Old 10-02-2014, 07:35 PM   #295
KevinB85
KevinB85's Avatar
Guys I too am looking for SVXdc harness.
My brother in law is very good with a soldering iron and electronic diagram savy. Is there any guides online to how to build my own harness? When I look at the pictures, it looks very simple, something you can get from radioshack even.
KevinB85 is offline   Reply With Quote
Old 10-04-2014, 02:53 AM   #296
greencounty
greencounty's Avatar
Originally Posted by hasanaltan View Post
Hey everyone. I'm a complete noob to car wiring and purchased a Rydeen Duo for my 2015 FRS.
What else do I need to wire this thing up properly? Will this suffice? http://autoharnesshouse.com/19867.html
Yes. That is the harness that I have on my BRZ. It works great!
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 10-04-2014, 06:48 PM   #297
hasanaltan
hasanaltan's Avatar
Drives: 2015 FR-S 6MT
Purchased. Thanks for the reply
hasanaltan is offline   Reply With Quote
Old 10-14-2014, 04:36 PM   #298
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Snagged this as well!
Cockatoo is offline   Reply With Quote
Old 11-18-2014, 07:36 AM   #299
pepe
Drives: gt86
our cable car called trigger is necessary?
pepe is offline   Reply With Quote
Old 11-18-2014, 07:53 AM   #300
pepe
Drives: gt86
could put as remove the door trim to route the cable to the touch screen?
Old 11-19-2014, 12:59 AM   #301
greencounty
Are you asking if the trigger wire is needed on our cars?
The BRZ has the trigger wire already. I believe the FRS does not have the trigger wire from the factory.
Garage:
Old 11-19-2014, 01:15 AM   #302
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
GT86 cars in Europe with the TAS300 head unit already have the trigger (+12V reverse gear signal) connected.
SVXdc is offline   Reply With Quote
Old 11-19-2014, 05:54 AM   #303
pepe
Drives: gt86
I understand then that this kit is enough, and would plug and play?
http://www.ebay.es/itm/261662886080?...84.m1423.l2649
and could also be a combination of this piece
http://www.ebay.es/itm/121479363404?...84.m1423.l2649
and this camera?
http://www.ebay.es/itm/141314675831?...84.m1423.l2649
Without any additional wiring trigger?
Old 11-19-2014, 07:26 AM   #304
pepe
Drives: gt86
do not understand why in this kit there is a connection to the connector 10 pin connector and one for 16pin, and other kits there is only one connector.
in that other kit there is only one connector to the head unit.
http://www.ebay.es/itm/Roadshop-SUBH...-/261662886080
Old 11-19-2014, 08:30 AM   #305
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
It looks like it's getting power from one plug and video signal going into the other. The eBay one might require you to make the power connection on your own.
For more details about wiring visit svxdc's site, he sells harnesses to accomplish backup cam. I bought a cam for about $2 on eBay as well as his harnesses and the cam works perfectly with OEM radio and 100% plug n play after a little bit of soldering... Do not spend a lot of money on this lol
B-R-Z is offline   Reply With Quote
Old 11-19-2014, 12:17 PM   #306
pepe
Drives: gt86
ok, thanzs
Old 11-19-2014, 01:18 PM   #307
celica73
Any thoughts on how [ame=http://www.amazon.com/PAC-CAM-TY11-Reverse-Camera-T-Harness/dp/B00KWLA3T0/ref=sr_1_2?ie=UTF8&qid=1416419661&sr=8-2&keywords=reverse+harness+scion]this[/ame] compares to the SVXdc harness?
PAC CAM-TY11
Old 11-19-2014, 01:47 PM   #308
B-R-Z
B-R-Z's Avatar
It should work, you might just want to confirm pins are in the correct locations. And the power line in that will only work if you cam is 6-volt. You could use it as a trigger for a relay if your cam is 12v..as I did in my setup.
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
