Old 10-02-2014, 04:37 PM   #15
nfaj
Drives: 2015 BRZ limited 6MT
Random fluttering/flapping sound when coming to a stop
[ame]http://youtu.be/r8uk71jvpmY[/ame]
Here's the vid . Pls take a listen and see if this isn't engine knock . Appreciate it !!!!
EDIT sound happens after 1min mark
nfaj is offline   Reply With Quote
Old 10-03-2014, 10:24 AM   #16
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
I had the same exact sound. I don't think its knock. I think its the flywheel. I started holding the clutch while slowing to a stop and I don't hear it anymore. Im pretty new to MT so perhaps someone who knows more than me can chime in.
Sent from my Galaxy S4 using Tapatalk
AllStar0419 is offline   Reply With Quote
Old 10-03-2014, 10:47 AM   #17
nfaj
It's def the engine and not the flywheel.
I can differentiate with flywheel chatter when operating the car in low engine speed. That's when I normally hear the flywheel
Old 10-03-2014, 03:12 PM   #18
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah... guys, as stated earlier, cars, and sports cars in particular, are not meant to accelerate from that low of RPM. If you have a manual, downshift, or at least slip the clutch more when around 1k RPM. If you're using the auto paddle shifters, just don't let it fall that low.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-04-2014, 02:44 PM   #19
Muckraker
Drives: 2014 FR-S
Mine makes that same sound all the time. Noticed it in the first week or two after I bought it new.
Based on what I've read on the forums, it's a common sound and supposedly nothing is wrong with the car.
It happens when coasting to a stop while in neutral and the engine is at idle speed.
Pressing on the clutch pedal seems to stop it.
And if the air conditioner is turned off, it seems to not happen.
Muckraker is offline   Reply With Quote
Old 10-04-2014, 02:53 PM   #20
nfaj
True that ! Thanks for the info
Old 10-08-2014, 02:40 AM   #21
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
I've noticed this sound as well, and it's definitely connected to the RPM drop. Mines an auto, and I only hear it while stopped and idling, with the AC on. Recently, I've also heard what sounds like a muted jackhammer for about 1 second, when the AC clicks on the the RPMs drop. I'm bringing it in to the dealership this weekend to check it out. I have about 16k miles.
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 10-08-2014, 12:44 PM   #22
tomkozski
Drives: 2017 WRB BRZ w/ PP
Originally Posted by Shutter View Post
Nope, not detonation. Just the sound of the engine almost dying!
Since the rpms drop so much, it causes the engine to feel rough/jerky. I don't wanna say its "normal" but its no harm to the engine. Just feels weird, thats all. If you pick up an OFT, and run one of the base maps you shouldn't have an issue with this anymore.
There's a TSB out there for the RPM drop, if you believe the RPMs drop too much. It's a ECU update - had it done on my BRZ and it solved the RPM drop when the a/c is on.
tomkozski is offline   Reply With Quote
Old 10-08-2014, 01:52 PM   #23
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
yup, x2. I know some people have had issues with their dealer not doing it unless they can "prove it". But if you bitch enough, they should do it for you. It is a TSB after all.
Unless its really horrible, I avoid the dealership as they may fix something that ain't broke or wash my car with sandpaper.
Old 10-08-2014, 01:56 PM   #24
stonenewt
Drives: BMW 120d
^^ that sounds like anti-stall when the revs have run very low. Normally this is due to bad mapping causing excessing rev drop when entering an idle state. As others have said there's a TSB out so my guess this is what your car is doing.
stonenewt is offline   Reply With Quote
Old 10-08-2014, 04:13 PM   #25
nfaj
Idk if my car is eligible for a tsb since since its a 2015
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 01:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 01:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 08:34 PM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 10:27 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 02:17 AM
