Old 10-03-2014, 09:21 PM   #2185
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
I cant wait for my flex fuel kit to get in..
-Thomas
86SPEED is offline   Reply With Quote
Old 10-05-2014, 01:31 AM   #2186
CSG Mike
CSG Mike's Avatar
Originally Posted by nlowell View Post
This SC on e85 is a beast! I was just on my way up to Buttonwillow for a track day tomorrow. Cruise control was enabled at 75mph and sport mode was off (it's an AT). I just touched the accelerator to pass someone (maybe 1/2 way) - the car downshifted twice to 4th gear and my back end kicks out. Mind you this is on new RS3s. Eek and wow both at the same time I might have to upgrade my wheels to something much wider sooner than I thought...
How'd you do? What kind of lap times were you putting down and what top speeds were you seeing?
Old 10-05-2014, 03:05 AM   #2187
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
What a crazy day. This was my first time in HPDE3 so I was a little nervous to push it too hard.
The first session I was a complete mess. The RS3s I just put on were super slick for the first 2/3 of the 20 minute session - not to mention the track was cold. I was hitting 110 in the main straight but then I was smoking the brakes going in too deep. Times weren't that good with a top time of almost 2:18.
The second session was much better. I let some pressure out of the tires and stiffened up my shocks a little adding a little more stiffness to the rear. I tried to keep the car in a higher gear so the power was more manageable except when I wanted to use the power to help rotate the car like at bus stop. In the home stretch I was going ~113mph. I reduced my time by 7 seconds to hit a 2:11 but I know there was still way more time to catch.
By the third session the ambient temperature was 100 degrees and my brakes/tires/car wasn't too happy with this. I came out of the gate too aggressive and once everything heated up it was all sorts of slick. Pulling in from run three my car started smoking bad - I seriously thought something had caught fire. I was thinking "welp, good thing I bought that track insurance!" Ended up being ATF leaking from my aftermarket cooler lines. I spent the rest of the day fixing that in 100 degree weather - yuk. Luckily it was a fairly simple fix and I brought some ATF fluid and my fluid pump. Missed the fourth session but at least I made the 4 hour drive back home!
ATF temps hovered around 215 while on the track but then would spike when I got off the track up to 240-250.
Oil temps were consistently higher than ATF even though the oil cooler is 2x as large as the ATF cooler. Oil temps would be at ~235 when the ATF was at 210. The oil temp got as high as 245-250.
Hopefully because this is only in short duration it's not damaging.
I think I'm going to hit up the Buttonwillow instructor session in December. It's basically a $200 all day track session with as much or little instruction as you want. Lots of track time...with hopefully no breakage
nlowell is offline   Reply With Quote
The Following 4 Users Say Thank You to nlowell For This Useful Post:
86SPEED (10-06-2014), Freeman (10-10-2014), kbogarto (10-05-2014), myd_lyf_crysys (10-05-2014)
Old 10-12-2014, 01:12 AM   #2188
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Hello all,
I just finished installing my Kraftwerks C30 kit in my FRS but I am having issues with it. I Loaded up ZA1JA01C-enc New Map 91oct $6B 2A 1E that was on the USB drive using ECUTek. Started up the car and let it idle for a bit. The revs did not drop and stayed at ~1100 rpm. I blipped the gas and hit 2500 rpm and then the car stalled. I also noticed that my ECUTek was seeing 0.82bar when it stalled. I am suspecting that I have the wrong MAP sensor/EcuTek calibration combination.
The map sensor that I received was Denso 079800-5410. Any suggestions guys? Sucks that I have everything done but I don't think I can drive it.
I also had an incorrect intercooler silicone coupler in my box so I had to run out and buy one.
Thanks!
-Anthony
projek_01 is offline   Reply With Quote
Old 10-12-2014, 04:15 PM   #2189
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
@KraftWerks should get you taken care of quickly
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
KraftWerks (10-13-2014), projek_01 (10-13-2014)
Old 10-12-2014, 08:32 PM   #2190
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
My friend and I are working on a custom grill. I hated the look of the stock grill so I cut out. We whipped this up today. Paint comes next weekend. It's not for everyone but I like the look of it.
post_break is offline   Reply With Quote
The Following 3 Users Say Thank You to post_break For This Useful Post:
doberman8u (10-12-2014), KraftWerks (10-13-2014), zoth (10-13-2014)
Old 10-13-2014, 08:58 AM   #2191
post_break
post_break's Avatar
That picture doesn't do it justice and it was bothering me. Here is a picture from the side. It's still way too much of a cow catcher without paint. When it's black it will look so much better.
The Following 2 Users Say Thank You to post_break For This Useful Post:
KraftWerks (10-13-2014), zoth (10-14-2014)
Old 10-13-2014, 01:26 PM   #2192
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by projek_01 View Post
Hello all,
Thanks!
-Anthony
PM sent your way Anthony. We'll make sure this gets sorted immediately!
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
Old 10-13-2014, 09:15 PM   #2193
projek_01
projek_01's Avatar
Kraftwerks working in the background figuring out what is causing my issue. Can somebody post or email me a copy of their data log? I am curious to see what a normal running C30 kit looks like. Thanks
Old 10-13-2014, 10:38 PM   #2194
John92
Drives: White scion frs
Here is my Virtual Dyno, smoothing of 3. I am tuned by @moto-mike.
John92 is offline   Reply With Quote
The Following 3 Users Say Thank You to John92 For This Useful Post:
Freeman (10-14-2014), ramiram1984 (10-13-2014), Xero-Limit (10-14-2014)
Old 10-14-2014, 12:16 AM   #2195
projek_01
projek_01's Avatar
Thank you for that. Looks like some good numbers!
What I wanted to see was an EcuTek log with the maf and MAP readings.
I am seeing 0.32 bar at idle and up to 0.9 bar after I blip the throttle. Seems to be off but I wanted to see what others are getting.
Old 10-14-2014, 01:12 AM   #2196
John92
http://www.datazap.me/u/john92/3rd-g...0?log=0&data=1 hope this helps.
The Following User Says Thank You to John92 For This Useful Post:
projek_01 (10-14-2014)
Old 10-16-2014, 12:40 PM   #2197
projek_01
projek_01's Avatar
Thanks to @KraftWerks! Turns out that my car was stalling because the ECU needed to learn/calibrate itself to the new tune. After driving it lightly around town for a bit, it seems to be running smoother than the OEM tune.
The Following 3 Users Say Thank You to projek_01 For This Useful Post:
Freeman (10-16-2014), gmsii (10-16-2014), KraftWerks (10-16-2014)
Old 10-16-2014, 01:30 PM   #2198
JoonPrime
Drives: 2015 Limited series all white brz
just thought id write here that ive gotten my kit for a few weeks now and cant imagine my car ever without it. Kraftwerks was always kind enough to answer my seemingly endless idiotic questions and are quick to respond when i had a few troubles(which were not troubles, i just thought they were)
ALSO, this is more for new comers who are thinking about going FI,
Dynojet results
Car baselined at 165ish HP, 130TQ
After the KWSC install results
255HP, 205 TQ
i will post a video and dyno graph if anyone would like it , just showing the numbers gain are really quite good. the only other modification i have a invidia q300 catback exhaust :]
-also, still drives just as smooth around tough corners as before, just with a little more oomph when you punch it straightening out !
im plannin on getting a delicious tunes flash&go to compliment my DD style as well !
JoonPrime is offline   Reply With Quote
The Following 2 Users Say Thank You to JoonPrime For This Useful Post:
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
