Old 09-29-2014, 05:30 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Spring Length Question
Hypothetical question.
What's the difference between fitting a 5 inch spring and a 6 inch spring of the same rate with the spring perch 1 inch lower?
Assumes that the spring perch has adequate adjustment and the spring is fully seated at maximum droop.
Ta.
Old 09-29-2014, 08:54 AM   #2
DougW
Drives: FR-S stock for now
1 inch.
DougW
DougW is offline   Reply With Quote
The Following 2 Users Say Thank You to DougW For This Useful Post:
Captain Snooze (09-29-2014), themajesticone (09-29-2014)
Old 09-29-2014, 10:10 AM   #3
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
1 inch less bump travel?
Fizz is offline   Reply With Quote
Old 09-29-2014, 11:33 AM   #4
Wepeel
Drives: '13 BRZ Ltd
The longer spring will provide more travel before coil bind. May or may not be an issue depending on the setup. Also the 6" spring will be marginally heavier, if that makes a difference to you.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Racecomp Engineering (09-29-2014)
Old 09-29-2014, 11:40 AM   #5
wparsons
wparsons's Avatar
This! I doubt that coil bind is going to be an issue with either free length on these cars though, unless you're running really low spring rates.
flickr
Old 09-29-2014, 12:01 PM   #6
5 inches is a pretty short spring though...I wouldn't run them on a KW for example.
- Andy
Old 09-29-2014, 12:15 PM   #7
Wepeel
Drives: '13 BRZ Ltd
- Andy
Yeah, 5" is kind of short. Maybe if you had a damper with crap travel and ran super low it would work.
I was wondering this - what do you guys assume for bump stop compression? I'm assuming "fully compressed" is about 0.5" of the free length, but I'm thinking it might be longer than that.
Old 09-29-2014, 12:30 PM   #8
Depends on the bumpstop of course and sometimes that data is available.
For the purposes of avoiding coilbind we typically assume a much larger % of the bumpstop can be compressed.
- Andy
Old 09-29-2014, 12:36 PM   #9
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
This thread is boring without the expert opinions of Ubersuber....
The Following 5 Users Say Thank You to Fizz For This Useful Post:
Captain Snooze (09-29-2014), gramicci101 (09-29-2014), jvincent (09-29-2014), Mad1723 (09-29-2014), wparsons (09-29-2014)
Old 09-29-2014, 12:57 PM   #10
wparsons
wparsons's Avatar
- Andy
Because of their spring rates, or because of their shock design?
I would think it depends more on how much the spring is compressed between free length and static ride height than anything else, which is mostly going to be driven by spring rate.
flickr
Old 09-29-2014, 01:26 PM   #11
KWs have a lot of available stroke. Yes if they're slammed it's not a lot of bump travel. But at a realistic ride height you have a good amount of bump travel...probably more than the a 5 inch spring has before it binds (which is a problem).
- Andy
Old 09-29-2014, 02:40 PM   #12
wparsons
wparsons's Avatar
- Andy
Ah, gotcha. My thought was that with stiffer springs you're running less pre-load and will run out of damper stroke before running into coil bind. Guess it really depends on how much stroke you have and spring rate.
flickr
Old 09-29-2014, 08:48 PM   #13
Wepeel
Drives: '13 BRZ Ltd
Yep, the kw have about 5.6" of total damper stroke in the front. With my ride height 1" lower than stock, using a 7"/7k spring, I actually only have 0.12" of margin before coil bind (spring travel left when the damper is fully bottomed), assuming 50% bump stop compression. I was surprised to see it was that close.
If I dropped to 1.5" lowered I'd have 0.5" before coil bind.
I should probably lower the car a bit.
motion control suspension(mcs) spring length toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-21-2014 11:42 AM
OEM Machperson Strut Spring Length x Inside Diameter mslerner2002 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-26-2014 06:29 PM
Spring orientation question theom Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-05-2013 05:29 PM
Coilover Spring Length Tirewarmer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-17-2013 12:39 PM
To coilover or spring? That is the question... Knightmare Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-13-2013 10:34 PM
