Old 09-30-2014, 04:36 PM   #1
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Is the front sway bar bushings liquid filled?
Because mine is leaking. I want to go to the dealer but they'll probably say it's a wear item.
Rayme is offline   Reply With Quote
Old 10-01-2014, 12:42 AM   #2
HapaHaole
Drives: Grocery cart
Whats the oil leak above from? And NO they are not oil filled, but do have some lucubration on them.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 10-01-2014, 01:30 AM   #3
WesleyG
Drives: 2014 Satin White Pearl GTS auto
looks more like something leaked onto them,
BTW, i saw your avatar, are you into die antwoord?
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 10-01-2014, 02:24 AM   #4
No, just lucubrated. @Rayme, still sporting your cool roof art? <3 Bender.
Replace bushings. Make sure there's no active leak on the new ones.
Old 10-01-2014, 05:04 AM   #5
gsrmn
Drives: 2013 white out FRS
u have a active leak its even on your axle
gsrmn is offline   Reply With Quote
Old 10-01-2014, 08:02 AM   #6
PunX
Drives: GT86 - minor mods
Not a leak, i have diagnosed it @dealer as heat damage from Catalyst, if you look closely all the rubber has been heavily deformed by heat, it even transferres to other side by sway bar.
PunX is offline   Reply With Quote
The Following User Says Thank You to PunX For This Useful Post:
Rayme (10-01-2014)
Old 10-01-2014, 11:01 AM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Yea, love them! But their last album I found it a little less enjoyable...
Yup, still on there.
Interesting. I thought the techs. might have shot lubrication when they changed my oil but the other side is dry as the sahara. I'll see if I can get it replaced, it's definitely damaged by the look of it
Old 10-01-2014, 11:04 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
I have an oil spot in the same area, If you have MT I believe that block off plate that is said to leak is above this area. My block off plate was dry to touch but who knows.
Old 10-01-2014, 12:00 PM   #9
extrashaky
Drives: 2014 BRZ Limited
LOL at "lucubration."
Mine is also stained on/around that mount, but it's relatively dry and I can't figure out where it came from. I'm pretty sure it's not coming from the cam plate, 'cause I've been watching that bastard like a hawk and have noticed no leaks at all there.
Based on the comment about the cat, I'm wondering if exhaust heat has caused the lube on it to liquefy and sweat out.
Old 10-01-2014, 12:38 PM   #10
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
did you touch the lube? I know the feel and smell of oil (maybe? from the cam plate over pipe down?), transmission (should not be), brake fluid (too far out the way), silicone grease (which is what in between the sways) etc. you can rule some things out. You need more pictures GL bro.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 10-01-2014, 02:07 PM   #11
aagun
Drives: 86
That oil is normal . Before we install the sway bar we lucubration the bushes by heavy grease. Also after market sway bar have it . If there is no lucubration it will squeaks
aagun is offline   Reply With Quote
Old 10-01-2014, 06:10 PM   #12
extrashaky
Everyone playing the drinking game take a shot!
lucubration
Again with this word. I'm picturing you all sitting around on the ground staring at that bushing and contemplating it.
The Following User Says Thank You to extrashaky For This Useful Post:
Rayme (10-01-2014)
Old 10-02-2014, 02:59 PM   #13
aagun
Drives: 86
oh sorry my bad i meam lubrication
Old 10-02-2014, 05:06 PM   #14
That's funny. It looked like you were just playing along. No worries
lucubration
FS: Stock sway bars with bushings Tim_Asphalt_FRS Brakes, Suspension, Chassis 12 10-09-2014 11:56 AM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
FA20CLUB Oil Cooler Kit Liquid/Liquid Andy@FA20Club Engine, Exhaust, Transmission 46 02-03-2014 11:10 AM
Front Control Arm Bushings. feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-02-2013 05:35 AM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 10:32 PM
