#15 |
Drives: None
Thump, like a kick to the tire sort of sound. Every time I start up my car I hear a thump coming from the passenger side of the engine bay. When I turn on the ignition, I hear this thump coming from that side with a little startle. Car runs fine, no weird noises while cruising, no sign of idle dips so I figured it might be one of the components from the avo kit.
#16 |
Drives: None
#17 | |
Drives: 2017 RS3, 2013 BRZ, 2010 M3
its possible your exhaust is hitting against something that only occurs during cranking, maybe the over pipe? |
| The Following User Says Thank You to statik For This Useful Post: | Astroboy (10-05-2014) |
#18 |
Drives: None
I remember first experiencing this noise when I first started to feel my car shake due to bad motor mounts. I ended up having the mounts replaced with Perrin motor mounts which stopped the vibration I was feeling, so maybe you are right about that. I'll check it out, thanks for the response bro.
#19 |
Drives: None
Also, if it were the di seals, would the popping affect the rpm gauge? Would it make it dip or shake sometimes?
#20 |
I Love custom Turbo kits
Drives: Limited BRZ
The firecrack popping of DI Seals is noticeable after starting the car and accelerating it at idle.
I'd think it's the overpipe too. Sent from my SAMSUNG-SM-N900A using Tapatalk
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Astroboy (10-05-2014) |
#21 |
Drives: Scion FRS
I wish I was cool and backfired
#22 |
Drives: 2015 Series.Blue
What you guys are referring to is a muffler explosion or afterfire. A backfire is when it happens in the intake.
One is mostly harmless (if you still have cats it will cause issues) while the other can cause serious harm (and if it's happening on a fuel injected car, something is SERIOUSLY screwed). |
#23 |
Drives: None
David, does the di issue affect the rpm gauges? Does it make the rpm stutter or or shake each time it pops.
#24 |
Drives: Limited BRZ
I don't know the answer, but my guess is no.
#25 |
Drives: 2006 Subaru LGT
#26 |
Drives: None
#27 |
#28 |
Drives: None
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| fs feeler full blown turbo kit minus turbo | kingkai23 | Engine, Exhaust, Bolt-Ons | 10 | 03-11-2014 02:59 PM |
| nj brand new fa20 turbo kit minus turbo 2500 | kingkai23 | NY / NJ / CT / PA | 3 | 03-06-2014 06:41 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
