#141 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Car looks so odd without the FMIC
![]() ![]() ![]() Rear fitment, going to do a little more work to the quarters ![]() ![]() ![]() ![]() And yes, that's hearing protection that stays in my car lol
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus Last edited by OmarGC; 09-12-2014 at 08:54 PM. |
#142 |
My FR-S has 5 gears
Well some more has changed...
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#143 |
Drives: bucket
about your plate....
I thought all Supras were FR. Just playing... car looks amazing. bold choice to do this swap and try and keep it low budget. it's members like you that help pave the way for others who want something similar in the future. thank you. |
#144 |
My FR-S has 5 gears
Got bored today and wanted to see how much the Treadstone TR10 filled the bumper opening. I'm 85% content with how much it filled, which I'll live with as it's was pretty cheap and scored a decent deal on it brand new. Keep in mind when it's actually mounted the bumper cover will be trimmed and the core will sit quite a bit lower and further inward, literally just wedged it into the cover to see how much of the length of the opening it took.
Omar GC
#145 |
My FR-S has 5 gears
Overall satisfied with the quality of the core, cast end tanks are pretty nice.
Omar GC
#146 |
#1 Toyota Fan
Drives: 85 SR20 AE86, 95 RB25 S14, 94 FD3S
Great thread bro! Watchin u from the NW, just picked up a frs, 2015. workin on suspension during the winter but not sure what to do about the motor.. I wanted to boost the stock but bro i think i just wanna slap a LS or 2JZ in this bitch and call it a day. Can't wait to see how your car turns out, if you do it for $8k its a no brainer for me
#147 | |
My FR-S has 5 gears
I have kinda compiled some last minute extras that were completely unnecessary so when I get the car completed I'll make a break down of the cost with both needed items and items that are more so "desires". Also will give my final total after selling off my old parts.
Omar GC
#148 |
My FR-S has 5 gears
Omar GC
#149 | |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Someone on Supraforums said:
In fact, our builds don't even really show on google without specific terminology. It's all sponsor builds (E.kanoo, Tuerck, etc) |
#150 |
Drives: 2014 Scion FRS (Ultramarine)
What about all of the accessories? Power steering, A/C, heat? No need?
#151 |
There are still other mods that are needed to support the power which I have not seen you mention. Mods such as...
axles rear-end driveshaft turbo manifold suspension upgrades a legit tune fuel system (pump, lines, fittings, filter, regulator, and so on) |
#152 |
Hey, come to my thread next.
#153 | ||
My FR-S has 5 gears
Rear end- assuming you mean rear diff, I'm more then confident with the oem rear diff holding above 500whp. Did plenty with altezza/is300 rear diffs throughout my life in Japan with numbers above what I'll be making and also have a spare altezza diff with a 1.5 way LSD. My single isn't very large and I doubt I'll see above 500whp ever. Driveshaft- custom DSS Aluminum or steel one piece, both stupid cheap. Turn around time after giving needed specs is less than 3 weeks. 1 piece steel shaft is still significantly lighter than oem chaser/supra/etc DS and I'm not very fond of lightening the driveline/powertrain in excess and I'm already lightening in other areas so I'll likely go the steel route due to my uncommon preferences. Exhaust manifold- have been given a manifold off my friends 2j 850+ whp s14. No clue what it is, but it'll be here sometime next week. Wastegate- running a turbosmart 38mm as I felt no need to go with a 44mm gate as I no longer plan to run <14 since I will no longer be using stock Jdm aristo twins. (Gate was given to me for a case of beer). I know some awesome people Suspension- custom front sway or no front sway at all(we'll figure this out when I redo my spring rates/valving/likely different coils in general). Currently on stance ss+ pros, white line rsb, adjustable rear control arms, bunch of random minor bits along with the stuff mentioned above. Tuning- running dual ecu setup with the 2jzgte ecu being commanded with an apexi piggyback which will be tuned by a personal friend from Speed and Sound STL(well known jz tuning shop). Will switch over to ProEFI or AEM standalone with time, just trying to get it on the road without initially to show it can be done for a lot less than what's being tossed out. Who knows, if the piggyback does well I'll keep running it as the oem vsc/TCS will remain fully functional. Fuel- fuel pump I'm still very undecided on what pump to run, but likely just the largest drop in tank I can find(frs fitment) unless we figure out a good way to run a large supra pump in tank, leaning towards making a bosch 044. As far as lines Chase Bays builds a frs to 1/2jz adaption kit in which will be ran with a Hybrid Racing FPR to stock aristo fuel rail and usdm 550's.
Omar GC
#154 |
My FR-S has 5 gears
Looks like I'll be running the @FullBlown walbro 485 fuel pump kit
Omar GC
| BRZ- Lemon? | laxfogo | Issues | Warranty | Recalls / TSB | 24 | 04-05-2013 05:15 PM |
| So my FR-S is officially a lemon... | frsinpa | Scion FR-S / Toyota 86 GT86 General Forum | 90 | 01-19-2013 11:50 AM |
| Anyone thinking about lemon law? | Accurate Race Shop | Issues | Warranty | Recalls / TSB | 16 | 10-18-2012 09:11 AM |
| Lemon? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-08-2012 10:13 AM |
