrong with the engine then I don't have any way to prove I did the required oil changes... would my warranty still be valid?
Should have held on to my receipts when i bought the oil + filters but not sure if that would even be sufficient considering I'm the only performing the oil change.
FR-S89 is offline   Reply With Quote
Old 10-10-2014, 12:18 PM   #2
Yep, you should have!
A lot depends on your dealer. There are several threads on this subject and most have had issues with the dealer wanting proof.
There is no issue with doing it yourself but you will need to be able to prove it was done.
If you bought the supplies with a credit card you may be able to get records that way but cash or debit will not likely help.
Old 10-10-2014, 12:23 PM   #3
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
if you have a warranty and the work is free why are you doing stuff your self?
Digitalanalog is offline   Reply With Quote
Old 10-10-2014, 12:40 PM   #4
FR-S89
saves time + i know what oil im getting
quick oil change before a wash
Old 10-10-2014, 12:41 PM   #5
Shady195
Drives: '13 10 Series FRS #1203
I have a folder I keep, everything related to the car I buy or thats done regarding maintenance gets a receipt saved as well as a note with mileage
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
BRZ21 (10-14-2014)
Old 10-10-2014, 12:45 PM   #6
FR-S89
so basically you guys are saying im shit outta luck?
This is my first time buying a new car still under warranty and i didn't think about this.. think i messed up big time.
What if i start collecting receipts now?
Old 10-10-2014, 12:53 PM   #7
Chrono
Chrono's Avatar
Drives: '13 WSP BRZ
What's your mileage and how long have you owned it?
2013 BRZ Limited 6MT, White Satin Pearl
2012 Triumph Street Triple R, Phantom Black
"Treat all tires like they deserve to die!" -Chris Harris
Chrono is offline   Reply With Quote
Old 10-10-2014, 12:57 PM   #8
Shady195
You could always go to the store you bought the oil from, its possible they would be able to pull up old purchases and print them out for you...
Only reason I mention this is a co-worker of mine had an engine go in his Rav4, they were going to deny him because he was missing a few reciepts.. Ended up going to wherever it was he bought the stuff and was able to pull it up via his credit card.
Old 10-10-2014, 01:01 PM   #9
FR-S89
30,000km
owned it for 18 months
did 4 oil changes, don't have receipts for any of them think I paid debit each time
Old 10-10-2014, 01:40 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
What work is free? The first free oil change? Yeah I've seen too many stripped oil pans, missing or doubled crush washers, grease stains and missing fasteners to take my car back to any dealership for any reason.
With regards to the OP, receipts are usually considered proof enough that you've done the maintenance, if you bought the oil online then the vendor likely can dig up a copy, not sure about local auto parts stores it might be worth a shot.
I'm at 31k miles (~50k km) haven't been back to the dealer once, I've saved the receipts (or can get copies) and taken pictures to document some of my maintenance, hopefully I'll be lucky to 60k or any serious problems wind up with a full recall...
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
BRZ21 (10-14-2014), roddy (10-10-2014), Texas BRZ (10-24-2014)
Old 10-10-2014, 02:30 PM   #11
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I do all my own work. Try to keep receipts, but sometimes I forget. What I usually do though, for all in-warranty oil changes, is take a pic on my phone when I'm doing the oil change of the new oil and filter in the engine bay of the car. It is date stamped, so I at least have that as a record.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
Tcoat (10-10-2014)
Old 10-11-2014, 12:16 AM   #12
30,000km
If you paid by debit or credit card, you should be able to retrieve the record of sale.
I would suggest you start a maintenance log (bound notebook), post dating when you did the maintenance, what you did and what parts/or fluids you replaced.
That may satisfy the dealer that your car has been maintained properly...
Old 10-11-2014, 12:29 AM   #13
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The original factory warranty doesn't include free work.
The dealer may throw in some oil changes or something but it has nothing to do with the factory warranty.
Old 10-11-2014, 02:22 AM   #14
Mini Cooper S
Mini Cooper S's Avatar
Drives: '16 MX5 rip '14 FRS
If you do your own maintenance, you'll do your own engine, transmission, etc. at least that's what I'm trying to learn.
Mini Cooper S is offline   Reply With Quote
Going for maintenance with coilovers on ang31ito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-13-2014 07:33 AM
25,000 Where can I go for maintenance. laley81 Southern California 9 09-20-2013 04:00 AM
Winter Maintenance Chinadian CANADA 21 01-25-2013 02:32 AM
Maintenance Required? Dan86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 01-23-2013 01:58 PM
Recommended Maintenance blunova Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 51 01-04-2013 08:47 PM
