Old 10-09-2014, 03:55 PM   #155
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I could buy this. Seriously. Will you offer install with any local shops?
Old 10-09-2014, 04:05 PM   #156
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by s2d4 View Post
NA builds, SC builds and turbo builds all have their differences.
Some are applicable, some aren't. Just the way it is.
Are you saying you want them to develop a turbo kit specifically around the OFH?
Think in terms of: "It would be nice If I won the lottery". "It would be nice if there were no wars". I just thought it would be nice "if the open flash header was modular and could be used for everything from NA, to super, to turbo". I understand I might as well wish my car had wings and could fly.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-09-2014, 05:00 PM   #157
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
OFH could be used with a PTuning style turbo kit... Just saying.
- AdrianG
AdrianG is offline   Reply With Quote
Old 10-10-2014, 01:03 AM   #158
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Shiv@Openflash View Post
Why? It won't sound any different than a EL manifold. The turbo blades chop up the exhaust pulses and improve cylinder filling during even light load operation. More effective than any forum of exhuast pulse tuning on an NA engine.
It is exactly what @alexand3r said. Subarus are know for that boxer growl only because of the UEL header. If you look at the current SBD header design, you could simply swap the pipe orientation. Here is what I mean.
Current SBD Header:
Motor Header
Front
12 12
34 34
Back
UEL Header Design:
Motor Header
Front
12 43
34 12
Back
This would make the runner length of the front and rear cylinders different. I am not sure how it would affect the sound exactly though.
Luckrider is offline   Reply With Quote
Old 10-10-2014, 01:56 AM   #159
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Shiv and team, will the 350 kit work with AT cars?
I would expect a cooler would be needed but otherwise...?
F1fletch is offline   Reply With Quote
Old 10-10-2014, 03:11 PM   #160
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
@Shiv@Openflash
Does the OFT300 have an e85 option?
Cockatoo is offline   Reply With Quote
Old 10-20-2014, 03:46 PM   #161
football751
Drives: n/a
Current SBD Header:
Motor Header
Front
12 12
34 34
Back
UEL Header Design:
Motor Header
Front
12 43
34 12
Back
I believe what Shiv is saying is that with the turbo you get the same sound with an UEL or EL, because the turbo is in the gas path. With NA or SC it makes a difference, but not with a Turbo. Though I could very well be mistaken, I believe that's what he meant.
football751 is offline   Reply With Quote
Old 11-05-2014, 08:30 PM   #162
Anh5oi
Drives: 13 FRS
Where is the 350 kit??
Current: FRS(Daily), Cayenne(Weekend), 1000RR(Fun), 650Maxim(Fun).
Recently Sold: 13 Boxster(Crash), 08&10 335i, 08 M3, 12 A4, 97 NSX....
Anh5oi is offline   Reply With Quote
Old 11-12-2014, 02:08 PM   #163
ShaunNeutron
ShaunNeutron's Avatar
Drives: BRZ Limited Manual CBS
I called and asked about the OFT350 yesterday and was told I should expect to see something within the next two weeks. Fingers crossed :-)
ShaunNeutron is offline   Reply With Quote
Old 11-18-2014, 05:47 PM   #164
toast
Drives: 14 BSP Edelbrock BRZ
You are correct in your interpretation of what he said, but I don't think what he said is true. If a turbo truly chops up the air enough to cover up a manifold then no turbocharged subaru (such as an STI) would have a 'boxer rumble'. And the video above shows pretty clearly the sound difference between an UEL manifold (AVO) and an equal length one.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
RobertPaulson (02-24-2015)
Old 11-18-2014, 06:06 PM   #165
Luckrider
Luckrider's Avatar
The problem is, this kit is sourced from a turbo supplier which was speced out by SPD. This is the same company that makes the Greddy turbo. This would require an entire redesign just to get the sound. I understand why they don't do it, but you are right, UEL obviously can be heard with a turbo.
Old 11-18-2014, 11:53 PM   #166
s2d4
s2d4's Avatar
No it isn't. Good to see their marketing worked.
Old 11-18-2014, 11:59 PM   #167
Luckrider
Luckrider's Avatar
Explain then.
Old 11-19-2014, 12:30 AM   #168
s2d4
s2d4's Avatar
Explain then.
@Dave-ROR
Introducing, the widow. IloveBaldEagles Member's Car Journals 7 05-02-2014 11:47 AM
Introducing myself fz6r Scion FR-S / Toyota 86 GT86 General Forum 11 02-14-2014 02:54 PM
Introducing myself and my FRS Apes Six Scion FR-S / Toyota 86 GT86 General Forum 11 07-12-2013 04:51 AM
Introducing the PHR Clutchline Powerhouse Racing Engine, Exhaust, Transmission 12 09-11-2012 05:47 PM
Officially Introducing The Audi A1 vh_supra26 Other Vehicles & General Automotive Discussions 26 06-23-2011 01:19 AM
