Old 09-30-2014, 07:18 AM   #29
Snowblind
Just use it. It will get smoother.
Old 09-30-2014, 12:08 PM   #30
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
You can use a regular allen wrench or one of the allen headed sockets (which I prefer).
Kwaziekeller is offline   Reply With Quote
Old 09-30-2014, 02:46 PM   #31
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Not enough room I think to used this, when I tried.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 10-02-2014, 06:47 PM   #32
Kwaziekeller
I used them no problems, even took the bolt out to put some blue loctite on it with them. If you leave the shifter in neutral or put it in 5th/6th it gives u more room.
Old 10-15-2014, 11:12 PM   #33
Cop
Cop's Avatar
Drives: 2013 FRS
I just installed the kit tonight and am having similar amounts of slack as mentioned in one of the earlier videos. Does anyone have some tips for tightening the adapter bolt? That one was a PITA to tighten and it looks like I need to tighten it even more.
Cop is offline   Reply With Quote
Old 10-16-2014, 08:49 AM   #34
zoth
zoth's Avatar
Just keep on it until you see it stick out about 2 to 3 lines of threads.
Sent from my SM-N900T using Tapatalk
Old 10-16-2014, 09:49 AM   #35
blown
Drives: ft86
mine had enough slack, and eventually i could not get into 1st or 2nd. turned out the bolt backed out. you may need to add red loctite, as what it came with did not work.
blown is offline   Reply With Quote
Old 10-16-2014, 11:36 AM   #36
Cop
Cop's Avatar
Drives: 2013 FRS
Figured out I made a mistake in installing the adapter initially, fixed it and now the slack is largely gone. Feels great and was just what I was looking for
Old 10-16-2014, 09:18 PM   #37
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I got mine installed a few days ago. Not a bad decision!
Old 10-18-2014, 03:03 PM   #38
Anh5oi
Drives: 13 FRS
Installed and it's very stiff to shift but I liked it...lol
Anh5oi is offline   Reply With Quote
Old 08-21-2015, 09:15 PM   #39
axelo
Drives: Whiteout frs
Mine came loose also....did blue locktite and is holding better, but it will come loose if i use it the way i want to use it....so will take it easy until have time to use red or 272... Feels even better with mtec shift springs
Thanks for sharing
axelo is offline   Reply With Quote
Old 08-23-2015, 12:40 AM   #40
Cop
Cop's Avatar
Drives: 2013 FRS
Thanks for sharing
I'm using red loctite and it's much better now. I think I went an entire month without the bolt coming too loose.
Old 08-23-2015, 05:55 PM   #41
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Originally Posted by charged86 View Post
yes re installing the stock boot is like putting on a condom in the dark, drunk, in a hurry , whilst falling down a flight of stairs.
Oh college.
Definitely going to get this next!
bryan767 is offline   Reply With Quote
Old 12-24-2015, 02:13 PM   #42
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Glad I'm not the only one with this issue. Does anyone know if Toyota has a fix? I did notice that when moving the shifter, the bolt rubs on the bottom input shaft causing the bolt to turn.
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 02:42 PM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
TRD quick shifter (sold) lovebeingbleu98 Transmission and Driveline 13 04-09-2014 06:25 PM
trd quick shifter? tjohnson104 Engine, Exhaust, Transmission 6 01-26-2014 02:37 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
