Old 10-05-2014, 01:56 AM   #295
veck
veck's Avatar
Drives: 2014 Subaru BRZ
Almost thought something was wrong with mine. Good to know its just normal.
veck is offline   Reply With Quote
Old 10-05-2014, 09:05 PM   #296
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I have another really dumb question, how much knock correction (KC) is acceptable? I updated the tune and ran up and down the road and saw it go anywhere from 2* to 5*. I don't have the light to do a safe datalog tonight, but I'll run one from 2.5k to redline and one cruising and upload them tomorrow after work.
Basically I just want to know if its safe to drive it to and from work tomorrow, or if I should flash back to stock.
Thanks!
Bobblehead is offline   Reply With Quote
Old 10-06-2014, 12:31 AM   #297
steve99
Drives: FT86
Thanks!
KC Learned is not knock its actually knock correction advance and is the amount added to the base timing. It will go up and down as per the values in the Knock Correction Advance Max A table.
For knock you need to log FBKC Feedback Knock control on an OFT this is (Knock Correction) easily confused with KC Learned or KCA, and FLKC Fine learning Knock Control and IAM ignition advance mutliplers. Have a read og the knock corection thread below.
Look for IAM = 1 ideally or very close to 1
FLKC and Knock Correction(FBKC) to idealy be zero but the occasional 0.7 or so is acceptable
Values like -2 or more are a concern
If you getting -5 Knock correction that is not good but I suspect your logging KC Learned
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Bobblehead (10-06-2014), zc06_kisstherain (10-06-2014)
Old 10-06-2014, 12:47 AM   #298
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
In terms of reliability, is it safer to run 91 vs 93 stage 1? Or is it equal?
Currently running 91 tune but still fill up with chevron 94. Shell 91 feels a bit sluggish in comparison, probably due to a timing retard...
Which stage 1 tune do you guys prefer better and why?
Stealthy is offline   Reply With Quote
Old 10-06-2014, 01:04 AM   #299
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
+1, I also suspect you are logging KC Learned and not knock retard. A range of 2 to 5 deg is correct for KS Learned.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 10-06-2014, 02:56 AM   #300
Trettiosjuan
Drives: GT86
91 map on 94 fuel should always be safer because it less aggressive with timing and the fuel should have higher knock resistance. The other way around would be unsafe.
Trettiosjuan is offline   Reply With Quote
Old 10-06-2014, 09:04 PM   #301
Bobblehead
Bobblehead's Avatar
I made a cruising datalog, I'll upload it when I can, but couldn't do a safe 3rd gear pull due to the rain.
My Advance Multiplier stayed mainly at 1. I saw it go to .96, .99, and saw it at 0 in city traffic. I closed and re-opened the realtime data and it was back up at 1. My AFR while cruising at 55mph and 10% throttle was ~14.58 to ~14.74 or so. Under a heavy pull up a hill it got down to around ~12.
Do these numbers check out?
Old 10-06-2014, 09:21 PM   #302
steve99
Drives: FT86
sounds fairly normal. Ideally IAM should be one so their must be a bit of knock in lower rpm range but log will show it.
Try changing brands of fuel some are way better than other even with same octane rating
Old 10-06-2014, 09:29 PM   #303
Bobblehead
Bobblehead's Avatar
OK thanks! Right now I'm on a mixed tank of Kwik fill and Sunoco 93's. I'll run this tank down and test which one is better.
Old 10-07-2014, 12:08 AM   #304
Shiv@Openflash
Drives: 2013 FRS
Exclamation
OFT OTS v2.062 is now available for download. The only change (as documented the change log) is added support for ZA1JD00D calibration ID. No mapping changes otherwise. So unless you have a ZA1JD00D ROM and are waiting for tune file support, there is no need to download this latest release
Cheers,
Shiv
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
CamryDS (10-07-2014), chas3wba0 (10-07-2014), flippy (10-07-2014), papatango1976 (10-07-2014), tmichel (10-07-2014)
Old 10-07-2014, 03:06 AM   #305
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I'm curious why Stg1 91/93 have -14.88 base timing for the soft rev limiter and Stg2 91/93/E85 all have -0.14.
Does this mean Stg2 has a softer limiter and would Stg1 7600rpm be better at -0.14 instead?
I accidentally put the -14.88 from Stg1 in my Stg2 maps and the limiter still threw me forward in the seat.
Thanks
Old 10-07-2014, 03:18 AM   #306
steve99
Drives: FT86
Thanks
seems suspect would think it should be the same seems like a typo as your using same defs and all the other values would be out if def scaling was wrong.
did you check the RPM fuel cut setting ? think its under misc limits folder they need changing as well think it 7600 cut and 7450 resume but check the table in a A01G OFT rom
Old 10-07-2014, 03:22 AM   #307
Wayno
Wayno's Avatar
No, fuel cut is 7600/7550 across the board.
US and EU Stg1 and Stg2 soft limits are consistent across the board. Stg1 = -14.88, Stg2 = -0.12.
Old 10-07-2014, 03:25 AM   #308
steve99
Drives: FT86
That strange, got no idea why that would be -14 does seem a bit savage
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
