Old 06-24-2014, 06:48 AM   #211
Davey
Drives: BRZ Limited
Originally Posted by Monogram View Post
Exaggeration: Untruth, falsehood, baloney, big talk, hogwash, whopper, misrepresentation, fabrication, crock, yarn?
Am I close?
Not really, no.
Davey is offline   Reply With Quote
Old 06-24-2014, 06:20 PM   #212
Mr.Zoolittle
Drives: Five Axis FR-S, MR2 Turbo, TacomaDC
Someone close this thread. The MR 286 has moved and others have not. Enough is enough. Thanks for sharing your story MR 286.
Mr.Zoolittle is offline   Reply With Quote
Old 06-24-2014, 08:21 PM   #213
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It will die of it's own volition.
Again have to echo thanks to @Mr 286 for sharing his story, sorry for the shit you had to deal with and hope you find something else fun.
ineedyourdiddly
Old 06-26-2014, 09:55 PM   #214
fredfromnh
Drives: 2013 scion frs
Fwiw, toyota put a complete motor in mine (heads, short block, even injector lines) and it's been running like a champ. I was warned by service rep about light weight crank pulley. New motor came with new pulley.
fredfromnh is offline   Reply With Quote
Old 09-16-2014, 09:16 PM   #215
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
Add another to the list: fuel pump replacement (to get rid of crickets) by the dealer
See my posting, regular usage, er, except that happened in Canada during winter.
polarstorm is offline   Reply With Quote
Old 10-05-2014, 06:02 PM   #216
RavnFRS
Drives: 2013 Scion Frs
Well fellas, i believe i have had the most significant issues out of anyone. Currently on 5TH ENGINE. ALL WARRANTY COVERED! First engine: 15,000 miles, threw a rod complete catastrophic failure. A month and a half later, nearly whole engine rebuilt(only one head though) 300 miles later boom second engine bit the dust. Oil control valves malfunctioned starving my engine of oil. Another month later car back and 1,100 miles later boom. Both second and third engine had low idle problems/crickets. First engine had zero issues until the day it blew. Oil control valves seemed to be issue again and the head they didn't replace had major damage. Total rebuild for my 4th engine and car died first day i had it back. Lets just say i was fed up. Corporate was now all over my case. Every single piece of engine oil ever touched was replaced, subaru engine specialist tuned my current engine as perfectly as he could. Now running trd cold air(which i received for free) and corsa catback which I'm in love with. have had car for 2,000 miles and no issues. Car idles beautifully, runs perfect and has zero issues. But like others of you, had oil control valves replaced every time, control arms, DI injectors, the list goes on and on and on. Total cost incurred to dealership was $28,000 dollars lol. Toyota will be contacting me and thanking me for my patience and probably getting me trd body kit. Now have 18" enkeii raijins, blacked out tails and rocket bunny wing. Car is sexy and i missed having her all summer. Hope none of you have to go through what i went through. will have to picture all the paperwork sometime for fun.
RavnFRS is offline   Reply With Quote
Old 10-05-2014, 06:58 PM   #217
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by RavnFRS View Post
Well fellas, i believe i have had the most significant issues out of anyone. Currently on 5TH ENGINE. ALL WARRANTY COVERED! .
Just a wild ass guess, but between which two engines did they finally replace the harness and Engine ECU?
between 4 & 5 right?
Old 10-05-2014, 09:52 PM   #218
ZZT86
ZZT86's Avatar
Drives: BR86
@ RavnFRS - What is year of construction ?
ZZT86 is offline   Reply With Quote
blown engine
Engine Failure (#4 Rod Bearing + Short Block) eriktherod Issues | Warranty | Recalls / TSB 215 10-30-2015 12:24 AM
Crawford posts of engine failure example at 218hp OICU812 Engine, Exhaust, Transmission 95 03-27-2015 05:40 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
Stock Engine Failure Annahra Issues | Warranty | Recalls / TSB 37 06-25-2014 01:42 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
