Old 09-21-2014, 08:16 PM   #155
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by OmarGC View Post
Looks like I'll be running the @FullBlown walbro 485 fuel pump kit
I'm going to run the same kit in a return setup. Once I upgrade the rear end I'll be putting in a triple pump surge tank.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 10-09-2014, 03:38 PM   #156
inertia
inertia's Avatar
Looks like I'll be running the FBM walbro 485 fuel pump kit
How much power can that support?
inertia is offline   Reply With Quote
Old 10-09-2014, 04:51 PM   #157
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
IIRC little over 600whp on e85 and 800+ using gasoline
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
inertia (10-09-2014)
Old 10-09-2014, 04:53 PM   #158
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
That's definitely backwards....
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 10-09-2014, 04:59 PM   #159
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Negative... You need a lot more fuel flow with ethanol than gasoline. You have it backwards...
Omar GC
Instagram: 2jzus
Old 10-09-2014, 05:01 PM   #160
Acree
Acree's Avatar
You are correct. I misread and thought you were answering a question regarding the engine. I was like "I've never seen someone run more power on pump than E85...." My bad!
The Following User Says Thank You to Acree For This Useful Post:
OmarGC (10-09-2014)
Old 10-09-2014, 05:03 PM   #161
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Its all good!
Omar GC
Instagram: 2jzus
Old 10-09-2014, 05:31 PM   #162
inertia
inertia's Avatar
Thanks dude!
Old 10-10-2014, 04:24 PM   #163
TWMPerformance
Drives: Manual Transmission, All the Way!
Wow dude, you have great taste
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 10-10-2014, 05:10 PM   #164
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Renato
Thx.
Omar GC
Instagram: 2jzus
TWMPerformance (10-27-2014)
Old 10-17-2014, 07:25 AM   #165
slicktop
https://m.facebook.com/story.php?sto...62711873758009
-slicktop
2013 Scion FRS
Old 10-24-2014, 08:37 PM   #166
the puppet master
2013 Whiteout
the puppet master's Avatar
Drives: 2013 whiteout
Great build so far Omar... Loving the ZE's
Subscribed!
the puppet master is offline   Reply With Quote
The Following User Says Thank You to the puppet master For This Useful Post:
OmarGC (10-25-2014)
Old 10-26-2014, 03:47 PM   #167
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Rattle canned my old busted ass spark plug/cam cover with the stuff I had left behind from painting my stock wheels 2 years ago. Pretty close match.
Omar GC
Instagram: 2jzus
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
inertia (11-18-2014), TWMPerformance (10-27-2014)
Old 10-27-2014, 04:35 AM   #168
the puppet master
2013 Whiteout
Not bad for rattle
BRZ- Lemon? laxfogo Issues | Warranty | Recalls / TSB 24 04-05-2013 05:15 PM
So my FR-S is officially a lemon... frsinpa Scion FR-S / Toyota 86 GT86 General Forum 90 01-19-2013 11:50 AM
Anyone thinking about lemon law? Accurate Race Shop Issues | Warranty | Recalls / TSB 16 10-18-2012 09:11 AM
Lemon? grgonium Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2012 10:13 AM
