Old 10-03-2014, 05:08 PM   #1
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Innovate/Sprintex SC installation Tips or Notes
Hey everybody! I bought a Stage 2 intercooled Innovate SC (and 70mm Raceseng pulley) from a fellow forum member, and am going to install it next weekend. I was hoping that others that have installed one before might be able to give some tips, notes, or what to watch out for on the installation process. My car is a manual 2014 BRZ, and is currently completely stock.
I'll be doing this install on some ramps out in the driveway, so no access to a lift. I already have an EcuTek cable and tune from Delicious Tuning. Is there anything else that I will need or should do before the installation? The previous owner has changed out the plastic hose fittings to brass ones, and upgraded the allen head bolts that tended to break off. Any and all advice welcomed.
Thanks in advance
CarzCarzCarz is offline   Reply With Quote
Old 10-04-2014, 12:14 AM   #2
J.C.
Drives: '13 Raven FR-S
I found it very useful to label all existing hoses/ components with masking tape as well as all the parts included in the kit. Keep track of your work, stay organized, and be patient with each step is my advice.
Also helps to have another set of hands to place the blower on correctly.
J.C. is offline   Reply With Quote
The Following 2 Users Say Thank You to J.C. For This Useful Post:
CarzCarzCarz (10-06-2014), Dream20b (10-04-2014)
Old 10-04-2014, 12:54 AM   #3
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Where are you at in Texas?
Dustin is offline   Reply With Quote
Old 10-06-2014, 11:45 AM   #4
CarzCarzCarz
Thank you, I'll remember to do that, good advice. I will have an extra set of hands thankfully, I bet placing the blower is not fun alone.
Old 10-06-2014, 11:46 AM   #5
CarzCarzCarz
Houston, by Hobby Airport.
Old 10-06-2014, 11:47 AM   #6
CarzCarzCarz
Another question, I bought some Radium catch cans in anticipation of this instal. How are the hoses routed for the supercharger, and do you really need both catch cans?
Old 10-06-2014, 12:05 PM   #7
harkbrz
Drives: Subaru BRZ 2013
Nope, just send your other one over my way
In all seriousness though, can't hurt. From my understandng the cans are set up to anticipate two different types/scenarios of blow back.
Check Out My Build
harkbrz is offline   Reply With Quote
The Following User Says Thank You to harkbrz For This Useful Post:
CarzCarzCarz (10-07-2014)
Old 10-06-2014, 02:00 PM   #8
J.C.
I'm only running the PCV catch can which is mounted on the passenger side next to the battery. A lot of guys running the Innovate kit report that they weren't catching much on the crankcase side of things.
Of course it doesn't hurt to have both though.
The Following User Says Thank You to J.C. For This Useful Post:
Old 10-06-2014, 05:13 PM   #9
olorin
olorin's Avatar
Drives: GBS Premium
I found this useful when I did my install:
http://www.ft86club.com/forums/showthread.php?t=42754
olorin is offline   Reply With Quote
The Following User Says Thank You to olorin For This Useful Post:
CarzCarzCarz (10-10-2014)
Old 10-07-2014, 11:52 AM   #10
CarzCarzCarz
PERFECT, thank you very much for the link! I searched but didn't find that one, was reading through so many other threads.
Old 10-07-2014, 01:17 PM   #11
brianhj
Drives: 2017 Camaro 1SS
Also Important Topics section in very first post of this thread:
http://www.ft86club.com/forums/showthread.php?t=40066
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
CarzCarzCarz (10-08-2014)
Old 10-16-2014, 04:04 AM   #12
brianhj
Did everyone torque to spec in the instructions? Where can I get a torque wrench with low ft lbs range like that? Some of the values are under 10 ft lbs
Old 10-16-2014, 04:31 AM   #13
CoupedUpSubie
Drives: 2013 BRZ Limited
Best bet is a torque wrench in inch lbs. 10 ft lbs is 120 in lbs. Just about any tool store will have one.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
brianhj (10-16-2014)
Old 10-18-2014, 02:58 AM   #14
brianhj
Exclamation
Which hose is the "crankcase breather hose"? I'm short a hose lol. The one that is extended in step 5.1 goes to the inlet tube so which one goes to the middle connector on the back of the supercharger?
innovate, installation, sprintex, supercharger
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Whataboutbob's Innovate SC Install Notes whataboutbob Forced Induction 8 05-05-2014 01:21 AM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 03:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 08:26 AM
Intercooler options for Sprintex/innovate diss7 Forced Induction 3 02-15-2014 10:03 PM
