Old 09-16-2013, 03:31 PM   #15
jamesm
Originally Posted by FRSTEVE View Post
I didn't see any links to a public file repository for where people can stick their tweaked files (along side some description of their mods for use with that file).
i'm working on that one.. almost finished. just need some of these files to show up in the wild so i can start on some of the more advanced stuff (diffing files, in-browser views on the data, etc).
jamesm is offline
The Following User Says Thank You to jamesm For This Useful Post:
bakerr6 (09-16-2013)
Old 09-16-2013, 03:35 PM   #16
bakerr6
Drives: 2013 raven black fr-s
are base maps going to "update" as more tables are identified/defined?
bakerr6 is offline
Old 09-16-2013, 07:03 PM   #17
lexusb3
Drives: FRS
Originally Posted by mad_sb View Post
Anyone who can mash keys on a keyboard (or if your fancy and have a trained cat that can take you dictation and paw type ) can make tuning changes.
You will start by downloading your currently loaded rom file, send that to the OFT folks who will either create a definition for your ecu id (if they don't already have one) or send you a definition file. By default these are XDF Files used by tuner pro, which is a free download.
You can then install tuner pro, open the XDF file, open your rom and start editing away all you want. Or you can download one of the OFT basemaps (if they have one for your ID). I would highly recommend trying the stage 1 base map assuming it is applicable to your setup. Then you can tweak the base map or start rolling your own etc etc.
I just tested the latest stg1 basemap over the weekend and it is within a few hp of the last pump gas dyno tune i did for my car.
i was just curious how this setup worked im more than happy with my tune/tuner just reading new things lol thanks tho
lexusb3 is offline
Old 09-17-2013, 02:46 AM   #18
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
awesome .. thanks for the reply!
how long have you been running FI? how many miles?
approx 9000 miles... brought it to Vegas and LA (2x) already..
86_ZN6 is offline
Old 10-06-2014, 12:32 AM   #19
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Bump for more results...
hmong337 is offline
Old 12-03-2014, 12:17 PM   #20
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
let's try another bump...
There's gotta be some people out there using the OFT base maps to tune FI....
Jaden
Jaden is offline
Old 12-03-2014, 12:33 PM   #21
RFB
RFB's Avatar
Drives: FRS
BRZWORLD has a twin with a Vortech supercharger and an oft VISHNU tune.
Works well !
CERBERUS
RFB is offline
The Following User Says Thank You to RFB For This Useful Post:
Shiv@Openflash (12-06-2014)
Old 12-03-2014, 01:07 PM   #22
Akari
Drives: 2013 DGM BRZ
Their Vortech tune looks pretty solid and they have awesome pricing for OFT users. This is likely the route I'm going and is definitely worth looking into if you are going FI.
Akari is offline
The Following User Says Thank You to Akari For This Useful Post:
Chad86 (12-04-2014)
Old 12-03-2014, 02:22 PM   #23
Jaden
Road-hole
Well...
Come On Vishnu, make that tune available. I would love for that tune to be available for the dual compressor supercharger I'm developing so I can use it as a baseline for testing...
Jaden
Jaden is offline
Old 12-03-2014, 02:55 PM   #24
Akari
Jaden
Send them a message, they may be able to help. I know it's free for OFT users who buy a Vortech from them, I'm unsure what their stance is on giving it out to just their regular OFT customers.
Akari is offline
Old 12-03-2014, 04:18 PM   #25
phrosty
I assume it's due to not all Vortech kits being alike. For instance, I believe I remember Perrin created a custom MAF housing because they found the one Vortech supplies to be erratic. There are also iirc two versions of the Vortech kit.
phrosty is offline
Old 12-03-2014, 04:27 PM   #26
Jaden
Road-hole
actually I'm not an OFT customer yet..
I was planning on buying one tonight or tomorrow but I was looking into the viability of tuning for FI with it. I hate the idea of spending $1200 for a flash n go tune with ecutek and not being able to modify it at all.
I also don't want to spend $500 if it's virtually impossible to do forced induction tuning with an OFT...
Jaden
Jaden is offline
Old 12-03-2014, 04:29 PM   #27
Foobar
SLO NO MO
Foobar's Avatar
I got the OFT300 tune from them after buying the OFT/OFH. I already had the Vortech kit from another vendor.
Foobar is offline
Old 12-03-2014, 05:40 PM   #28
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Jaden
When spending 5k+ for FI, fuel and drivetrain upgrades, I don't see the merit in saving 300-400 on the tune. Our EcuTek tunes start at 649 and end at 899 for most common setups (pretty much all you'd run on a stock motor) including hardware/license. Then you get the added features of RaceROM, overboost protection, wideband integration, custom traction control, flex fuel....you get the idea. By far the most cost effective upgrade over any other component of an FI setup. So can you do it? I'm sure. But it doesn't make any sense.
Xero-Limit is offline
The Following User Says Thank You to Xero-Limit For This Useful Post:
Circuit Motorsports (12-04-2014)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
