Old 09-12-2014, 06:22 PM   #71
deliroast
Drives: 2014 SSM BRZ
Since you can't read well. The guy who responded to the tech line (Subaru work order) called back to the local dealer and informed him that it was a known issue (at Subaru) and that they would be sending a transmission out. There was no opening up it checking synchros. It was these are the issues, replace whole transmission.
Also, once again, started experiencing issues at stock power output.
M3 > BRZ
deliroast is offline   Reply With Quote
Old 09-12-2014, 07:06 PM   #72
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
My 5th sports car and had about 8 muscle cars as well so no I don't "sit on it". And I have broken several of them after pushing them too hard on modded equipment. The difference is I knew the risk was there and did not blame the car manufacturer for my problems. Not sure how taking responsibility for my own actions makes me a "fan boy"?
Just because a bunch of guys whine and moan about their transmissions on a forum does NOT make it a known issue. It just means that the small percentage of the people that use the forum are more vocal about any problem they have. There are not nearly enough people that are on here to represent all the cars sold. Do a quick google search on FRS transmission problems and the only hits you will get are this forum or places that pulled their misinformation from it.
Shit happens and things break when you push them. Fix it and move on
I will fix it FAN BOY! and your stock ride may not visit the dealer much it is a known issue.
And Muscle Cars, jajaja thats why you are so used to broken cars!
kombatlion is offline   Reply With Quote
The Following User Says Thank You to kombatlion For This Useful Post:
Tcoat (09-21-2014)
Old 09-12-2014, 08:46 PM   #73
And at what point did I say MINE was stock?????
Old 09-12-2014, 08:47 PM   #74
Well that just leaves bad driving then doesn't it?
deliroast (09-13-2014), Ultramaroon (10-01-2014)
Old 09-13-2014, 05:56 AM   #75
deliroast
Lol ok.
M3 > BRZ
Old 09-21-2014, 08:12 AM   #76
deliroast
Just had our sixth person take their car in for bad synchros. That makes 3 replaced transmissions in the area in the last 2-3 months and 2 still fighting local dealers after toyota acknowledged that the transmission should have been replaced
M3 > BRZ
Old 09-23-2014, 03:03 PM   #77
RacerX
Drives: Subaru BRZ
Going from 4-5 at +5000rpm it feels like the shifter hits a wall and doesn't go into gear.
For those who have had their tranny recently replaced is everything 100% perfect now? Is it confirmed that there has been a revision to the replacement transmissions?
I'm going to contact my dealer but I don't know how I can demonstrate the issue for them unless I'm speeding through city streets. There are no highways nearby.
RacerX is offline   Reply With Quote
Old 09-23-2014, 03:04 PM   #78
deliroast
Mine is 100% so far. Part numbers were also different on the work order. Name:  ImageUploadedByTapatalk1411499077.556978.jpg
M3 > BRZ
Old 09-30-2014, 12:36 PM   #79
TougeSlug
Drives: 2015 CBS WRX 2014 D4S Mono(R.I.P.)
Had the same experience as deli. And they replaced the tranny in 2 days. Gave me a loaner car for 2 days.
TougeSlug is offline   Reply With Quote
Old 09-30-2014, 03:27 PM   #80
deliroast
Those assholes took almost a week and never called me to let me know it was done. Whole shitty week with an outback
M3 > BRZ
Old 09-30-2014, 11:58 PM   #81
RacerX
Drives: Subaru BRZ
With mine it comes and goes. Sometimes it goes in just fine, other times it takes alot more force. I've just trained myself to shift a little slower going into 5th to give the syncros a little more time to do their thing. It only grinds if I expect it to go in quickly and let out the clutch reflexively.
Did it grind or resist getting into gear if you guys shifted slower? Or did it only happen when you're aggressively shifting?
Old 10-01-2014, 01:29 AM   #82
Imrac
Drives: 13 SWP BRZ Prem
Had my tranny replaced due to the same reason recently.. It would grind no matter how slow or fast I up shifted.
It took them over a week to "Diagnose" the problem. Once they were able to reproduce the issue (not sure why it was so hard, I told them go 45 MPH in 3rd and shift into 4th, it happens every time.) They kept insisting that they have to drop the trans and verify the clutch wasn't abused and "raced". I have header back exhaust and I think that had them concerned.
The service writer called me asking if there was anything they should be concerned about before dropping my trans... A couple days later they called back stating they have the car ready with a new tranny.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 10-01-2014, 09:33 AM   #83
TougeSlug
Be glad you at least had an outback. I had a pos hyundai accent. That crappy 2014 made me think it was 1997 and it made me hate my life
Old 10-06-2014, 04:21 PM   #84
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Get your transmission warranted then post the repair order in my thread so I can use it in court.
How would you shift from 4 to 5? qqzj BRZ First-Gen (2012+) — General Topics 37 05-01-2014 08:10 PM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
HUD shift up and shift down display question JS86JS Electronics | Audio | NAV | Infotainment 6 05-17-2013 02:54 AM
What really grinds my gears! CircuitJerk Off-Topic Lounge [WARNING: NO POLITICS] 124 04-01-2013 08:45 PM
How do you shift? Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 27 12-30-2012 01:11 PM
