Old 09-29-2014, 04:53 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Smallest bolt on spacer?
What is the smallest possible bolt on spacer I can buy? I am talking to ones with built in lugs, not the ones that require extended studs.
I am trying to fit stock wheels over AP racing sprint. I read it needs a 10mm spacer but I dont think there are 10mm bolt on available.
Maybe I should just buy some slightly longer studs...
Old 09-29-2014, 04:55 PM   #2
gramicci101
Off Topic
I've seen 15mm from several dealers, but I've not seen any 10mm. What wheels are you using?
The Following User Says Thank You to gramicci101 For This Useful Post:
ZionsWrath (09-29-2014)
Old 09-29-2014, 04:56 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Just trying to put stock wheels over them, stock tires have a lot of life would hate to waste them. I have track wheels that will clear them.
Old 09-29-2014, 05:03 PM   #4
gramicci101
Off Topic
If you're using stock wheels and tires, @Corner3garage has a great deal on front and rear spacers, but they're 20/25mm front and rear. I have them on my car, and I really like how it makes the overall stance of the car look.
EDIT:
Before
After
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Corner3garage (09-29-2014), ZionsWrath (09-29-2014)
Old 09-30-2014, 03:19 PM   #5
illmattic
illmattic's Avatar
Poject Kics makes 10mm bolt on spacers.
http://www.evasivemotorsports.com/mm...s_Wheel_Spacer
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 09-30-2014, 03:26 PM   #6
Dezoris
Dezoris's Avatar
Eibach 10mm spacers, ft86speed factory.
http://www.ft86speedfactory.com/inde...FSMLMgodkBUA5A
Old 09-30-2014, 03:28 PM   #7
jvincent
jvincent's Avatar
I was going to chime in with 10mm bolt-on as being the smallest.
However, since the spacer nuts can only be a maximum of 10mm deep, you won't have enough thread engagement to be safe.
The technical info I have seen say you should have at least the same nut depth as bolt diameter. Since our lug bolts are 12mm the smallest bolt on spacer should be 12mm, assuming tightened down flush to the hub.
Old 09-30-2014, 04:21 PM   #8
JonMotoring
Drives: Scion
There are 10mm adapters out there but it's a bit of a risk to run them as we have seen something like this happen where the studs on the adapter just tear apart and break away from the spacer/adapter. However, There are some 10mm adapters that people have said worked.
Circuit Sport 5x100 to 5x114.3 Adapter/Spacer (15mm)
We carry Circuit Sports 15mm 5x100 to 5x114.3 adapters and 15mm 5x100 bolt on spacer. Many customer have ran these on their cars and have had great results.
JonMotoring is offline   Reply With Quote
Old 09-30-2014, 04:55 PM   #9
buddy32
Drives: WRB Subaru BRZ Limited
Is there a reason you want a bolt on instead of slip on?
buddy32 is offline   Reply With Quote
Old 09-30-2014, 07:00 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
I think 10mm is the smallest for spacers with bolts, but you can get 3mm spacers that slip on and won't require longer studs... but it might not be enough to clear whatever you need to clear
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-01-2014, 07:52 PM   #11
OmarYasin
OmarYasin's Avatar
Size:  71.7 KB get arp wheels studs there easy to install
OmarYasin is offline   Reply With Quote
Old 08-19-2015, 04:15 PM   #12
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by OmarYasin View Post
Attachment 92302 get arp wheels studs there easy to install
are those muteki open ended nuts?
BRZ RN is offline   Reply With Quote
The Following User Says Thank You to BRZ RN For This Useful Post:
OmarYasin (08-19-2015)
Old 08-19-2015, 04:33 PM   #13
DAEMANO
Time Traveller
I wouldn't go thinner than 15mms for bolt on. Recommend H&R Track+ hubcentric alloy spacers
http://trakplus.com/buy
Old 08-19-2015, 04:58 PM   #14
OmarYasin
OmarYasin's Avatar
Yes
Sent from my LGMS323 using Tapatalk
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
smallest OD coil over / spring perch BadBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2014 12:56 PM
What's the smallest oil cap? Hanakuso Engine, Exhaust, Transmission 2 07-08-2013 03:55 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
