Because compromise ®
Drives: Red Herring
Spring Length Question
Hypothetical question.
What's the difference between fitting a 5 inch spring and a 6 inch spring of the same rate with the spring perch 1 inch lower? Assumes that the spring perch has adequate adjustment and the spring is fully seated at maximum droop. Ta.
#2 |
Drives: FR-S stock for now
1 inch.
DougW |
| The Following 2 Users Say Thank You to DougW For This Useful Post: | Captain Snooze (09-29-2014), themajesticone (09-29-2014) |
#3 |
Senior Addict
Drives: 86 GT
1 inch less bump travel?
#4 |
Drives: '13 BRZ Ltd
The longer spring will provide more travel before coil bind. May or may not be an issue depending on the setup. Also the 6" spring will be marginally heavier, if that makes a difference to you.
| The Following User Says Thank You to Wepeel For This Useful Post: | Racecomp Engineering (09-29-2014) |
#5 |
This! I doubt that coil bind is going to be an issue with either free length on these cars though, unless you're running really low spring rates.
#6 |
#7 | |
Drives: '13 BRZ Ltd
I was wondering this - what do you guys assume for bump stop compression? I'm assuming "fully compressed" is about 0.5" of the free length, but I'm thinking it might be longer than that. |
#8 | |
For the purposes of avoiding coilbind we typically assume a much larger % of the bumpstop can be compressed. - Andy |
#9 |
Senior Addict
Drives: 86 GT
This thread is boring without the expert opinions of Ubersuber....
| The Following 5 Users Say Thank You to Fizz For This Useful Post: | Captain Snooze (09-29-2014), gramicci101 (09-29-2014), jvincent (09-29-2014), Mad1723 (09-29-2014), wparsons (09-29-2014) |
#10 | |
I would think it depends more on how much the spring is compressed between free length and static ride height than anything else, which is mostly going to be driven by spring rate.
#11 | |
- Andy |
#12 |
Ah, gotcha. My thought was that with stiffer springs you're running less pre-load and will run out of damper stroke before running into coil bind. Guess it really depends on how much stroke you have and spring rate.
#13 |
Drives: '13 BRZ Ltd
Yep, the kw have about 5.6" of total damper stroke in the front. With my ride height 1" lower than stock, using a 7"/7k spring, I actually only have 0.12" of margin before coil bind (spring travel left when the damper is fully bottomed), assuming 50% bump stop compression. I was surprised to see it was that close.
If I dropped to 1.5" lowered I'd have 0.5" before coil bind. I should probably lower the car a bit. |
| motion control suspension(mcs) spring length | toby714 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-21-2014 11:42 AM |
| OEM Machperson Strut Spring Length x Inside Diameter | mslerner2002 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 02-26-2014 06:29 PM |
| Spring orientation question | theom | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 07-05-2013 05:29 PM |
| Coilover Spring Length | Tirewarmer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-17-2013 12:39 PM |
| To coilover or spring? That is the question... | Knightmare | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 01-13-2013 10:34 PM |
