Old 10-04-2014, 10:51 PM   #15
Astroboy
Astroboy's Avatar
Drives: None
Thump, like a kick to the tire sort of sound. Every time I start up my car I hear a thump coming from the passenger side of the engine bay. When I turn on the ignition, I hear this thump coming from that side with a little startle. Car runs fine, no weird noises while cruising, no sign of idle dips so I figured it might be one of the components from the avo kit.
Astroboy is offline   Reply With Quote
Old 10-04-2014, 10:56 PM   #16
Astroboy
Astroboy's Avatar
Drives: None
Describe the thump
^^ this. It only happens at start up. I've asked multiple people who had the di seal faliure but I never get responses. I think they don't like to talk about it.
Old 10-04-2014, 11:50 PM   #17
statik
Drives: 2017 RS3, 2013 BRZ, 2010 M3
this doesn't sound like DI seals, you should be able to get a reproducible popping when revving the engine, you would notice it driving around.
its possible your exhaust is hitting against something that only occurs during cranking, maybe the over pipe?
statik is offline   Reply With Quote
The Following User Says Thank You to statik For This Useful Post:
Astroboy (10-05-2014)
Old 10-05-2014, 12:12 AM   #18
Astroboy
Astroboy's Avatar
Drives: None
I remember first experiencing this noise when I first started to feel my car shake due to bad motor mounts. I ended up having the mounts replaced with Perrin motor mounts which stopped the vibration I was feeling, so maybe you are right about that. I'll check it out, thanks for the response bro.
Old 10-05-2014, 12:13 AM   #19
Astroboy
Astroboy's Avatar
Drives: None
Also, if it were the di seals, would the popping affect the rpm gauge? Would it make it dip or shake sometimes?
Old 10-05-2014, 12:33 AM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The firecrack popping of DI Seals is noticeable after starting the car and accelerating it at idle.
I'd think it's the overpipe too.
Sent from my SAMSUNG-SM-N900A using Tapatalk
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 10-05-2014, 01:19 AM   #21
dabocx
dabocx's Avatar
Drives: Scion FRS
I wish I was cool and backfired
dabocx is offline   Reply With Quote
Old 10-05-2014, 01:41 AM   #22
Poodles
Drives: 2015 Series.Blue
What you guys are referring to is a muffler explosion or afterfire. A backfire is when it happens in the intake.
One is mostly harmless (if you still have cats it will cause issues) while the other can cause serious harm (and if it's happening on a fuel injected car, something is SERIOUSLY screwed).
Old 10-05-2014, 02:32 PM   #23
Astroboy
Astroboy's Avatar
Drives: None
David, does the di issue affect the rpm gauges? Does it make the rpm stutter or or shake each time it pops.
Old 10-05-2014, 03:18 PM   #24
Sportsguy83
Drives: Limited BRZ
I don't know the answer, but my guess is no.
Old 10-06-2014, 11:34 AM   #25
wcbjr
Drives: 2006 Subaru LGT
Came here to post this.
Backfire: [ame="https://www.youtube.com/watch?v=hKVlzNt-4tE"]intake backfire - YouTube[/ame]
wcbjr is offline   Reply With Quote
Old 10-06-2014, 08:43 PM   #26
Astroboy
Astroboy's Avatar
Drives: None
Backfire:
Yes, but unfortunately I'm not getting any answers to my questions about the issue. Actually, I don't even get responses half of the time
Old 10-07-2014, 10:01 PM   #27
Poodles
You never answered the simple question: Do you have a BOV venting to atmosphere?
Old 10-08-2014, 12:07 PM   #28
Astroboy
Astroboy's Avatar
Drives: None
Nope. I have a turbo smart bpv installed in my car. Why?
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
fs feeler full blown turbo kit minus turbo kingkai23 Engine, Exhaust, Bolt-Ons 10 03-11-2014 02:59 PM
nj brand new fa20 turbo kit minus turbo 2500 kingkai23 NY / NJ / CT / PA 3 03-06-2014 06:41 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
